Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 01-14-2014, 06:35 AM   #15
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Originally Posted by GeeTee86 View Post
I'm very annoyed that yours work just with relay
Me too. VERY ANNOYED.
If they didn't want us to have DRL for whatever reason they could have left the relay out. Removing a wire is silly.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 01-14-2014, 11:28 PM   #16
Moe
Moe's Avatar
Drives: Lexus IS250, Toyota 86
Confirmed: DRL works on my car after the relay is installed
I put the horn relay back and swapped with the rear fog relay (identical part), as I rarely use rear fogs. Also the Valenti lights are quite bright on normal park settings, so no real need for rear fogs. Will however still need to find a relay one of these days and put it back - but not urgent any more.
So, if you want to experiment, you can also use the relay from "RR Fog" instead of the horn one.
Also checked all my lights, including brake lights, brights, etc and everything else seems to work (beside the rear fog obviously).
Moe is offline   Reply With Quote
Old 01-16-2014, 12:24 AM   #17
sav
sav's Avatar
That's great news! This should then work for all the new High specs that came stock with the rear spoiler. Won't work on the ones before that.
95RON SAV Tuned
Old 01-16-2014, 02:24 AM   #18
Shadeslayer
Shur'tugal
Shadeslayer's Avatar
Drives: Toyota 86 Galaxy Blue Silica
Hi vladror, I've just PM'ed you my numbers, please help me join cpt whatsapp group.
Don't judge a man until you've driven a mile in his 86.
Shadeslayer is offline   Reply With Quote
Old 01-16-2014, 02:47 AM   #19
Shadeslayer
Shur'tugal
Really?...Darn it!
Old 01-16-2014, 02:57 AM   #20
Moe
Moe's Avatar
Originally Posted by Shadeslayer View Post
Really?...Darn it!
Easiest way to check is to swap your relay from the fog to DRLs - takes 30seconds to confirm if your car has them pre-wired.
Old 01-16-2014, 06:26 AM   #21
sav
sav's Avatar
Yep. Just to clarify - all high spec vehicles are pre-wired for DRL, the problem is with the headlight itself(one pin missing).
95RON SAV Tuned
Old 01-16-2014, 06:45 AM   #22
Sporran
Drives: Metallic Grey 86
I checked mine this morning and it looks like I have eight wires into the headlight so I thought I'd swap over the relays to see. Couldn't get the rear fog to fit into the DRL relay slot because of the little protrusion on the body of the relay itself which fouls on the plastic and prevents the relay from being inserted. Is this unique to mine??
Sporran is offline   Reply With Quote
Old 01-16-2014, 06:50 AM   #23
sav
sav's Avatar
Not sure, just use the horn relay. They're the same.
Is yours a "new" High spec with the BRZ style boot spoiler? When looking at the wiring it's got 8 wires from the harness side but if you unclip the headlight's plug you'll see 7 or 8 on the headlight side.
95RON SAV Tuned
Old 01-16-2014, 09:50 AM   #24
Sporran
Mine is the older Hi-Spec. I removed the headlight plug and it turns out I only have six connectors on the headlight side itself, so not going to get the DRL's to work no matter what I do with the relays. Just out of curiosity I tried the horn relay and it's the same - the plastic protrusion won't allow it to fit into the DRL relay slot in my particular fusebox.
Oh well, next challenge is to try to source one of those centre armrests with the opening lid - my local Toyota dealer say it's an invalid part number.
Old 01-16-2014, 10:18 AM   #25
sav
sav's Avatar
Damn! Weird that you've only got 6 wires though. The horn relay isn't a perfect fit but I got it in. You can hear it clicking when DRL supposed to switch on and off but obviously the power is going nowhere.
95RON SAV Tuned
Old 01-16-2014, 11:29 AM   #26
Vladror
Vladror's Avatar
Drives: Toyota 86 M High - Dark Grey
i got mine via @Ryan86
Vladror is offline   Reply With Quote
Old 01-19-2014, 06:50 AM   #27
keymaster
Drives: Pearl/Satin White 86 High 6MT 2014
Whoa! Hold on...I'm very new to this car, was also wondering why there isn't DRL.
I got my 86 last week Saturday.
So it would be great if someone can post a picture on the wires and how to "relay" it.
I have the new High-Spec model.
Thanks
keymaster is offline   Reply With Quote
Old 01-20-2014, 12:11 AM   #28
sav
sav's Avatar
Hi
Congrats on the new car. No pic needed, just check the relay locations on the back of the fusebox cover in the engine and pull the horn relay out and fit it in the DRL relay's empty slot.
95RON SAV Tuned
TRD kit questions Tofu driver's Fr-s Cosmetic Modification (Interior/Exterior/Lighting) 28 07-30-2013 03:04 AM
HKS SC questions... Shit Luck Forced Induction 2 07-22-2013 10:30 AM
Sub + Amp Questions itdansharpe Electronics | Audio | NAV | Infotainment 29 07-08-2013 12:42 PM
HID / LED questions RealShkillz Cosmetic Modification (Interior/Exterior/Lighting) 7 06-01-2013 05:15 AM
Questions about CEL DarkSunrise Issues | Warranty | Recalls / TSB 7 08-31-2012 12:42 PM
