| CANADA Canada |
Drives: 2013 BRZ WRB
17x7.5 +40 offset
Hey everyone,
not too sure about this setup... is this compatible with an OEM or slightly lowered setup? I do not want to disturb the OEM suspension geometry by replacing the offset. thnx |
#2 |
Drives: 6MT
Yes it is fine, the stock wheel is 17x7 +48, so that is not far off from stock specs
that's an 8mm difference in offset, and 1/2 an inch wider wheel geometry will not be affected the wheel will poke out maybe 2cm more than the stock wheel, noticeable, but subtle still |
#3 |
Thnx
| Wheel Directory: Motegi MR125 17x7.5 +42 | mechaghost | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 08-16-2013 12:41 PM |
| Autec Zenit 17x7 40 offset | KBRZee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 07-08-2013 04:39 PM |
| Enkei RPF1 17x7 42mm offset | brz7400 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 01-08-2013 06:26 PM |
| Let's talk Offset. 17x7.5 +35 | Tainen | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 06-28-2012 04:57 PM |
| Volk Racing GT-C 17x7 and Gram Lights 57 Optomise 17x7 | xravexboix | Wheels and Tires | 0 | 05-24-2012 08:04 PM |
