Old 01-10-2014, 07:53 PM   #1
psyclone07
psyclone07's Avatar
Drives: WRB BRZ
No drill side skirt extensions
Has anyone seen or used or know of any side skirt extensions that mount with double sided tape and maybe just screws on the ends of the wheel arches.
I love the look of simple extensions but not a fan of drilling into the underbody of the car/skirt
psyclone07 is offline   Reply With Quote
Old 01-10-2014, 08:03 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
None
I wouldn't trust any held with tape. The STI skirts however can be mounted without drilling into sheet metal.
Old 01-10-2014, 08:20 PM   #3
psyclone07
psyclone07's Avatar
Drives: WRB BRZ
On my previous car had a kit that Held up for 2 years until I removed them. Similar shape to sti skirts though.
Maybe just end up with sti style skirts.
Here's a car I painted with the same kit. Rear lip and side skirts have double sided tape only and screws on ends.
Old 01-10-2014, 08:25 PM   #4
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
get a STi replica side skirt on ebay. no drill require, just bolt on, and 3M tape inside. I have it on my car for 3 months. no problem at all.
http://www.ebay.com/itm/12-14-BRZ-tS...784965&vxp=mtr
The Following User Says Thank You to Lverasky For This Useful Post:
hmong337 (01-11-2014)
Old 01-11-2014, 02:38 AM   #5
sirsol66
Drives: 2013 FRS- Hot Lava
Would you happen to have any photos from some distance? I'm curious to see how they look on a firestorm car.
sirsol66 is offline   Reply With Quote
Old 01-11-2014, 03:32 AM   #6
kALMIGHTY
Drives: TRD Ultramarine '13
I believe the entire 5axis kit is just 3M. No drilling.
Old 01-11-2014, 04:14 AM   #7
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Originally Posted by Kiske View Post
None
I was concerned for my rear wing since my coworker started having water damage to the tape, so I used silicone sealant to make sure no water gets to the tape. That should make sure it sticks u until you take it off.
mike_ekim1024 is offline   Reply With Quote
Old 01-11-2014, 08:56 AM   #8
charged86
charged86's Avatar
Attachment 63030
I've done side skirts the same way. Paint looks good btw
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
psyclone07 (01-11-2014)
Old 01-11-2014, 11:47 AM   #9
psyclone07
psyclone07's Avatar
Drives: WRB BRZ
Thanks, just makes me cringe to drill into a new car. May just end up going with the sti skirts and painting the upper portion of them, leaving the lower lip black.
Wish I had more time / place to continue paint work . All done in a garage took it to a car meet and no one believed it was a DIY.
Cool story bro! I know <_<
This is right after it dried. Before any cut and buff.
And my car with same kit
Old 01-11-2014, 12:30 PM   #10
sirsol66
Glad I'm not the only person with this concern. Hopefully eventually the aftermarket releases a no drill solution!
The Following User Says Thank You to sirsol66 For This Useful Post:
TouchMyHonda (01-11-2014)
Old 01-11-2014, 01:24 PM   #11
mfbmike
Drives: 2013 FRS, 2008 R32
I believe the TRD sideskirts do not require drilling and are mounted using screws that are on the lower ends of the wheel wells i.e. where mudflaps would go
mfbmike is offline   Reply With Quote
Old 01-13-2014, 12:50 PM   #12
_search
I am right there with you. Drilling holes into sheet metal on the bottom of the car? If you live anywhere that has a real winter that just seems like taunting the gods of rust to smite you.
After what I went through with the rust under my old GC8's side skirts I just can't do that to my BRZ and feel ok about it. And those side skirts were factory.
_search is offline   Reply With Quote
ForceWerkz: FRS/BRZ Side Skirt Extensions JonMotoring Exterior Parts - The Rest 142 05-23-2014 03:35 PM
GB: ForceWerkz Side skirt extensions & FRS front lip JonMotoring Groupbuys 72 04-16-2014 05:56 PM
ForceWerkz FRS/BRZ Side skirt extensions (CARBON FIBER) JonMotoring Exterior Parts - The Rest 76 11-13-2013 02:12 PM
GROUP BUY: BRZ/FRS CS style Side Skirt Extensions JonMotoring Groupbuys 82 08-13-2013 10:55 AM
