Old 01-12-2014, 02:43 PM   #2619
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Where are you guys ordering the bearings from?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 01-12-2014, 03:58 PM   #2620
TemeCal
Drives: 86
whataboutbob posted the link a few pages back. Here's what he says to order:
[ame="http://www.amazon.com/Ntn-6203LU-Single-Ball-Bearing/dp/B005BN2BDK"]Ntn 6203LU Single Row Ball Bearing: Amazon.com: Industrial & Scientific[/ame]
TemeCal is offline   Reply With Quote
Old 01-12-2014, 05:04 PM   #2621
wrxgoose
WUB WUB
Drives: 2013 Firestorm
okay, so i had posted a while back about getting a custom intake made, and that plan has fallen through. Went over to the fabber's shop earlier today, and unless we cut some of the frame, there's no way to get a 3" pipe down to where i wanted. SO! we've come up with a different idea. an aluminum pipe to where the stock intake is, but with a place for the MAF, so that we can use aftermarket intakes.
any interest? I know people are gonna want to see results of this after the fact, and i plan on doing this reguardless, but do y'all want updates on this or no?
also, he make try to custom fabricate some new UEL headers for me, so they're not right under the intake piping. but we don't know if that'll work yet, since we gotta get my car on the lift to see what he can do.
wrxgoose is offline   Reply With Quote
Old 01-12-2014, 06:12 PM   #2622
xxscaxx
Drives: 2013 SWP BRZ
i'd be interested pending feedback and seeing it on yours.
Tips for anyone purchasing the IC kit and already have the SC installed:
If you want to keep the manifold bolted down and just remove the sc unit, Pull off the back elbow that connects to the throttle body first. Those bolts in the back are a PITA to get to with it in the way.
Its really easy to take those three bottom bolts off of the elbow with an extended Allen key with the ball on the end as it allows you to tighten/loosen on a slight angle.
I have the charger off and just waiting now for the re-delivery tomorrow night. Figured i'd pull everything off to make the install process a little faster.
Also, Radium can't release their catch can kit fast enough for the twins. I had a a bunch of blow by oil in the back of the unit when I took the elbow off, and I just had it off not that long ago to replace those fittings. Was also a small light coating on the actual manifold under the charger.
xxscaxx is offline   Reply With Quote
Old 01-12-2014, 06:57 PM   #2623
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Radium stated on their FB page the catch can system will release for sale within next few weeks BTW..
Old 01-12-2014, 07:52 PM   #2624
xxscaxx
I know they did, hence my mentioning of them lol.
The Following User Says Thank You to xxscaxx For This Useful Post:
OICU812 (01-12-2014)
Old 01-12-2014, 08:02 PM   #2625
OICU812
Just a dude
OICU812's Avatar
I'm waiting to they make great stuff!!
Old 01-12-2014, 08:05 PM   #2626
xxscaxx
Yeah me too, thats why i'm waiting. Just hoping they put them in a good spot for their specific kit, or i will end up waiting for nothing.. lol. I know it will be a dual can setup.
Old 01-12-2014, 09:21 PM   #2627
TemeCal
Drives: 86
@whataboutbob -
I had the guy from Locate Bearings call me, after I placed the order. Apparently the 6203LU only has a seal on one side. He called to confirm this was really what I wanted. I guess the 6203LLU has seals on BOTH sides of the bearings.
Do you recall if the bearing has seals on BOTH sides? If it does, the part number is 6203LLU. He is sending me the 6203LLU, because I can remove one of the seals if necessary.
I actually bought from eBay (pretty sure it's the same company), because I noticed they were in Palm Desert.
http://www.ebay.com/itm/6203LU-NTN-N...item1e84ae6426
Their phone number, if anyone is interested, is 800-409-3632
Old 01-12-2014, 11:25 PM   #2628
whataboutbob
AutoX-10/10ths every run
@whataboutbob -
Mine had seals on both sides.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
TemeCal (01-12-2014)
Old 01-13-2014, 04:48 AM   #2629
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Kit all working, tested under load seals held tight.
With the BG belt you can certainly hear the noise from the idle pulley.
Going to be interesting what figures I'll get now with a fixed kit as previous dyno I got
250whp 206ftlb with it leaking coolant and a dead coil pack.
75mm 11psi boost.
[ame="http://vimeo.com/84022479"]Sprintex GT86 on Vimeo[/ame]
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
xjohnx (01-13-2014)
Old 01-13-2014, 09:14 AM   #2630
xxscaxx
75mm 11psi boost.
glad you got it all sorted out. What strut bar is that?
My kit is coming tonight, if it gets delayed again UPS is going to have a big problem
Old 01-13-2014, 09:33 AM   #2631
Ryan86
Road Warrior
Ryan86's Avatar
It's the Tanabe tower brace.
It does not fit with the coolant bottle hence one of the reasons I relocated the coolant bottle as I was not going to waste money purchasing a new brace.
The 2 braces I know fit with the bottle on the kit are the Cusco and Megan.
Hope your kit arrives.
Ordered the Raceseng 72.5 and 70mm pulleys to see what extra gains are obtained by each pulley for R&D purposes, but I will stay on 75mm as 11-12 psi 250whp is plenty fun.
xxscaxx (01-13-2014)
Old 01-13-2014, 03:39 PM   #2632
swift996
swift996's Avatar
For anyone running a oil catch can:
Would you just put it between the line then enters the plastic intake pipe before the throttle body?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
