#169 |
Drives: Raven FR-S
PTR11-18130 is the read red sway bar for the FR-S not the lowering springs
#170 |
Drives: Raven FR-S
*rear
#171 |
Drives: Raven FR-S
FR-S TRD Lowering Springs and Sway Bars releasing soon
I know people have said the TRD lowering springs will be rebranded eibachs, are they supposed to be more similar to the pro kit or sportlines?
#172 | |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
My guess is that TRD wouldn't release springs with as aggressive of a drop as the Sportlines (1.4"). I'd even be a little surprised if they went with the Pro-Kits at 1". I was thinking they would be closer to the drop from the RCE yellows (0.8") but who knows. Dropping the car affects the rear camber in a way that I'm not sure a OEM would endorse. Also dropping the car with the factory wheel width/offsets would suck in the appearance of the wheels to the point where it just wouldn't look right for a OEM configuration. Just my 2 cents. What do I know. |
| The Following User Says Thank You to mit_peid For This Useful Post: | nosi9frs (01-08-2014) |
#173 | |
Drives: tezla
#174 |
Drives: Raven FR-S
^ key word there is if haha. And I'm about to pull the trigger on the pro-kit when it gets warmer
#175 | |
Drives: Ultramarine FR-S
#176 |
Drives: Subaru BRZ Limited
#177 |
Drives: 10 series FR-S & Matrix S
Deno if any 1 else has seen this but theres a few trd sway bars posted on ebay and they are sold by toyota dealerships so im guessing its official that the usa trd sway bars finally came out recently? O and its FRONT AND REAR! Not just rear only! Can any 1 confirm?
http://www.ebay.com/itm/131089488069...84.m1423.l2649 |
#178 |
Drives: Raven FR-S
Call TRD and inquire about that part numbers availability (PTR11-18130) I've done this for the lowering springs and was told they were discontinued, but I never asked about the sway bars.
1-800-688-5912 |
#179 |
Drives: 2013 Scion FRS
they r in.....
i have the kit....front and rear bar...just waiting for it to be install
#180 |
Drives: Raven FR-S
How much for the install? And does any one think the trd springs will ever be not discontinued and actually released?
#181 | |
US TRD front bar? I did not see it. http://www.toyotaterritory.com/scrip...modelname=FR-S Where did you buy them? Thanks. |
#182 | |
| The Following User Says Thank You to SF-FRS For This Useful Post: | cslntuee (01-14-2014) |
| Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More | SOURCE,LLC | Brakes, Suspension, Chassis | 445 | 05-11-2015 05:41 PM |
| ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! | Boston Motorsports | Brakes, Suspension, Chassis | 84 | 07-23-2013 11:42 PM |
| Stock springs and sway bars | Spencer | Brakes, Suspension, Chassis | 3 | 04-25-2013 09:41 AM |
| FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 06:00 PM |
| **The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive | Pure Automotive | Brakes, Suspension, Chassis | 1 | 02-06-2013 02:32 PM |
