#57 |
Drives: 2014 Scion FR-S|Whiteout
ST Coilover Pics
Looks like I'm joining the ST club! Unfortunately, one of my rear coils and helper spring was damaged during shipment (nice chunks taken out of the yellow powder coat)... but a quick call to ST and they overnighted new coils for me!!! Their customer service is top notch!!!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
| The Following User Says Thank You to *LongFella For This Useful Post: | Bad Habits (01-08-2014) |
#58 | |
Drives: br zed
Got this reply from ST via email - Galvanized Steel Coming from the makers of KW suspension systems the only main difference between the ST Variant 1 and KW Variant 1 is the steel they use. While KW uses Stainless Steel for their shock housing, ST uses Galvanized Steel. However, this does not mean a drop in quality, durability, or appearance. Although coilovers that use galvanized steel are more prone to corrosion due to environmental influences (i.e. mixture of salt water); those in the lower states: California, Texas, Florida, Nevada, etc. don't have to worry about corrosion. Those in the mid to upper States that snow still don't have much to worry about as long as they do not drive in heavy snow conditions upon where salt is used on roads. to further ensure those with doubt about Galvanized Steel, ST has corrosion resistant zinc plating on all of their threaded strut housings for further protection. Every year I head to spring training in Florida to see the Red Sox so that is a pricey trip but as soon as that is over and paid for there is a short list of a few mod's including the ST's I want to get started on. From what I can find these seem like the best bang for the buck for a decent ride and looks on a budget. |
| The Following User Says Thank You to Bad Habits For This Useful Post: | switchlanez (01-10-2014) |
#59 |
RedBunny w/ Wing
after you order teh ST Coilover, what else do you need before the installation... camper bolts? camper plate?
#60 |
Drives: WRB LMTD '13
#61 |
RedBunny w/ Wing
what kind of camber bolts you got?
#62 |
SPC 16mm camber bolts part number 81280
| The Following User Says Thank You to hanabie For This Useful Post: | Lverasky (01-09-2014) |
#63 | |
What are your ST's set at? Turns from bottom up? I'm putting mine on this weekend and like how your stance is. I'm also running 18x8.5 +33 sq gram lights. Thanks for the help!
#64 |
Drives: frs
#65 |
Drives: CBS BRZ MT, CBR 600RR
![]() at the height they come at right out of the box |
#66 |
#RememberTheBuster
Drives: Firestorm FRS MT
#67 |
Hella Flush
Drives: 2013 SWP BRZ
Just got the car back
| The Following User Says Thank You to Ny Brz For This Useful Post: | chanomatik (01-29-2014) |
#68 |
Drives: 2014 BRZ Limited
You're not worried at all about driving those ST's through the salty snow?
#69 |
Hella Flush
Supposedly because of the zinc plating it should be no problem. I dont drive her when or around when it snows, i drive my wife car.
#70 |
The front is maxed out and the rear is about midway. I think you could technically take out the helper spring in the front to go lower though. I'm no expert, but it seems to me the helper springs aren't doing much of anything because they are fully compressed.
![]() I did not adjust the perches from this before installing. |
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
| Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 856 | 06-14-2018 02:53 PM |
| RS*R Sports-i Coilover system installed (pics) | R0ME0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 139 | 02-05-2015 03:38 PM |
| Pics of you!? Pics of your life?! | seven | Off-Topic Lounge [WARNING: NO POLITICS] | 66 | 12-25-2012 04:49 AM |
| More stock pics. My Raven FR-S with graffitti background. Sick Pics | Hardrock4445 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 11-11-2012 11:29 PM |
