Old 01-16-2014, 11:40 PM   #43
corvino26
corvino26's Avatar
Drives: 2013 Scion FR-S 6MT Raven
To lower or not to lower....
Tein s.tech springs and you'll be fine
corvino26 is offline   Reply With Quote
Old 01-16-2014, 11:46 PM   #44
RFB
RFB's Avatar
Drives: FRS
Originally Posted by ronboogieon View Post
So is 1 inch drop the lowest you can go without significantly scraping or can you go slightly lower?
Lower than 1 inch and we can all laugh at you when you high centre in a drive through and ask for help to push your car off the speed bump !
CERBERUS
RFB is offline   Reply With Quote
Old 01-16-2014, 11:58 PM   #45
Dwood11
Dwood11's Avatar
Drives: 2014 SWP BRZ LIMITED
CERBERUS
Funny you say that. I went over my first significant bumps after my spring install and my cheeks puckered a little as I so have an exhaust that hangs bellow the axle. No problem however.
Dwood11 is offline   Reply With Quote
Old 01-17-2014, 02:10 AM   #46
RFB
RFB's Avatar
Drives: FRS
All I have is a 5 axis kit with no lowering and I scrape comin outta my driveway with direzza's.
Stock tires (1/4 inch difference) and I'm ok -
But there WILL be that one stinkin pot hole eventually -
CEREBRUS
Old 01-17-2014, 02:15 AM   #47
Rio
Rio's Avatar
Drives: 2014 Scion FR-S ハチ
1.2 front 1.4 back with H&R Super Sport Springs and no problems with speed bumps so far. I have to go over them in my own neighborhood and work.
Rio is offline   Reply With Quote
Old 01-17-2014, 02:45 AM   #48
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
I honestly don't know exactly how low my car is (on ST Coils)
all i know is, i have 0 problems getting into my driveway, but now i do take literally every angle a LOT slower
also, the main problem area seems to be my exhaust, it's low as shit to the ground...doesn't look to be maybe a half an inch or so higher than the damn bottom of the wheels (not the tires, the actual wheel)
SoCal909 is offline   Reply With Quote
Old 01-17-2014, 10:10 AM   #49
Mikem53
Drives: FR-S 6MT
Originally Posted by cooldandani View Post
Hey guys!!! Quick question, any one know how much a decent set of coil overs costs and benefits other than how sexy this beast is going to look when lowered?? Lol I don't want to lower it too much I wanna be able to drive and not worry about hitting anything.... Thanks!
Sent from my SGH-T889 using Tapatalk
Besides worrying about ground clearances... You should also be concerned about
The axle half shafts that will be compromised by the new angles which will put more wear and tear on the CV joints... Just another consideration to keep in mind when you modify something that is designed to work a certain way..
Mikem53 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mikem53 For This Useful Post:
humfrz (01-17-2014), RFB (01-17-2014)
Old 01-17-2014, 11:02 AM   #50
RFB
RFB's Avatar
Drives: FRS
yep
In stock mode it is a very well designed car - If it ain't broke - don't fix it.
However - if it wasn't a daily driver but a dedicated track car - go all the way.
$$$$$$$$$$$$$$$$$$ for mods and breakage ! (All hobbies are expensive)
CERBERUS
The Following User Says Thank You to RFB For This Useful Post:
humfrz (01-17-2014)
How should i lower :( Obja Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 06-15-2014 12:39 PM
Looking to lower... PoWn3d_0704 Northwest 34 03-28-2014 05:43 PM
Want to lower my FR-S where can I go? laley81 Southern California 16 08-22-2013 07:05 PM
I want it lower !! Ndgreely Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-12-2013 11:10 PM
How can I go lower? nab335 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-08-2013 03:15 PM
