Old 01-10-2014, 02:27 AM   #799
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Has anyone tried plumbers putty for this fix?
Old 01-10-2014, 08:24 AM   #800
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
Nope, but I do have some black Sugru to try.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
Old 01-10-2014, 09:12 AM   #801
wheelhaus
wheelhaus's Avatar
So it's back again and pretty bad.
I'm past the warranty (over 36K miles), is the taillight still a TSB and i can get it replaced for free? Or am i screwed now?
I picked up some silica packets, i'm going to give those a try. Also going to try and sealing the taillights.
It's an easy fix, a lot of people are blowing it out of proportion and treating it like the end of the world. I agree its a problem we shouldn't encounter, but it's small and easy to resolve. The taillight assembly is fine, its the gasket that fails and allows water by, which then seeps in past the bulb sockets.
I made an earlier post outlining how I fixed it permanently if you don't want the visible snot method mentioned above.
Here's a stepped version:
1- pop out trunk liner (enough to get to the fender)
2- remove 4 small nuts and two light connectors and remove taillight
3- remove bulbs (note the bulbs are not gasketed, this is how water gets in once the foam gasket fails)
4- gently remove thin foam gasket and clean with soap and water or isopropyl alcohol
5- pool water into corner and turn upside down to remove as much water as possible
6- set up hair dryer on lowest possible heat and tape up a cut soda bottle or cardboard to funnel air into the largest bulb socket
7- let sit and monitor for an hour or two until dry
8- squeeze a small bead (1/8" (3mm) diameter) of silicone sealant onto the taillight side of the foam gasket anywhere it meets the plastic flange and around the hardware (the foam will be squished in these areas)
9- carefully place gasket onto the taillight, and repeat silicone bead on fender side of the gasket
10- reinstall taillight (note the plastic tab on the outer edge must be inserted first) and lightly torque nuts. Done.
Old 01-10-2014, 09:13 AM   #802
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by RFB View Post
Depending on how much water - an alcohol wash or drier packs
Then silicone seal gaskets and snot
CERBERUS
When you say alcohol wash - what exactly do you mean?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 01-10-2014, 10:42 AM   #803
RFB
RFB's Avatar
Drives: FRS
11 - snow man snot.
Otherwise the continual erosive action of the water will eventually break the seal.
Think of the Grand Canyon.
If you spray your back window with a garden hose, watch the water stream coming out over the top of your tail lights -
You will be convinced.
CERBERUS
RFB is offline   Reply With Quote
Old 01-10-2014, 10:45 AM   #804
RFB
RFB's Avatar
Drives: FRS
Plumber snot
It would work but I used tack adhesive because the plumbers seal was softer and messier (kinda plasticine ish).
CERBERUS
Old 01-10-2014, 10:50 AM   #805
RFB
RFB's Avatar
Drives: FRS
Methyl Hydrate (gas line anti-freeze).
Completely harmless to all plastics.
Swish it around let it drain out and air dry only (no heat).
CERBERUS
The Following User Says Thank You to RFB For This Useful Post:
civicdrivr (01-10-2014)
Old 01-10-2014, 10:50 AM   #806
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Might I suggest using a Removable Caulking as quote
"Use this weather-strip caulk when you need it and then simply peel it away when you don't. Its temporary watertight and weatherproof seal prevents air and moisture penetration"
This should remove any worries about gluing in your tail lights with silicone. It is usual clear and could be used instead of the snot. Just make use it is a thick enough bead that it will hold together when you pull it off.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 01-10-2014, 10:56 AM   #807
RFB
RFB's Avatar
Drives: FRS
Sugru
Its good stuff but 18 bucks verses 99 cents !
CERBERUS
Old 01-10-2014, 10:58 AM   #808
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Haha, you don't think i've done this?
I've done it all under the sun. New custom cut gaskets, double gaskets, silicone and so forth.
I'm getting tired of this bullshit.
36K miles in and this is the 7th time it's happened. Seven.
I have patience for when somethings broken, not flawed from the start.
I'll try the gaulk, but it's the underbody of the taillight of which moisture from the air gets in, not so much the rainflow or waterfowl from the trunk. There have been days where there is no water at all touching the car and i'll still get it. I live near the water, theres moisture in the air all day.
I've spent over $60 on fixing a seal of taillight, boy doesn't that sound stupid?
Old 01-10-2014, 11:27 AM   #809
RFB
RFB's Avatar
Drives: FRS
The pics on this forum of condensation (and all the ones I've seen) show condensation forming on the inside tops of the tail lights.
This is indicative of water getting in on top. If left unchecked enough water gets in to collect on the bottom.
The bottom of the lights have no ingress, but the back does (where the connectors plug in). Moist air gets in that way, but also allows air egress.
It is also important to follow the tsb with regards to peening the car body bolt holes, tightening torque etc. for flush mounting otherwise all else is in vain.
CERBERUS
Old 01-10-2014, 11:38 AM   #810
wheelhaus
wheelhaus's Avatar
Don't mean to provoke anyone or hit any nerves. That really sucks, you must be in the worst case scenario for conditions to lead to this.
I'm sure you've accounted for this, but it's possible the thin metal underbody is warped, rendering any dry gasket useless. At least a wet sealant such as silicon or a tacky putty (maybe snowman snot would work in the same way) would fill the tiny gaps and voids left behind by a dry gasket.
When I had the taillight assembly out I believe the only way for moisture to actually enter the assembly was through the bulb sockets, because there's no seal there. (Unless the housings are cracked/damaged/flawed/modified, etc providing another pathway). Apparently the hot/cool cycles each day are sucking moist air into the housings where it later condenses if you live in a humid environment. If the sockets are the only pathway, maybe just use some of the snowman snot mentioned above if its removable? I can't remember how the bulb sockets were shaped, but I imagine it would work either as a gasket inside the socket or packed around the outside.
Old 01-10-2014, 12:09 PM   #811
TiagoGrohl
Drives: GT 86 Toyota
Location: Portugal, Vila Nova de Famalicão/ Vila do Conde
i have the same problem, they change the seals twice 2 months ago and yesterday they change both tail lights. i drove 45 km to home and when i arrive the tail lights have condensation in both. i dont realy know what to do. is the third time
Opel Kadett Cabrio 1.4l, 100hp 1992
Daihatsu 55Wide 0.55l, 35hp 1988
Daihatsu Feroza 1.6l, 100hp 1991
Fiat Coupe 2.0l 20V Turbo, 290hp 1998 (Wrecked)
Honda CRX VTEC 1.6l 180hp, 1992 (Sold)
TiagoGrohl is offline   Reply With Quote
Old 01-10-2014, 12:25 PM   #812
RFB
RFB's Avatar
Drives: FRS
Dont let the dealer fix it. Do it yourself with all the information on this forum.
A flat body mount surface, a thick glued gasket and a putty dam at the top (dealers mechanics don't do all this).
CERBERUS
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 03:48 PM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 06:20 PM
