Old 01-12-2014, 12:45 PM   #43
xlid007
Drives: Scion FRS
Originally Posted by BlueDubbinTDI View Post
I got mine lowered on RSR super downs yesterday and although I've only driven about 20 miles on them I must say they feel pretty much exactly like stock just Id say it rides like 2-2.5 fingers lower than before. We'll see if they settle further but I really couldn't be happier. Will post pics when I get my 18" XXR 530s mounted this week.
Did you have to get them cambered or did you just get an alignment?
xlid007 is offline   Reply With Quote
Old 01-12-2014, 02:32 PM   #44
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Both. 1.3 front 2.3 back
Old 01-12-2014, 02:58 PM   #45
xlid007
Drives: Scion FRS
Is this with oem components, or did you have to buy camber bolts and rear lca's?
Old 01-12-2014, 05:37 PM   #46
BlueDubbinTDI
I bought front crash bolts that changed it from 1.1 to 1.3 which is still in spec. My rears are actually 1.9 and 2.3 without LCAs. The 2.3 is technically out of oem spec but since the toe is basically 0 all was well. The alignment sheet was all green after the alignment except the 2.3 which was on the rear right I believe.
Old 01-12-2014, 06:10 PM   #47
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
common issue with right rear having more camber than left rear. Mine was a whole degree more negative on that side with a mild drop so i had to buy the SPC lower control arms.
Old 01-12-2014, 06:37 PM   #48
BlueDubbinTDI
Guess I should consider myself lucky then. Actually didn't get to drive it at all today which sucks!
Old 01-13-2014, 01:33 PM   #49
SurfAndSand
8SiX
Drives: FRS 10series
I'm running the RSR super downs too. I love em. I can't compare to Swifts, because I've never ridden on those either, but in the RSRs you are noticeably lower, and the ride is still comfortable, but you are losing about an inch of shock travel.
SurfAndSand is offline   Reply With Quote
Old 02-07-2014, 11:12 PM   #50
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
Do you need an alignment after dropping on the RS-R Super Downs?
kayoh is offline   Reply With Quote
Old 03-06-2014, 09:38 AM   #51
VuDism
NASIOC: AzNSTiImpreza
VuDism's Avatar
correct me if im wrong fellas... but any time you install springs, any springs... even replacement stock springs... you need to do an alignment. The process of installation throws off alignment i believe.
FYI- I also got RSR- S Down springs and waiting to get installed
VuDism is offline   Reply With Quote
Old 03-06-2014, 11:25 AM   #52
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
yes.
the install process doesnt necessarily throw off the alignment, the components being installed do
supramkivtt2jz is offline   Reply With Quote
Old 03-06-2014, 11:30 AM   #53
BlueDubbinTDI
I'm adding 5mm spacers to the rear and getting my rear knocking inspected at the same time on Saturday so I'll report our findings after.
Old 03-20-2014, 01:23 AM   #54
newports
Drives: 2013 Scion FRS
update on spacer?
newports is offline   Reply With Quote
Old 03-20-2014, 09:12 AM   #55
BlueDubbinTDI
Originally Posted by newports View Post
update on spacer?
See my build thread
Old 03-20-2014, 12:09 PM   #56
FR-Slide
Drives: 13 Whiteout 6MT
Still on stock wheels for now, but was debating adding some spacers in the rear as well just to get them a bit less tucked. You mentioned your 5mm ones are not hubcentric; is there a brand/size/type that IS? Is there a recommended size/limit for still using stock wheels/lugs? I was looking at something in the 5-10mm range, nothing huge.
FR-Slide is offline   Reply With Quote
Swift Springs BRZ TouchMyHonda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 149 05-12-2015 12:33 AM
Prototype Swift Springs for FR-S mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 09-17-2013 09:36 PM
wtb:swift frs springs bkblitzed Want-To-Buy Requests 0 06-16-2013 04:03 PM
Swift springs rate ID subaruferrucci Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 04:26 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 06:15 PM
