View Poll Results: Do you have squeaky windows in your BRZ/FR-S?
I do and it's noticeable 105 77.78%
I do but only when the window cracks open/close 13 9.63%
I don't. 17 12.59%
Voters: 135. You may not vote on this poll
Old 12-13-2012, 02:16 PM   #29
RYU
RYU's Avatar
Drives: really slow...
Originally Posted by Tt3Sheppard View Post
Maybe the squeak is related to that 2 inch wide line I get on my side windows. Whenever I clean my windows I roll them down then back up and there is a nice streak from something under the door.
Originally Posted by number1Tango View Post
that streak is so annoying.. i wish there was a way to get rid of that
Probably no way to get rid of it. Our windows are "frameless" so those are internal window guides since it has no frame guides. I think if they changed the friction material to a different kind of urethane that should solve the problem.
Originally Posted by alan.chalkley View Post
Easy fix for squeaky windows on any car.
Just squirt a small amount of powdered graphite in the slide rubbers and wipe off any excess.
This may work but it seems like the squeak is coming from the center (not the side guides.
Originally Posted by CircuitJerk View Post
Just to be clear, to me it seems like its squeaking in the center, not the sides right?
Appears to be coming from the center area for me.
It rained again last night. Squeak is back in full force! Annoying as hell.
RYU is offline   Reply With Quote
Old 12-13-2012, 06:35 PM   #30
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Yeah, so I'm tempted to take the door panel off, but it's not something I want to do for no reason, and that's pretty much what it is for me at this point. It's not my daily and I avoid inclement and even mild weather conditions when possible.
I'd sure love to see what's behind there.
CircuitJerk is offline   Reply With Quote
Old 12-15-2012, 04:43 PM   #31
twincamRob
twincamRob's Avatar
Drives: 2013 FS FR-S
Originally Posted by Jlin View Post
is there a remedy for this?
Took my door panel off today to try to find a fix for this. Found the source of the problem but you cannot get to it without completely removing the window
There's a rubber piece that rubs/contacts the window as it goes up and down. Only way I can think of to get rid of the sound is to lube this up (which would make for no more clean window), or remove it.
There's also a fuzzy piece farther back on the door on either side of the window, there's a small section of this stuff under the rubber thing above as well...
Robbie S.
-13 FR-S
-12 H-D 48
Instagram: @twincamrob
twincamRob is offline   Reply With Quote
The Following 4 Users Say Thank You to twincamRob For This Useful Post:
CircuitJerk (12-15-2012), number1Tango (12-15-2012), RYU (12-17-2012), zc06_kisstherain (06-16-2015)
Old 12-15-2012, 05:06 PM   #32
number1Tango
Drives: Silver FRS
so that's the culprit for the streaks.. hmm... maybe using a different material?
number1Tango is offline   Reply With Quote
Old 12-15-2012, 06:09 PM   #33
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
I've really only noticed mine do that when it's really cold.
glorydays is offline   Reply With Quote
Old 12-16-2012, 10:28 AM   #34
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
i used rain-x to make the window squeak go away, when it squeaks again it means the wax needs to be reapplied for maximum safety in the wet
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following User Says Thank You to carbonBLUE For This Useful Post:
CircuitJerk (12-16-2012)
Old 01-11-2014, 03:47 PM   #35
lorip713
Me too, only happens when it's wet.
lorip713 is offline   Reply With Quote
Old 01-12-2014, 09:44 AM   #36
BRZnut
Drives: BRZ DGM Limited
only when wet here too, otherwise fine!
Windows Squeaking Froylavin Issues | Warranty | Recalls / TSB 164 02-24-2018 02:41 PM
RED FR-S with DG Squeaky Clean Hamza7 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 02-01-2014 02:48 AM
Windows 8 Khalis Off-Topic Lounge [WARNING: NO POLITICS] 33 10-17-2012 11:20 PM
Ice + windows... brzninja BRZ First-Gen (2012+) — General Topics 23 10-09-2012 10:29 PM
Windows 7 Theme ToyotaObsession Scion FR-S / Toyota 86 GT86 General Forum 0 05-28-2011 04:27 AM
