Old 01-13-2014, 04:36 PM   #2633
olorin
olorin's Avatar
Drives: GBS Premium
Originally Posted by swift996 View Post
For anyone running a oil catch can:
Would you just put it between the line then enters the plastic intake pipe before the throttle body?
For a dual catch can setup it would be that plus the breather line in the back of the SC. Meaning one can between each line. I think if you were only running one you would do the breather line in the back but with FI dual catch cans would be best.
olorin is offline   Reply With Quote
The Following User Says Thank You to olorin For This Useful Post:
Calum (01-13-2014)
Old 01-13-2014, 04:41 PM   #2634
sw20kosh
Drives: 2013 Black FR-S
The one that really spews oil into the intake track is the PCV breather line that empties into the back of the supercharger. That is the line I would run a catch can on. I checked the other line you are referring to many times to find very very little oil there.
Dual catch would be best of course. You could always run both lines to the same catch and then vent it to air. Actually I wonder if you could plump both lines to a catch can and then plumb that to the nipple at the back of the supercharger. Is it ok if both breather hoses receive vac?
Old 01-13-2014, 04:57 PM   #2635
swift996
swift996's Avatar
That's the line coming off the crankcase going into the supercharger? It's been a while since I've looked but will be going the intercooler upgrade soon so thought it might be a good time to do a catch can too.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
sw20kosh (01-13-2014)
Old 01-13-2014, 05:16 PM   #2636
olorin
olorin's Avatar
Drives: GBS Premium
Yes, the real short one in the back of the SC
The Following 2 Users Say Thank You to olorin For This Useful Post:
sw20kosh (01-13-2014), swift996 (01-13-2014)
Old 01-13-2014, 05:37 PM   #2637
Calum
That Guy
Drives: 2013 asphalt FRS MT
With FI you'll want an air/oil separator between the block and the intake manifold, and another between the block and the intake pipe.
Old 01-13-2014, 05:57 PM   #2638
CSG Mike
CSG Mike's Avatar
Does a one way check valve not work for Innovate owners?
Old 01-13-2014, 06:00 PM   #2639
sw20kosh
Context?
Old 01-13-2014, 06:02 PM   #2640
CSG Mike
CSG Mike's Avatar
Context?
Instead of a catch can air/oil separater.
Old 01-13-2014, 06:29 PM   #2641
sw20kosh
Still confused about how you would do this. Never heard of this being done in place of a can.
So you would place a check valve in the lines and point them down to the ground? Oil/vapor would be able to escape out of the lines but nothing would be able to enter?
Old 01-13-2014, 06:34 PM   #2642
CSG Mike
CSG Mike's Avatar
More the other way around. They wouldn't be able to escape, but air can go back in when there's vaccuum...
Unless I'm misunderstanding the intent here.
Old 01-13-2014, 06:44 PM   #2643
sw20kosh
What is your intent?
We are concerned with the oil that is being spit into the supercharger plenum/intake tract from the PCV/breather.
A solution is to put a can in-line so that the oil never makes it to the intake tract.
Old 01-13-2014, 06:49 PM   #2644
CSG Mike
CSG Mike's Avatar
My solution would be to use a check valve to prevent the air/oil mixture from reaching the supercharger via the PCV/breather.
Old 01-13-2014, 07:01 PM   #2645
chutrain
chutrain's Avatar
Drives: WRB BRZ
I have seen this being used in other applications before. And generally will be a cheaper solution than a catch can. Worth researching and seeing if it works.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 01-13-2014, 07:14 PM   #2646
CSG Mike
CSG Mike's Avatar
It's what we're using... (it's included in the kit that we have on our car)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
