Old 01-13-2014, 07:39 PM   #15
OrbitalEllipses
Drives: Attitude
It's a flat engine, it *will* have oil starvation issues in high-g lateral loading.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
PoorMansRacing (01-28-2014), ZionsWrath (01-14-2014)
Old 01-13-2014, 08:11 PM   #16
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Dipstik-sportech View Post
I was always under the assumption that being that it's mostly gravity that returns the oil it the pan from the turbo you want as straight a shot as possible. If you extended the drain below the oil level will it not cause the oil to back up and cause the turbo seals to leak ?
Sent from, The Frozen North
I'm not completely sure, but in hudraulics the oil in the pan and the drain are both at atmospheric pressure. Following that, as long as the turbo is mounted above the drain that shouldn't be an issue.
The Following User Says Thank You to Calum For This Useful Post:
Old 01-13-2014, 08:39 PM   #17
diss7
Drives: AE86, 2x GT86, TE27
Is this an issue with this car? I have not read too many threads of people with oil pressure gauges fitted. I don't have a gauge fitted and run slicks (Kumho V710) at track days so I would be interested to know.
Yes a couple of us in NZ have experienced it. I've stopped circuit racing mine until a solution is found
The TR86 race cars had the same problem during development. TRNZ developed a few prototypes before coming up with a pan and pickup modification. THey're going to release it to the market soon.
I'm trying to decide whether to get that, or do a drysump.
Buddy of mine has his own fab business, and wants to do a whole drysump/subframe setup for me, then offer it to the market.
Heres a pic of his own setup for his sti drift car.
diss7 is offline   Reply With Quote
The Following 3 Users Say Thank You to diss7 For This Useful Post:
Captain Snooze (01-13-2014), Dipstik-sportech (01-13-2014), ZionsWrath (01-14-2014)
Old 01-14-2014, 12:08 PM   #18
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Originally Posted by bakerr6 View Post
I've been happy with your suspension parts. PM me when you get this finished as an idea of what you are thinking froma cost perspective. Also, what coating options are you planning on going?
Thanks!! At present no plan for coating options, as far as price we are looking to release the pan at $350 to $300, of course only time will tell when the pan(s) is/are complete.
Originally Posted by normancw View Post
@racerx1715
Any plans for a baffle to reduce oil starvation on high speed turns?
Currently in process, we are investigating several baffle plates right now to decide on a design that we think is appropriate for the platform.
Jeff@Racer X Fab is offline   Reply With Quote
The Following 6 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
B L U E S L A T E (01-28-2014), bakerr6 (01-14-2014), Calum (01-14-2014), normancw (01-14-2014), The Slow One (01-14-2014), ZionsWrath (01-14-2014)
Old 01-14-2014, 12:17 PM   #19
bakerr6
Drives: 2013 raven black fr-s
Send me a pm when you get this finished. If it's around that area, go ahead and send me an invoice while you are at it lol.
bakerr6 is offline   Reply With Quote
The Following User Says Thank You to bakerr6 For This Useful Post:
Old 01-14-2014, 12:23 PM   #20
OrbitalEllipses
Drives: Attitude
Subaru dry sump setups are mad money - even on NASIOC you rarely ever hear about it because it costs over ~$5K USD to do properly AND the parts development is mum/hush-hush/all custom. Typically race car only stuff.
Old 01-14-2014, 12:32 PM   #21
The Slow One
Track Junkie
Drives: Argento Scion FR-S
I'm very interested in this, a baffle would be nice
The Slow One is offline   Reply With Quote
Old 01-14-2014, 02:41 PM   #22
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Would someone be so kind as to tell me what these two holes are for?
Old 01-14-2014, 03:37 PM   #23
Jeff@Racer X Fab
Sure, these are the oil return ports that fit to the upper pan. In that picture you do not see the drain tubes.
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
Captain Snooze (01-14-2014)
Old 01-14-2014, 04:46 PM   #24
diss7
You're right. Just look at the parts, before any custom work is done. Pump, good fitting and lines, tank, there's $3k right there.
Old 01-27-2014, 09:30 AM   #25
Jeff@Racer X Fab
Oil pan update
Looks like we are wrapping up a final design, and have built a few prototypes that we were not happy with. This oil pan will work with the OEM manifold, and should be compatible with aftermarket exhaust manifolds. We will offer an incentive once the final product is released for those that are interested.
The final design resembles the OEM pan with a few exceptions. Increased capacity, turbo oil drain port (can be plugged), baffle plate that captures oil by the pick up, and uses an o-ring seal on the flange.
Here are a few pictures of the design. I will post up the actual pan hopefully later today.
The Following 4 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
86drift (03-09-2014), Brzzee (01-30-2014), normancw (02-09-2014), The Slow One (01-27-2014)
Old 01-28-2014, 11:06 AM   #26
Jeff@Racer X Fab
Few pics of the pan in process of being built.
Old 01-28-2014, 12:49 PM   #27
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I would love to run a larger oil pan, but my class in the SCCA doesn't allow for a modified windage tray or pickup. I'm assuming yours has a new windage tray
Ranatsu is offline   Reply With Quote
Old 01-28-2014, 01:53 PM   #28
Malt
Drives: 2015 WRX
How much further down does this extend compared to the stock oil pan?
Malt is offline   Reply With Quote
Racer X Fabrication air intake design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 45 08-01-2019 12:29 PM
Racer X Fabrication suspension parts, and development Jeff@Racer X Fab Suspension | Chassis | Brakes -- Sponsored by 949 Racing 134 09-01-2016 05:02 AM
Racer X Fabrication Suspension group buy: UCA, Rear LCA, Front LCA and more!! Jeff@Racer X Fab Groupbuys 74 06-23-2014 09:08 AM
Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! Jeff@Racer X Fab Brakes, Suspension, Chassis 25 01-24-2014 11:42 AM
Racer X Fabrication, New vendor intro Jeff@Racer X Fab Announcements, Contests, Giveaways 0 03-12-2013 11:50 AM
