Old 12-19-2013, 12:15 PM   #29
mrazny
Drives: BMW 135i, soon to BRZ
Originally Posted by Eric1855 View Post
AKA protect the grumpy old guys
It's a touch more involved than that. It's the new car dominates, grumpy old guys flee the class, not all that many other also build said new dominating car...
Worst case scenario, the car is already faster in year 1 from 2 builds, 14 drivers ditch the class, now there are 8 drivers from 3 twins and the one RX-8 that still thinks it can develop more.
The Grumpy old men may be grumpy, and occasionally irrational, but there is also what faith there can be in National Twin SP builds. We have quite a few "class it and they will come" classes. SP as a whole is down. It's a s@*t situation.
mrazny is offline   Reply With Quote
Old 01-02-2014, 08:00 PM   #30
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
No offense to the veterans but the whole rules system is setup that way.
Engine safety stuff is in sp or sm.
Drive shaft should be in STX.
Electric fans? Really
Stuff from the cars own tuning division putting you out of STX.
* opinion from several people who DD their cars and lightly mod them.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 01-04-2014, 05:17 PM   #31
Robbie
In the slipstream
No way should they allow lightened driveshafts in STX. That's a high cost item that would be seen as a have to have mod and would drive the cost of being competitive up. Plus it would be an allowance that a FWD car could not get the same benefit from. Lightened flywheels and clutches aren't allowed in STX so why should a driveshaft be different?
As far as STi parts kicking you out of STX; those rules exist because if said parts were allowed, they would make the car more unstreetable or open up an allowance that people would be custom building parts for maximum advantage.
If you want to be competitive in a Solo class, build to those rules. If you want to mod your car however you want, do it and base your "competitiveness" on whatever class you want.
Robbie is offline   Reply With Quote
Old 01-04-2014, 06:04 PM   #32
StormTrooper
Aluminium DS is $450. Considerably cheaper than say light weight seats.
I'm talking about aero parts specifically. For instance BRZ is the same car as FRS. BRZ can run wing but not the TRD one FRS can use neither.
Also FWD really have no Drivetrain loss to speak of like RWD and AWD .
GR86 MT premium
Old 01-06-2014, 02:44 PM   #33
mrazny
Your angle creeps into the "I" class type of thinking. The class has allowances, so how the mod affects *other* cars is also on the table. A Driveshaft for you and your car is not a drive shaft for a BMW, RX-8, etc. If you assume the rules have things stable today, and the Twin is equal to the ITR, your Driveshaft allowance improves your Twin while it can't improve the ITR.
The actual reason for limiting "tuner" division things is also because no two tuners are equal across car companies. Dealer-installed is a part that mucks up a lot as well. There are dealerships that have "tuner" specials with parts beyond that manufacturer's tuner division.
What the SCCA cares about (and should continue to care about) is how the cars compete based on the rules in place. A new rule should only foster a more equitable competition amongst the cars in the class, and mods that increase the cost to compete should be scrutinized severely.
Old 01-13-2014, 01:09 PM   #34
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Does anyone know if upgrading the OEM driveshaft to a solid aluminium driveshaft is allowable in SP?
PoorMansRacing is offline   Reply With Quote
Old 01-13-2014, 06:13 PM   #35
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
nope....not legal... if you change it out...it goes to SM.. or some other Prepared class..not Street Prepared..
Bill
Scooby South is offline   Reply With Quote
Old 01-13-2014, 06:16 PM   #36
mrazny
"Driveshaft" appears 19 times in the rules, replacement along with driveshaft doesn't happen until Prepared. The Update/Backdate rules are what some cars are utilizing when they do any Driveshaft changes, but obviously at that point we're still talking OEM or OEM-spec aftermarket for older out of production driveshafts.
Old 01-13-2014, 06:22 PM   #37
mrazny
Bill
SM is probably the ticket like Bill said. "D. Drivetrain and related components (induction, ignition, fuel systems,
etc.) are unrestricted except for the following limitations:", and none of the following paragraphs talk about driveshafts. Though Prepared allows for clearancing for fitment, and SM does not allow for much significant modification for that purpose.
Strange though that SM seems to imply you can change transmissions too. No "trans" specific language to limit that unrestricted drivetrain... Never thought about that part of the ruleset...
Bill, I'm glad you're staying with STX, but I'd love to see your version of an SM twin
Old 01-13-2014, 06:48 PM   #38
Scooby South
Conedancer
If, in fact, I ever went SM..it would involve a twin-scroll, flares... and 315 A6's...
Bill
Old 01-13-2014, 08:01 PM   #39
Eric1855
Drives: LP DSP / CSP '13 BRZ
Bill
That with e85, lots of weight removal and spiffy CF parts is what I would like to do...but it probably still wouldn't be competitive against the monsters SM brings out these days.
Eric1855 is offline   Reply With Quote
Old 01-13-2014, 08:36 PM   #40
Scooby South
Conedancer
^^^^ and this tooo
Old 01-14-2014, 12:16 PM   #41
mrazny
^^^^ and this tooo
Min weight is 2480 if you keep things at 51% rear or less, and 2565 if you go over 51% rear. Panda was in the mid 2600's, not sure if that's still the case.
A 2480 at a perfect 51% sounds like a good recipe. It also sounds better than CSP
Mercedes A class AMG v BRZ? Suberman FR-S / BRZ vs.... 20 09-24-2013 02:37 PM
Proposal for CDC FT-86 Class Areddi Mid-Atlantic 37 05-11-2013 06:59 AM
FRS No class? WTF ggpaul Scion FR-S / Toyota 86 GT86 General Forum 135 01-15-2013 12:07 PM
Anyone for a class? Fuzzysmith Northwest 21 08-13-2012 12:02 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
