Old 01-16-2014, 08:11 PM   #29
JS + BRZ
Drives: 2010 MS3
Originally Posted by Rayme View Post
Do you have a friend who's good with electronics? There has to be a way to bridge some wires from inside the cluster itself so it's always backlit whenever it's powered on. It's quite easy to remove and with a multimeter, should be easy to spot which lead to tap into. Very simple project.
That is exactly what I need. Some type of DIY for this.
Old 01-16-2014, 08:14 PM   #30
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by Marchy View Post
it wasn't a law in Ontario or Washington state, which are the two places i've had to take a written drivers test.
Yes, I suppose I can only speak for CA... now I'm doubting myself on whether it was even a question on the test or just something the instructor mentioned...
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 01-16-2014, 09:07 PM   #31
Gunman
Drives: 2019 Mazda Miata RF
Techstream can adjust the sensitivity of the "auto" feature from what I've been told, but in this case, why not just cover the light sensor, so it thinks it's night all the time?
Old 01-16-2014, 09:42 PM   #32
JS + BRZ
Drives: 2010 MS3
You sir.. are genius.
Where's that sensor again? Is it the one connected to rearview mirror?
The Following User Says Thank You to JS + BRZ For This Useful Post:
Gunman (01-16-2014)
Old 01-16-2014, 10:01 PM   #33
chas3wba0
chas3wba0's Avatar
Drives: Yes
I've seen a little dot on the dash, driver's side near the windshield defroster vents (similar to the light sensors on the front of smartphones). That might be it
The Following User Says Thank You to chas3wba0 For This Useful Post:
JS + BRZ (01-17-2014)
Old 01-16-2014, 10:05 PM   #34
Gunman
Yeah, that's why I should get paid the big bucks...
One of the round dots near the front windscreen, a piece of cardboard should help you narrow it down.
The Following User Says Thank You to Gunman For This Useful Post:
Old 01-17-2014, 01:16 PM   #35
JS + BRZ
Drives: 2010 MS3
Will check it out today. I think I know what you guys are talking about.
why not just turn your lights on everytime you drive then,
If I put it on "ON", the car keeps everything on if when I lock the car.
"AUTO" shuts off itself.
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 10:56 PM
F/S: FR-S instrument cluster MissDeb Audio/Visual, Electronics, Infotainment, NAV 5 04-08-2014 05:02 PM
Cluster dome <---you need this! sav AFRICA 29 04-26-2013 05:38 AM
BRZ cluster on FRS? Shipwreck Electronics | Audio | NAV | Infotainment 6 03-07-2013 12:09 PM
WTB: FRS instrument cluster jabbajaw99 Interior Parts (Incl. Lighting) 3 02-14-2013 02:31 PM
