Old 01-05-2014, 08:02 PM   #295
grannyshifter25
Drives: Subaru BRZ
Originally Posted by kosoku View Post
heres mine, still need to find some tires for track season.
Untitled by sektor 11
I wanted to do something different
nice, post more pics once it gets mounted. what color is it exactly btw?
grannyshifter25 is offline   Reply With Quote
Old 01-06-2014, 03:38 PM   #296
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Has anyone weighed these 17x9et35 wheels with 225/45, 235/45 and/or 245/40 tires mounted?? ...I am really curious much they weigh compared to the stock 41.4lbs oem wheel/tire combo.
fooddude is offline   Reply With Quote
Old 01-09-2014, 04:06 PM   #297
himbo
Drives: Lightening Red BRZ Ltd.
Originally Posted by fooddude View Post
Has anyone weighed these 17x9et35 wheels with 225/45 and/or 235/40 tires mounted?? ...I am really curious much they weigh compared to the stock 41.4lbs oem wheel/tire combo.
Bump!
himbo is offline   Reply With Quote
Old 01-10-2014, 02:32 AM   #298
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
I don't remember the exact number but these wheels with 245/40 tires mounted weigh 1-2 lbs less than OEM, so the other two would weigh a bit less than that. With 255/40 they weigh 42.4 lbs.
eSOLOR is offline   Reply With Quote
Old 01-10-2014, 07:52 AM   #299
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by himbo View Post
Bump!
Mine with 215/45 Federal tires(which run a bit wide) came in at just at 37lbs per.
So, I imagine a 225 and 235 width would probably land between 37lbs and 40lbs per corner.
Some tire manufacture websites also include weight. Just take what you find and add 16.4lbs to that and you should have a pretty accurate number.
Old 01-10-2014, 12:53 PM   #300
fooddude
Thanks. Did some calculations of my 2 most inticing wheels I'm interested in so far + PSS's:
OEM Stock = 41.4lbs
RPF1 = 16.4lbs
PSS + RPF1:
225/45 = 22.8lb = 39.2lb (-2.2lb weight reduction)
245/40 = 23.1lb = 39.5lb (-1.6lb)
57DR = 20.2lbs
PSS + 57DR:
225/45 = 22.8lb = 43lb (+1.6lb weight gain)
245/40 = 23.1lb = 43.3lb (+1.9lb)
I really love the look of the 57DR much more than the RPF1's (and they're affordable as well)...but dang, 2lbs heavier per wheel doesn't sound that nice.
Old 01-12-2014, 10:22 PM   #301
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
@whataboutbob
How much camber would you need to ensure the whole wheel was under the guard in the front?
& if you did add that much camber how much room is left on the tire and the strut?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-12-2014, 11:27 PM   #302
whataboutbob
AutoX-10/10ths every run
Originally Posted by DriftEightSix View Post
@whataboutbob
I was running -2.75 deg neg. There was about 1/4 in clearance between the tire/wheel and the lower spring perch. I've had NO contact issues even when autoxing. This was with the Whiteline camber bolts, COMCs, and RCE Yellows.
Build thread:Here
Old 01-14-2014, 11:26 PM   #303
jaydee_do_work
jaydee_do_work's Avatar
Drives: 13' Whiteout FR-S
Originally Posted by Aznsky View Post
Any whiteout owners have gold rpf1's? Want to see how they look before I pull the trigger
I just put mine on.
jaydee_do_work is offline   Reply With Quote
Old 01-14-2014, 11:28 PM   #304
fooddude
@Jaydee: Ill! Tiresize?
Old 01-16-2014, 09:33 PM   #305
DriftEightSix
Pegasus White
Drives: 86
Originally Posted by jaydee_do_work View Post
I just put mine on.
wow they look very sunk in for 9 +35.
Well done, not sure im sold on the white and gold combo though.
Old 01-17-2014, 06:20 AM   #306
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Mine on stock suspension, coilovers are going in next sat.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 01-18-2014, 07:58 AM   #307
DriftEightSix
Pegasus White
Drives: 86
what you using for the front wheel camber
Old 01-18-2014, 10:22 PM   #308
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
have you still not decided on wheels?!
86•BRZ is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
