Old 01-11-2014, 02:58 PM   #1
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Quick Tutorial - Dash carbon fiber wrap (3M DI-NOC)
DI-NOC is a great material to work with and will give your dashboard a more finished look if you like carbon fiber texture. Has anyone noticed whenever they get a passenger inside, they comment and seem to touch the dashboard? This will make it even better as the texture is pretty nice to the touch
I highly recommend you practice wrapping something else with extra material, knowing how to work the vinyl properly is pretty much the key to get a good result!
What you will need:
- Alcohol
- Scissors
- A knife / X-Acto
- A heat gun (a hair dryer won't work)
- Patience
- Painter's tape
- A few hours of work
Start by cutting your vinyl into shape, put your dash peices over the vinyl and give yourself a good 1.5" all around of extra material, as you will want something to grab unto to pull it around the corners.
Make sure you cut both pieces on the same length of the material so the pattern matches on both sides.
Start with your first piece, use a paper-towel / microfiber cloth damped with iso-propyl alcohol to clean the front and inside back of the pieces, then use some tape to attach it to your working area.
The DI-NOC has a checkered adhesive backing, this will make it quite easy to push any bubbles out.
Remove the di-noc piece from the silicon paper and center it on your peice, make sure it is aligned horizontally and press a bit on the center, then take your heat gun and heat the whole piece evenly so it kind of "melt" on the piece. Don't leave your heat gun at the same place for too long! Make quick back and forth motion.
After the initial heat, start pushing the material from inside out and try to cover the whole piece without any bubbles / kink. If you have a trouble spot, pull back on the material, heat and slightly stretch the vinyl over the area. You can use a squeegee / credit card but this is a small project, your hands will suffice.
The highly convex areas are the hardest to do, you will want to heat the di-noc until it feels "soft" and wrap it around with a bit of tension so it will cover the parts without any kinks in it. It takes patience and some practice to achieve so don't give up! When it's time to wrap it around the piece, you can cut small slits to make it easier to work on. Remember heat is your friend here. You can use a credit card to tuck the vinyl in the back.
Continue doing the same all around. When it's time to do the other peice, try to align the pattern so it looks good when all done!
Enjoy your new dash!
Rayme is offline   Reply With Quote
The Following 3 Users Say Thank You to Rayme For This Useful Post:
BlueDubbinTDI (01-11-2014), Brzzee (01-12-2014), PoorMansRacing (01-11-2014)
Old 01-11-2014, 04:05 PM   #2
DR 86
DR 86's Avatar
Make the fiber pattern line up across both pieces.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 01-11-2014, 04:11 PM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
It's not as striking in real life than in picture, however it lined up on the table but not perfectly once installed.
Old 01-12-2014, 06:00 AM   #4
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
Originally Posted by Rayme View Post
3M DI-NOC
Nice write up! I would HIGHLY suggest using 3M Primer 94 Adhesive Promoter to help the vinyl stick and not peel/bubble.
I did this almost a year ago...
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 01-12-2014, 12:44 PM   #5
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
Awesome! I was thinking of doing something like this, but for some reason the images aren't loading for me? Anyone else experiencing this issue?
kayoh is offline   Reply With Quote
Old 01-12-2014, 01:55 PM   #6
MadFRS
MadFRS's Avatar
Drives: UltraMarine FR-S
Images loaded fine on my end...
She's Gone....
Flickr Page
MadFRS is offline   Reply With Quote
Old 01-12-2014, 02:10 PM   #7
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Quantity needed
Attachment 63201
Attachment 63198
Attachment 63199
three tubes enough to how much? If I wanted to wrap doors and rear side panels how many of the promoter would you suggest I purchase?
Brzzee is offline   Reply With Quote
Old 01-12-2014, 03:58 PM   #8
AG3NT_5CARFAC3
Drives: Toyota GT86
The 3M promoters dry up REALLY fast; If you have three panels ready and already cleaned with alcohol, I would say you might get away with one tube for three panels. I ended up buying 20 of them in bulk on eBay. I honestly forget how much it was but I highly recommend getting a good amount.
The Following User Says Thank You to AG3NT_5CARFAC3 For This Useful Post:
Brzzee (01-13-2014)
Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) master345 Cosmetic Modification (Interior/Exterior/Lighting) 56 05-04-2014 12:10 PM
Carbon fiber wrap cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 22 09-18-2013 01:05 AM
carbon fiber wrap gone bad! joshuagranger Scion FR-S / Toyota 86 GT86 General Forum 28 06-28-2013 01:47 PM
3M Dinoc Matte Carbon Dash Wrap jadewbj Cosmetic Modification (Interior/Exterior/Lighting) 89 04-24-2013 10:58 AM
Carbon Fiber Wrap PLZdontscream Cosmetic Modification (Interior/Exterior/Lighting) 13 11-14-2012 02:58 PM
