#43 |
Drives: 2013 Scion FR-S 6MT Raven
To lower or not to lower....
Tein s.tech springs and you'll be fine
A.Corvino
http://www.streetmasters.com/ |
#44 |
Drives: FRS
#45 |
Drives: 2014 SWP BRZ LIMITED
Funny you say that. I went over my first significant bumps after my spring install and my cheeks puckered a little as I so have an exhaust that hangs bellow the axle. No problem however.
#46 | |
Drives: FRS
Stock tires (1/4 inch difference) and I'm ok - But there WILL be that one stinkin pot hole eventually - ![]() ![]() CEREBRUS |
#47 |
Drives: 2014 Scion FR-S ハチ
1.2 front 1.4 back with H&R Super Sport Springs and no problems with speed bumps so far. I have to go over them in my own neighborhood and work.
#48 |
Drives: 2014 WRB BRZ 6MT
I honestly don't know exactly how low my car is (on ST Coils)
![]() all i know is, i have 0 problems getting into my driveway, but now i do take literally every angle a LOT slower also, the main problem area seems to be my exhaust, it's low as shit to the ground...doesn't look to be maybe a half an inch or so higher than the damn bottom of the wheels (not the tires, the actual wheel) |
#49 | |
Drives: FR-S 6MT
The axle half shafts that will be compromised by the new angles which will put more wear and tear on the CV joints... Just another consideration to keep in mind when you modify something that is designed to work a certain way.. |
#50 | |
Drives: FRS
yep
However - if it wasn't a daily driver but a dedicated track car - go all the way. $$$$$$$$$$$$$$$$$$ for mods and breakage ! (All hobbies are expensive) ![]() ![]() CERBERUS |
| The Following User Says Thank You to RFB For This Useful Post: | humfrz (01-17-2014) |
| How should i lower :( | Obja | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 06-15-2014 12:39 PM |
| Looking to lower... | PoWn3d_0704 | Northwest | 34 | 03-28-2014 05:43 PM |
| Want to lower my FR-S where can I go? | laley81 | Southern California | 16 | 08-22-2013 07:05 PM |
| I want it lower !! | Ndgreely | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 07-12-2013 11:10 PM |
| How can I go lower? | nab335 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 07-08-2013 03:15 PM |
