Old 01-09-2014, 11:10 AM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by smbstyle View Post
Did a little research on Tire Rack on sizing:
(all XXX/45R17 sizing)
TIRE / SECT WIDTH / TREAD WIDTH
OEM Primacy / 8.4 / 7.5
MPSS 215 / 8.4 / 7.7
MPSS 225 / 8.9 / 8.2
RS3 215 / 8.4 / 7.9
RS3 225 / 8.9 / 8
ZII 215 / 8.4 / 8
ZII 225 / 8.9 / 8.2
Take the numbers with a grain of salt; Tirerack just republishes manufacturer numbers.
Old 01-09-2014, 11:11 AM   #16
CSG Mike
CSG Mike's Avatar
How much of a difference in grip is there between a 215 and 225? Basically I'm trying to weigh if the overall grip outweighs the loss in steering feel.
A little, but not much.
Stick to the 215. It's already gonna be low on steering feel because 7" is the minimum rim width for the 215. The 215 on a 8" would likely be faster than a 225 on a 7", because the contact patch will be larger.
Old 01-09-2014, 09:48 PM   #17
djliquidsteele
Drives: Scion FR-S
I will say that I bought 225/45/17 PSS purely to have a meatier look.
djliquidsteele is offline   Reply With Quote
Old 01-09-2014, 10:50 PM   #18
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
@Ninjin is running 225/45 PSS's on his stock wheels. They fit great. Not too much beef at all, but still some decent curb check protection.
^GT5 Replay Photo Mode^
Old 01-10-2014, 03:44 PM   #19
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
Thanks to the OP for this question. I'm in the very same frame of mind as I consider upgrading tires and/or wheels.
I've been to one HPDE session with the car bone stock; and obviously wasn't pushing the car too the extreme limits, but I didn't like the way the stock tires (Primacy) felt. In fact, I lost traction and spun off the track once. A lot of that was my inexperience, but these tires aren't the stickiest either.
My plans for the car are to stay NA for now, do at least one more HPDE and hopefully 3-4 Auto-x events in 2014. Once I get closer to warranty expiration, I will modd exhaust and tune.
For now, I'm considering upgrading the tires (looking at the Michelin Super Sports as I want a tire that gives better performance than stock, but can also do double duty as a daily diver...can't justify separate track/auto-x set of tires/wheels at this time, so I need the tires to be at least reasonable in the wet as we do get a fair amount of rain here). I've also considered upgrading wheels to 17x8 or even 17x9 with a 225 or 235 width tire.
Now I'm wondering if just going with either a 215 or 225 tire on the stock wheels for 2014 and getting some more events under my belt and then reassess.
My question: at my relative low skill level, is it really going to matter if I go with 215 vs 225 if I stick with the stock wheel? Would anyone experienced advise me to just drive the stock rubber until they're toast and then upgrade to better tire?
MightyMeeple is offline   Reply With Quote
Old 01-10-2014, 03:53 PM   #20
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Stock rubber is a low rolling resistance tire with soft sidewalls. The Primacy HP gives up grip abruptly as the sidewall rolls over and plays dead. It works fine up to that point. Better tires do not do that. Stay well away from any LRR spec tire if you want decent performance.
Everybody who fits better tires likes the result.
Michelin Supersports are probably the industry leading tire in that category at present.
215 and 225 are roughly equivalent sections. It is unlikely you would notice a difference. I like the look of the 225 better so I went with that. The 225 is more suitable to developing driving skills, especially on the stock 17 x 7 wheel, because it has a slightly taller sidewall and will bulge slightly more on that narrow wheel. Both of these characteristics give a more progressive breakaway and the slightly shorter and fatter contact patch will make initial turn in a bit less critical feeling as the tire will give a bit more as you input steering lock. As oversteer develops you will find the counter steer a little easier with the slightly fatter tire. The narrower tire will feel slightly sharper and on that narrow rim will react more quickly.
I'd fit 225/45 x 17 Michelin Supersports.
