Old 01-11-2014, 02:44 AM   #1
keithgold
I can only turn right
keithgold's Avatar
Drives: 2014 Whiteout FR-S
93 Octane vs 91 Octane
I read in the owners manual that the fr-s requires 93 octane gas. In the States the best we have is 91 octane. How much does that effect the performance of the car and does it damage the engine in anyway?
keithgold is offline   Reply With Quote
Old 01-11-2014, 03:02 AM   #2
Flashgodspeed
Drives: Argento 2013 FRS
In YOUR state lol. 93 is readily available where I live. E85 too
Flashgodspeed is offline   Reply With Quote
The Following 4 Users Say Thank You to Flashgodspeed For This Useful Post:
CSG Mike (01-14-2014), Evil Jesus (01-14-2014), Mister (01-22-2014), Zelica (06-15-2014)
Old 01-11-2014, 03:02 AM   #3
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I'm pretty sure 93oct is available in most places outside Cali. 91oct won't damage anything although this is lowest octane you should run in a 12.5:1 compression engine like the FA20. The ECU will adapt to 91oct but will obviously not perform as well.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 01-11-2014, 03:08 AM   #4
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
Firstly, other states do have 93 octane. Perhaps not at all gas stations but I have no trouble finding 93 in NY.
Secondly, the difference between 91 and 93 is very small. Using 91 will not cause any problems unless you have an incredibly aggressive custom 93 tune. Theoretically there is a performance difference but you'd need a dyno to really tell. I doubt most people could accurately tell which is faster in a blind test.
If 93 was really necessary over 91 the car wouldn't be sold in California.
Perrin CAI + intake tube || Tomei UEL || OFT Stage 2 tune
YMAA is offline   Reply With Quote
Old 01-11-2014, 04:20 AM   #5
Captain Stall
OK, here we g...oh, wait
Captain Stall's Avatar
Drives: '13 Hot Lava 6M
Or in parts of Canada. I've never seen 93 in New Brunswick or Nova Scotia.
I'm sure the owner's manual says something like, "Use 93 octane if available, otherwise 91 octane* is perfectly acceptible."
Last edited by Captain Stall; 01-11-2014 at 10:35 PM. Reason: *=fixed "ocatane" to "octane"
Captain Stall is offline   Reply With Quote
The Following User Says Thank You to Captain Stall For This Useful Post:
YMAA (01-11-2014)
Old 01-11-2014, 10:59 AM   #6
Suberman
Drives: Subaru BRZ Sport Tech Satin White
93 is recommended. 91 is minimum. The engine runs safely on 87 as I understand it, just not well.
Elevation affects octane requirements. 91 is the most common up here in Calgary at 1,000 meters elevation (3400 ft). I've used 94 with no noticeable effect, probably because the thinner air up here can't use more octane.
If you are in coastal areas you should be able to get 93 or 94 easily.
Suberman is offline   Reply With Quote
Old 01-11-2014, 11:15 AM   #7
Muskokan
Drives: white Sport-tech
Yea I grabbed a tank of the petro 94 when I was down in the city. Didn't really notice anything from the usual 91 shell.
Muskokan is offline   Reply With Quote
Old 01-11-2014, 11:33 AM   #8
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Petro 94 is simply 91 with 10% ethanol.
Mad1723 is offline   Reply With Quote
Old 01-11-2014, 12:18 PM   #9
Muskokan
sorry confused myself, not petro 94, ultra 94 octane at petro.
and if thats still the one your thinking about, link to info?
Old 01-11-2014, 12:29 PM   #10
Mad1723
Mad1723's Avatar
I can't give you a link right now, but a quick Google search should give you some results. It's even written on the pumps when you go at the station IIRC
Sent from my SGH-T999 using Tapatalk
Old 01-12-2014, 11:53 AM   #11
Taro
You call him Dr. Jones!
Taro's Avatar
Drives: 2013 Twin Mish-Mash
He's correct. I put 94 from Petro in, and my crickets started instantly.
[IMG][/IMG]
Taro is offline   Reply With Quote
Old 01-12-2014, 01:07 PM   #12
Muskokan
Yea he said the octane is still 91 though? I know it's got ethonal but it doesn't bother me.
Old 01-12-2014, 01:15 PM   #13
Mad1723
Mad1723's Avatar
Technically, it is 94. BUT not 94 pure gas. It's a blend with ethanol in it. =)
Old 01-12-2014, 01:43 PM   #14
mike the snake
I see some turbo numbers on 93 up as high as 330whp.
If I have WMI on 91, would that be equivalent to 93 at least?
I bought the WMI along with the FB turbo kit system hoping to get some better numbers than just 91 could offer.
100 Octane? hellyvin Northern California 23 07-24-2017 08:01 PM
What Octane for the FR-S? 914_WHITE_FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 07-13-2013 11:43 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
110 octane EZWood Engine, Exhaust, Transmission 19 06-29-2012 08:12 PM
93 Octane? ashtray BRZ First-Gen (2012+) — General Topics 175 04-04-2012 12:22 PM
