Old 07-07-2013, 10:43 PM   #15
Hot Toys
nice job...i was about to do it as well....i knew the deck can just plug and play...thanks
Hot Toys is offline   Reply With Quote
Old 09-20-2013, 10:28 PM   #16
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
The bcus2 harness adapter male does not fit properly into the back of my brz head unit
I'm stuck. Anyone had this problem ?
different size 16 pin back connector
Thanks
ucsmfu is offline   Reply With Quote
Old 10-03-2013, 12:25 AM   #17
Techfl3x
Techfl3x's Avatar
Drives: Firestorm Red FRS/86 MT
Thanks
Hmm I'm not sure since I don't have a BRZ. I'm sure @Beat-Sonic can help you out. Shoot them an email or PM. Eric's a good guy and helped answer all my install questions. Gl!
Techfl3x is offline   Reply With Quote
Old 10-06-2013, 02:40 PM   #18
Beat-Sonic
Beat-Sonic's Avatar
Drives: Toyota and Lexus
Thanks
Please pm me, I'll help you troubleshoot the issue!
Thanks!
Beat-Sonic is offline   Reply With Quote
Old 10-07-2013, 03:42 PM   #19
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
everything solved.
Thanks again to Eric at Beatsonic.
A++ customer service.
A++ quality products.
Old 01-06-2014, 04:40 PM   #20
Hardpack
Drives: Raven black FR-S
Do you have to have the bespoke HU in order to do this or can I hook it up to the stock touch screen HUH or with an aftermarket one.
Hardpack is offline   Reply With Quote
Old 01-09-2014, 09:29 PM   #21
Techfl3x
Techfl3x's Avatar
Good question. @Beat-Sonic should be able to help answer that.
Old 01-12-2014, 08:37 PM   #22
Beat-Sonic
Beat-Sonic's Avatar
Our BCUS3 Backup Camera Adapter and the Backup Camera combination is compatible to the Bespoke HU and also the stock standard Scion touch screen.
If installing the Beat-Sonic backup camera to an aftermarket headunit that is backup camera ready, you will not need the BCUS3 backup camera adapter. The backup camera is all you need.
Please let me know if you have any additional questions.
Thank you!
Old 01-13-2014, 06:40 PM   #23
SHES_A_10
SHES_A_10's Avatar
Drives: #1306
Subb'd
Sent from my iPhone
SHES_A_10 is offline   Reply With Quote
Old 03-11-2014, 05:29 PM   #24
moby
Drives: Toyota GT86 and C63 AMG
Does this work with the UK spec Toyota GT86 and the standard head unit (with Nav) fitted to it?
moby is offline   Reply With Quote
Old 03-20-2014, 09:18 PM   #25
maddog
Drives: FRS series 10, #32
Since you put that upside down is the writing about checking surroundings upside down?
maddog is offline   Reply With Quote
Old 03-23-2014, 07:31 PM   #26
SHES_A_10
SHES_A_10's Avatar
Drives: #1306
Originally Posted by Monogram View Post
It is installed the same direction as it would be on the plate mount, and everything is correctly oriented.
Hey may I ask how you had it placed in that location? Did you create/drill a hole or something? I'm looking to fix mine as such
Sent from my iPhone
Old 07-22-2015, 02:30 PM   #27
rixter145
Sleep Chomper
rixter145's Avatar
If I wanted to change the license plate... how hard is it to move the camera out momentarily?
rixter145 is offline   Reply With Quote
backup, beatsonic, cam, install, reverse
Beat-Sonic FR-S Photos Beat-Sonic FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 46 08-29-2013 10:35 AM
Beat Sonic Shark Fin Antenna | FR-S, 86, BRZ xravexboix Exterior Parts - The Rest 29 08-01-2013 07:42 PM
Beat-Sonic Backup Camera & Adapter for FR-S (Bespoke) & BRZ Special Price Beat-Sonic Audio/Visual, Electronics, Infotainment, NAV 60 07-15-2013 03:58 PM
Beat-sonic JDM shark fin antenna install. jadewbj Cosmetic Modification (Interior/Exterior/Lighting) 23 05-23-2013 01:12 AM