I've just bought a set of OZ Alleggerita 17 x 7.5 in graphite silver with Michelin Pilot A/S 3 tires to achieve the same result but with cold weather in mind. If you routinely drive on summer tires at temperatures below 40 F then consider this particular top line all season tire seriously. If most of your driving is in proper summer temperatures then the Supersport is going to be hard to beat.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
MightyMeeple (01-10-2014)
Old 01-10-2014, 03:56 PM   #21
diss7
Drives: AE86, 2x GT86, TE27
In my experience, a wider tyre than is recommended on a wheel experiences more roll in the corners.
If for example, a tyre manufacturer recommends a tyre on a 7.5"-8.5", 8" optimal, I certainly wouldn't run it on a 7". I probably wouldn't run it on a 7.5". I would run it on a 9" if I had to.
diss7 is offline   Reply With Quote
Old 01-10-2014, 04:15 PM   #22
Biggins
Drives: Yes
You can fit a 215/45, 225/45, or 235/40 Dunlop Z2 on the stock rims. The 235/40 is the favorite size for this tire for the autocrossers, though the stock offset cuts it a little close.
Since the OP is starting out, I'd say go 215/45. I have them and they're wider than the Primacy, but they're not THAT much wider.
Biggins is offline   Reply With Quote
Old 01-10-2014, 04:22 PM   #23
Suberman
Michelin is OK with a 225 on a 7x17 wheel.
You should not run a 235 on a 7x17 wheel as minimum recommended for that size is 7.5 inches.
Autocross is highly specialized and low speed, emphasizing turn in and rotation where sidewall roll is actually an asset.
For street driving or occasional track driving stick to 215 or 225 would be my advice.
Old 01-20-2019, 10:20 PM   #24
Thumpindrummer
Drives: 2017 86
Originally Posted by ROCKETS86 View Post
I have a 245/40/17 on the back of my car fits on the rim easily and looks very chunky.
fits in the guard easily too, since then i upgraded and have a 255/35/18 now still fits in the guard with plenty of room
What brand tires did you use with the stock rims for the 245/40/17
Thumpindrummer is offline   Reply With Quote
Old 01-20-2019, 10:33 PM   #25
Thumpindrummer
Drives: 2017 86
Are those 245/40/17. On 7” rims. If so what tires did you use
Old 01-20-2019, 11:55 PM   #26
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I really do not suggest putting a 245/40 on a 7" wheel. It's not going to look good. A 225/45 will work on a 7"
245/40/17 should go on a 17x8" minimum. or better yet, IMO, 17x9" wheels
Im running 245's on 9" wheels. They fit right.
With that said, and I don't know where the thread is, but some guys were using a 245/40 on a 7" for track use.
I LIKE TIRES!
Old 01-21-2019, 11:33 AM   #27
jtmroczk
Drives: C-Street FR-S
I ran a 245/40r17 Z2SS for autox and daily driving in 2016, on a recomendation that a local guy was doing well with this wheel/tire size and that Z2SS had a stiff enough side wall to handle the narrow wheel.
It really kinda sucked at times trying to manage tire preasure to maintain the side wall and all. The ocassional fast and hard transition where the side wall quickly flopped from bulging-out to stretched-in on the rear outside tire under heavy loading was obvious from the driver seat and getting used to that grip-flop-grip transition took some effort.
haha, leave that combo alone
jtmroczk is offline   Reply With Quote
Old 01-21-2019, 01:49 PM   #28
JD001
JD001's Avatar
Drives: Subaru BRZ
God I love this forum! No subject is too much to dissect down to the last millimetre! I'm pissed that the UK don't get the "new" P4S in 17inch!
Steering feel with wider tires? TSY Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 07-26-2013 11:32 AM
Wider wheels: need an alignment? OakmanSmalls Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 07-18-2013 11:34 AM
What would make the rear tires look wider?? Razor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-19-2013 12:16 AM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 11:26 PM
Factory Replica BRZ Wheels, but wider? boarder1995 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-18-2012 08:32 PM
