Old 01-08-2014, 11:33 PM   #211
Iceman
Iceman's Avatar
Drives: GT86
Pretty cool build, anyone who cares this much about Chapman's philosophy gets my respect.
Iceman is offline   Reply With Quote
The Following 2 Users Say Thank You to Iceman For This Useful Post:
Anthony (01-09-2014), Blokatos (05-02-2016)
Old 01-09-2014, 12:11 AM   #212
phastafrican
phastafrican's Avatar
Drives: 2013 Raven Scion FR-S
Never asked, what are the actual plans for the dash?
phastafrican is offline   Reply With Quote
Old 01-09-2014, 12:14 AM   #213
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Get rid of as much as I can without getting it to the point where I can bring it back to stock if I need to.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 01-09-2014, 12:32 AM   #214
phastafrican
Cool. I'll take it that making it presentable isn't even on the table?
Old 01-09-2014, 01:38 AM   #215
milchmann
Drives: 1987 AE86 -- 2013 ZN6 -- 1994 DC5
Nice work!
Nice work man. You already have most of the auto-x philosophy down. Super light, and just enough power to push it around the turn nicely. One thing you might need to consider is the DB restrictions for most clubs. A silencer will solve that at minimal weight if it is an issue. All of the clubs that I have ever encountered have a novice division that you will be place in btw. You will definitely be competitive ... and that will be addictive.
There are a few things that you will probably want to consider if you are serious about making that thing fly around turns that go a little against your philosophy.
Stitch or Seam welding the chassis.
Chassis bracing bars, especially with the rear seat removed the chassis is going to flex more.
I would also definitely take out that sound deadening. Here is a video on how to do that correctly.
[ame="http://www.youtube.com/watch?v=4FqkxgcjRQQ"]The Right Way to Remove Sound Deadening with Dry Ice - YouTube[/ame]
milchmann is offline   Reply With Quote
The Following 2 Users Say Thank You to milchmann For This Useful Post:
Anthony (01-09-2014), phastafrican (01-09-2014)
Old 01-09-2014, 01:50 AM   #216
milchmann
You might also consider removing all of the wiring for the dome light, trunk light, HVAC, stereo etc. You would be amazed at how much wires can weight ... plus you get to use more zip ties
The Following User Says Thank You to milchmann For This Useful Post:
Old 01-09-2014, 02:15 AM   #217
Bad Habits
Bad Habits's Avatar
Drives: br zed
Christ, last time I looked at this thread there was a car there! Can't wait to hear what it weighs.
Bad Habits is offline   Reply With Quote
The Following User Says Thank You to Bad Habits For This Useful Post:
Old 01-09-2014, 02:51 AM   #218
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
I did all this once. Dry ice and all. Even made an aluminum dash for more gauges. And I will never do it again for a daily driver.
kurbkilla is offline   Reply With Quote
The Following User Says Thank You to kurbkilla For This Useful Post:
Old 01-09-2014, 03:08 AM   #219
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
I think the sound deadening weighs so little that unless it comes out incredibly easy, you should just leave it.
Tanuki is offline   Reply With Quote
Old 01-09-2014, 03:12 AM   #220
Anthony
Weight Nazi
Anthony's Avatar
Thanks! All the Tomei exhausts come with silencers. I don't think NOLA Motorsports Park has a DB limit though. It's out in the middle of nowhere within an industrial area. I've done a good bit of track days there on my sport bike and there have been some crazy-loud bikes there and no one even brought it up.
As for the chassis bracing, I know how beneficial it can be. I'll probably do that after I've gotten it as light as I can. I know the benefits of the stiffness will far outweigh the negative side effects of the additional weight. So I'll be holding off on bracing and aero parts until the end.
Thanks for the video too. I was going to look that up eventually, but now I can just watch that one first. I'm still not even done gutting it, but I'm definitely on the down hill with that.
Old 01-09-2014, 03:17 AM   #221
Anthony
Weight Nazi
Anthony's Avatar
Only one way to find out...
Old 01-09-2014, 01:38 PM   #222
kurbkilla
kurbkilla's Avatar
It surprisingly weighs more then you might think. When I did it on my 83 celica the carpet was 18-22lb and the noise tar was about 30lb.
Old 01-09-2014, 04:31 PM   #223
Anthony
Weight Nazi
Anthony's Avatar
Holy shit. It can't weigh that much in our cars though. There's just not that much of it. I hope that's how much it weighs though.
Old 01-09-2014, 04:43 PM   #224
phastafrican
I actually hope there IS around 30lbs of it there. Between that and my window glass removal, I would almost negate roll cage weight.
The Following User Says Thank You to phastafrican For This Useful Post:
mother fu(king winning!
