Old 01-15-2014, 11:03 PM   #29
Code:Red
Code:Red's Avatar
Drives: 2013 Firestorm 6MT
Originally Posted by headlikeahole View Post
I'm going to get blasted by all the coilover fanboys for this but.. If you simply want the car to ride a little lower but maintain its driving characteristics, then your best option is a decent set of springs.
Unless you are VERY in tune with your car's handling (lots of track/autox time) you likely wont have any problem with upgraded springs. Most guys with eibach pro kits or similar set ups will tell you the handling is nearly the same as stock only a bit sharper, the ride is nearly as comfortable and the drop is perfect if youre looking for a "factory" look. RCE yellows are also a good choice however the spring rates dont mimic the stock springs like eibachs do and they will change the handling a little more. I'm sure others can suggest lowering springs that mimic the stock ride as well.
Unless you are a suspension wiz, and you plan to adjust your set up often for different situations, coilovers are not justified or needed. The tuner world tends to hate on lowering springs because on most cars, they're not a good option. However the fr-s being nearly perfect in stock form works well with springs alone. Don't listen to anyone who suggests coilovers, then tells you to get the cheap set that's barely adjustable...*Cough* stupid *cough*
The best part is, its a small investment. Dont like it and you can go back to stock with little loss.
Originally Posted by eSOLOR View Post
I would just get springs with a mild drop (1 inch) and try them out for a few months. That way you can go back to stock if lowered wasn't for you without burning a whole in your wallet. If you wanna go lower/higher and care about all the adjustability then you can invest in coil overs but I think 1 inch is perfect for this car
Thank you both for saying this and in this way. This is stuff I would've liked to have said, too, but you guys took the words right outta my mouth and some. For my purpose, I'll be heading down this route.
Code:Red is offline   Reply With Quote
Old 01-15-2014, 11:31 PM   #30
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
Agreed with many here... Unless you plan on tracking the car a lot and fine tuning it (or want to slam the car), just go for springs. I have to say that adding the pro-kit to my FRS along with 18's and stickier 225's has made it grip a little better in corners and has allowed it to keep that 50/50 balance that you can control with your right foot. The grip increase is almost completely due to the tires, though. The springs really made a minimal difference. They just make it look nicer and reduce a little bit of the (already minimal) body roll. With springs it will ride a touch stiffer though. If the roads you like driving on are generally rough, I would consider staying with stock ride height.
FReSh is offline   Reply With Quote
Old 01-15-2014, 11:49 PM   #31
HD86
Drives: 2014 Raven FR-S
Originally Posted by Yellow13 View Post
Sounds like the One American center. I am in there all the time (used to work there also). Any chance I am right? lol
Nope, I would tell you which parking garage it is, but don't quite want to reveal my exact location in Austin
HD86 is offline   Reply With Quote
Old 01-16-2014, 12:24 AM   #32
Yellow13
Yellow13's Avatar
Drives: 2013 6MT Asphalt FR-S
haha I do understand. I was just taking a wild guess! I do have a few other guesses but I understand not wanting to reveal specifics about your whereabouts on an open forum haha
Yellow13 is offline   Reply With Quote
Old 01-16-2014, 12:38 AM   #33
Yep, the Feds are watching ......
Old 01-16-2014, 01:02 AM   #34
ronboogieon
BReeZy Hunter
ronboogieon's Avatar
Drives: 13 DGM BRZ Limited 6MT
So is 1 inch drop the lowest you can go without significantly scraping or can you go slightly lower?
ronboogieon is offline   Reply With Quote
Old 01-16-2014, 03:23 AM   #35
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
FYI since it hasn't been posted:
http://www.ft86club.com/forums/showthread.php?t=49511
All the posts in the thread seem to be lowered 2+ inches since you're only doing it for visuals any problems will be much less severe.
ineedyourdiddly
Old 01-16-2014, 12:20 PM   #36
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Noob question: When lowering the car ... doesn't that change the steering geometry (camber, toe-in/out, alignment) of the car? Just curious.
Braces is offline   Reply With Quote
Old 01-16-2014, 12:33 PM   #37
Yellow13
Yellow13's Avatar
Yes of course. Remember that when installing new coilovers, you should give it about a day or so to settle before getting it aligned, or else you will just have to get it aligned, again! It also never hurts to buy new controls arms, toe arms, trailing arms, etc. - There are some pretty great aftermarket products that have a wider range of motion then the factory.
I am personally about to buy some RS*R's. I am super psyched. Also going to get some AP Control Arms with it
The Following 2 Users Say Thank You to Yellow13 For This Useful Post:
Braces (01-16-2014), strat61caster (01-16-2014)
Old 01-16-2014, 06:24 PM   #38
nyfries
Drives: 14 FRS Whiteout
Thanks guys. I'm not re evaluating my mod priorities
nyfries is offline   Reply With Quote
Old 01-16-2014, 06:31 PM   #39
Ponwh
Drives: 4 wheels
I agree with @HD86 and Drive ...... the suspension is set up pretty darn good from the factory, for average driving.
Why limit where you can drive your car by making it lower ..??
How many people are going to exclaim ..... oh, that car sits awful high .. ??
Or, look at that unsightly wheel gap ... ??
As they carry 2x4s around so they can pull into their own driveway ....
If you're worrying about where you can and cant drive your car, why not just get a 4x4 truck, or a vehicle made for off-roading?
I personally think the stock height is still pretty high. Many people like to make their car stanced and show it off at car meets or shows (because it looks super sexy in their eyes). But for obviously it depends on how low you want to go.
Ponwh is offline   Reply With Quote
Old 01-16-2014, 09:05 PM   #40
jkr
jkr's Avatar
Drives: '13 frs
Lower it! I pulled the trigger on a set of ground control coilovers, which essentially make the OEM struts into coilovers giving you a ride height adjustment between 0 and 1.6" and for half the cost of a set of coil overs.
hmmm ? any more info on this ?
jkr is offline   Reply With Quote
Old 01-16-2014, 09:09 PM   #41
Luis_GT
This thread may help
http://www.ft86club.com/forums/showthread.php?t=26890
The Following User Says Thank You to Luis_GT For This Useful Post:
jkr (01-17-2014)
Old 01-16-2014, 11:09 PM   #42
Dwood11
Dwood11's Avatar
Drives: 2014 SWP BRZ LIMITED
I went to with the Hotchkis springs and sways. As well as lca's and the front camber bolts. Then I got a really aggressive alignment and could not be happier. The car is much more fun to drive, but it kept the same overall characteristics it had when stock.
Please please do some more research before you make your choice. Buying 800 dollar coilovers and dropping your car 2 inches is not the best decision if you want the car to maintain the balance and feel from the factory. Ya if you are going for looks and handling doesn't matter than by all means. I will eventually go with coilovers but I don't have an extra 3g's sitting around. So for now I can't tell you how happy I am with the cars set up.
Dwood11 is offline   Reply With Quote
How should i lower :( Obja Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 06-15-2014 12:39 PM
Looking to lower... PoWn3d_0704 Northwest 34 03-28-2014 05:43 PM
Want to lower my FR-S where can I go? laley81 Southern California 16 08-22-2013 07:05 PM
I want it lower !! Ndgreely Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-12-2013 11:10 PM
How can I go lower? nab335 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-08-2013 03:15 PM
