Old 08-22-2013, 03:41 PM   #57
OrbitalEllipses
Drives: Attitude
Kharman Ghia is a really cool car.
Old 01-01-2014, 03:23 PM   #58
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Still no confirmed fitment on the AVO kit? Oh and any issues with RHD cars for those living in AUS or JAPAN and other parts of ASIA?
liquidsky44 is offline   Reply With Quote
Old 01-16-2014, 08:51 PM   #59
xjohnx
Grip>Slip
xjohnx's Avatar
what kind of coolant are all you guys running in the robispec? stock subaru blue stuff ok?
Old 01-16-2014, 10:19 PM   #60
TemeCal
Drives: 86
Yep - stock blue stuff. In fact, Robi's mechanics try to reuse the coolant from the original radiator. Just drain it all into a clean container, fill up the Robispec cooler with it, then top it off.
I actually use the blue stuff in my supercharger intercooler as well, just to keep them all using the same fluid.
TemeCal is offline   Reply With Quote
Old 01-16-2014, 10:53 PM   #61
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I have the AVO kit and Robispec Radiator/Oil Cooler and it will fit. I think I had better luck than @Sportsguy83 but it is a tight fitment.
Not sure about issues with RHD cars.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 01-16-2014, 11:02 PM   #62
mike the snake
I'm wondering if anyone is running this radiator with a turbo kit?
It's thicker than the stock radiator, and with my FB turbo kit, the thicker radiator pushes the fans back and there's only maybe 1mm of clearance between the FB fans and the downtube and header up-tube.
My car's being tuned presently, and we're seeing coolant temps of 220 and they haven't even done any full throttle pulls yet. I'm hoping I don't have heat issues when I finally get the car back.
The Robispec system is really nice, quality looks awesome, but I'm having to deal with these issues. I have work to do when I get my car back. Lots of heat wrap and heat shielding to install.
Even with these issues, the Robispec radiator seems to be one of the best available.
Old 01-16-2014, 11:09 PM   #63
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
See the post right above you
Old 01-17-2014, 07:31 AM   #64
mike the snake
Sorry, I should have said "top mount turbo kit" like Full Blown, FA20club, or P&L.
Old 01-17-2014, 07:32 AM   #65
Sportsguy83
Drives: Limited BRZ
I know there are people running it, but can't remember exactly who.
Old 01-17-2014, 03:18 PM   #66
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks!
Any idea how much total coolant it holds? I'm likely going to put fresh stuff in but I want to make sure I buy enough.
Old 01-17-2014, 03:35 PM   #67
TemeCal
Drives: 86
Thanks!
Sorry - I don't recall. Hopefully someone else can chime in.
Old 01-17-2014, 10:33 PM   #68
Draco_PR23
Fiebru
Draco_PR23's Avatar
My only issues are that I might need to modify the support if I want to use a CAI (ex. Perrin) for the kit and that the oil cooler fittings are really really close to the frame.
About the temps, well my coolant temps are around ~190 and I saw ~220 when I was doing some datalogs, keep in mind that I live in PR. It is odd that you seeing those temps without any full throttle.
Current Cars:
Old 01-17-2014, 10:38 PM   #69
Draco_PR23
Fiebru
Draco_PR23's Avatar
Thanks!
Not sure, but I re-used my existing coolant plus added like halve of a new one. I don't know the capacity of the OEM radiator.
Current Cars:
Old 01-17-2014, 10:46 PM   #70
xjohnx
Grip>Slip
xjohnx's Avatar
Stock is 1.9 gallons, so I should be fine, thanks!
Picked up 3 gallons today and have another 3/4 at home already. The innovate IC needs a little over 1/2 gallon. Yay new toys.
Robispec TIME ATTACK Build robispec Tracking / Autocross / HPDE / Drifting 254 11-18-2014 04:27 AM
Robispec Suspension Installed: A Review sw20kosh Tracking / Autocross / HPDE / Drifting 57 08-17-2013 01:12 PM
Koyo Radiator vs Oil Cooler Captain Snooze Engine, Exhaust, Transmission 54 06-21-2013 11:18 PM
Shout out to Robispec sw20kosh Southern California 2 05-22-2013 03:44 AM
ROBISPEC@ FT-86 CUP GARAGE #1 Buttonwillow robispec Tracking / Autocross / HPDE / Drifting 7 02-20-2013 10:11 PM
