Old 01-09-2014, 10:50 PM   #2577
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Originally Posted by phloozy View Post
Feel free to compare them in your mind, I would also
That's one of the reasons I hate being an aspy. mind goes one way, and i don't realize how it sounds until afterwards.
I am honestly curious to see how I woulda done at the dyno day that this shops dyno was at (when i had no money), so hopefully I can find out tomorrow.
and i edited the post that made me sound like a schmuck, because i did sound like a schmuck.
wrxgoose is offline   Reply With Quote
Old 01-09-2014, 11:54 PM   #2578
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by wrxgoose View Post
i know, and i unfortunately can't stop comparing them in my mind, which is why i think it's an anomaly. and you're right, i need to not compare it to others, since my build is different from others. Sorry.
You do realize a dyno dynamics has 2 modes right? Regular (low #'s) and Comparison mode (dynojet #'s). Bill at delicious has show a plot in both modes before. Regular mode showed 260 and comparison mode showed 300. Your 75mm pulley pump numbers make sense for comparison mode. I predict you will make 245-255 on a dynojet.
Old 01-10-2014, 12:09 AM   #2579
wrxgoose
WUB WUB
didn't realize that, but from doing some reading on other forums, looks like you may be right. guess we'll see in a couple of hours (if it's not raining)
Old 01-10-2014, 12:50 AM   #2580
DaBrz
New to FI and have some questions...
How many users are running autos with this and how was tuning?
I hear installation is not too difficult. At least compared to the other kits. How long did it take to install (by yourself or with a buddy).
On autos, is 230-240 expected with with the base kit with full 2.5in exhaust and headers or less. Looking for a reliable DD setup, nothing crazy since I drive about 20k miles a year and this looks like it.
DaBrz is offline   Reply With Quote
The Following User Says Thank You to DaBrz For This Useful Post:
whataboutbob (01-10-2014)
Old 01-10-2014, 12:56 AM   #2581
wrxgoose
WUB WUB
took my friend and i 3.5 hours to install, and while neither of us have ever installed forced induction on a car, he is a tech at lexus.
with tuning, i recomend doing some research on the available tunes that are out there, there's a lot of different tuners out there, all with their own methods to their madness. I've got @JuniorAWD doing my tune, and I really like him. Others have used FA20club, and Delicious, and um....shit, tired can't think of other tuners right now.
The Following User Says Thank You to wrxgoose For This Useful Post:
DaBrz (01-10-2014)
Old 01-10-2014, 01:48 AM   #2582
sw20kosh
good luck!!!
Old 01-10-2014, 02:21 AM   #2583
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
A local tuner recommended a couple things, first he strongly recommended a header and second if I did not go with a header he said I'd need to install a wideband bung in the exhaust manifold to get a proper AFR reading.
Does anyone have experience with this or having to install this. I haven't heard that mentioned before so I just wanted some more info. Thank you.
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
The Following User Says Thank You to jjkerr626 For This Useful Post:
DaBrz (01-10-2014)
Old 01-10-2014, 08:43 AM   #2584
swift996
swift996's Avatar
I think with eTunes (I pretty much assume any tuner on this platform will tune in person i.e.- Ptuning)
- Delicious
- FA20Club
- Moto-East
- Visconti? (not sure if he still exists in the community)
A header is going to add more power and should lower boost a little bit. The wideband will really help to dial in the A/F ratio. It's really the only true way to know/tune.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
DaBrz (01-10-2014)
Old 01-10-2014, 10:47 AM   #2585
wrxgoose
WUB WUB
it's drizzling out, so i don't know if i'll be able to use their dyno (it's on a trailer, so i don't know if it's inside or outside), and they haven't answered their phones.
I've been doing a bit of research also on finding a belt for the smaller pulley, so i can have that ready to go, and get belt and pulley installed next time JR is down here so i can go straight to dyno tuning.
Old 01-10-2014, 11:28 AM   #2586
DriftEm
DriftEm's Avatar
I have the 70mm pulley and I went with Gates belt K061010, this belt is half inch smaller.
Sent from my SAMSUNG-SM-N900A using Tapatalk
DriftEm is offline   Reply With Quote
The Following User Says Thank You to DriftEm For This Useful Post:
Old 01-10-2014, 11:30 AM   #2587
wrxgoose
WUB WUB
Originally Posted by DriftEm View Post
I have the 70mm pulley and I went with Gates belt K061010, this belt us half inch smaller.
I'm actually using a belt that's about half an inch smaller on the 75mm though, simply because my tensioner would move too much when i'd get on it. but john and i will definately look into this belt as well (if it's not the one i'm already using) for the 70mm
Old 01-10-2014, 11:34 AM   #2588
phloozy
phloozy's Avatar
Drives: Scion FR-S
Im using the 75mm belt on the 70mm with no issues
phloozy is offline   Reply With Quote
Old 01-10-2014, 11:43 AM   #2589
DriftEm
DriftEm's Avatar
That must have been a bitch to install with 75mm pulley, tight fit
Old 01-10-2014, 11:44 AM   #2590
wrxgoose
WUB WUB
lol. you have no idea. took probably more than 20 minutes just to get the belt on, and we had to rotate the crank to try and pull it on there.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
