Old 01-08-2014, 07:50 PM   #239
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by diss7 View Post
Increase the tyre compound, and the ABS is noww triggered by g-force, not tyre slip. The car is registering a g-force beyound what the stock system believes is safe, so it pre-emptively engages ABS, as it believe lockup is inevitable (as it probably would be on stock tyres)
I have literally never heard of this from a reliable source. Not in any of my vehicle stability or dynamics courses, none of the technical papers I've read.
It's great that a race team told you this, but I'd love to see ANY reliable evidence of this being true. That is, an accelerometer used as a hard cap to ABS. Link to those tuners and software developers you mentioned?
Here's a manual that seems to focus on Toyota systems.
http://www.autoshop101.com/forms/brake09.pdf
Of note is probably page 10/23 (p. 118) which calls out a 'deceleration sensor' used for AWD systems and determining road conditions, likely snow or gravel vs. smooth surface. The rest of the document focuses on wheel speed sensors being the primary input for ABS, you can see it in the wiring diagrams.
Unless you start coming up with evidence you're just spouting crap on the internet. As an aside, I really wish SAE articles didn't cost like $24 a pop, should have downloaded a fuckton when I was in school.
Edit: realized you never credited an engineer. I know all too well that racers usually find the fastest way around the track but they don't always get the science behind it right.
ineedyourdiddly
bestwheelbase (01-08-2014)
Old 01-08-2014, 08:05 PM   #240
diss7
Drives: AE86, 2x GT86, TE27
This may come as a surprse to you, guy; but I'm not here to prove anything to you. Just because I can't provide the information YOU need to believe something, does not make it untrue.
I started this thread to provide my feedback/impressions of what removing the aids achieve.
If you need more data to satisfy your own doubts, I've stated numerous times how you can do it.
If you can't, thats fine. But it doesn't then become my responsibility to provide this for you.
diss7 is offline   Reply With Quote
Old 01-08-2014, 08:06 PM   #241
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
There is no way the abs uses a g force sensor. How will it know if you are on ice or snow.
Sent from my XT1060 using Tapatalk
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following User Says Thank You to WolfsFang For This Useful Post:
strat61caster (01-08-2014)
Old 01-08-2014, 08:07 PM   #242
diss7
So if the car decides it needs to engage ABS based on G-force (excessive deceleration) being above a certain limit, What does it do?
If no wheels are slipping and they all show the same rotation, what could the ABS possibly do to remedy the non-situation?
I am really curious, because engaging ABS based on G-force doesnt make any sense.
I would like to see that in writing.
So if you are going up a steep hill, ABS will be less likely to engage, and if going down a steep hill , the ABS is MORE likely to engage?
It pulses the brakes in the same way that it would if slip was detected.
Old 01-08-2014, 08:09 PM   #243
diss7
READ the previous information I have posted.
If works to G or slip.
If you're on ice or snow, its going to be slip that triggers it.
If you are on a dry road, with stickier tyres, you will reach the g limit before lockup, this is when its the g that is activiating the ABS.
The Following 2 Users Say Thank You to diss7 For This Useful Post:
BRZ21 (01-09-2014), WolfsFang (01-08-2014)
Old 01-08-2014, 08:12 PM   #244
WolfsFang
Scrape Master
WolfsFang's Avatar
I have slicks on my car it with stock brakes I have locked them up twice before abs locked in. It doesn't make sense for it to use a good force sensor at all
Old 01-08-2014, 08:14 PM   #245
Rio
Rio's Avatar
Drives: 2014 Scion FR-S ハチ
This thread is like the Energizer Bunny. Going, going, going...
Sent from my SGH-T999 using Tapatalk
Rio is offline   Reply With Quote
Old 01-08-2014, 08:21 PM   #246
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Disabled the driving aids. Here are my impressions.
Originally Posted by Ralph Spoilsport View Post
Thanks for your observations. Sorry you getting such a shit shower for it, it's totally unwarranted in my view.
I think the recent posts in this thread have all been pretty civil and full of general curiosity. We're no longer talking about just @diss7 and instead learning about how ABS is working on our cars. I know I'm definitely not trying to change his mind, just trying to learn.
Far from definitive, but http://www.toyota.com/esq/glossary.html mentions g-sensors are on cars with VSC, but are tied to VSC and sort of implies they aren't part of the ABS system. But we may never know without talking to someone at Toyota/Subaru directly, or seeing some manuals/techdocs.
Really interesting stuff here. That definition of VSC and @diss7 experience makes me lean toward g-sensors affecting ABS, which makes me feel even more understanding of disabling it.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following 3 Users Say Thank You to enwave For This Useful Post:
bestwheelbase (01-08-2014), diss7 (01-08-2014), strat61caster (01-08-2014)
Old 01-08-2014, 08:24 PM   #247
sanmarcosfrs
sanmarcosfrs's Avatar
Drives: 2013 asphalt frs
No aids here! Daily driven for 16 years. While disabling everything isn't the best idea, it's not exactly a death sentence either
sanmarcosfrs is offline   Reply With Quote
The Following User Says Thank You to sanmarcosfrs For This Useful Post:
enwave (01-08-2014)
Old 01-08-2014, 08:26 PM   #248
diss7
Sorry, I don't believe this.
Are you talking about bald road tyres, or motorsport slicks.
Were they even warmed up?
It's contrary to what I have experienced if this is legitimate.
Old 01-08-2014, 08:34 PM   #249
WolfsFang
Scrape Master
WolfsFang's Avatar
I have Yokohama a048 and they were warm. I was driving around my town late when a saw a big branch on the floor that I braked hard for. Heard my tires lock up, I tried to lock then up again with hard braking but it could not do it again. Instead the car just braked hard but no abs came on.
Old 01-08-2014, 08:37 PM   #250
strat61caster
That's a fair statement, we're all here willingly after all.
My issue is your describing a system in a way that goes against everything I know to be true and people are believing you without asking for evidence besides your butt sensor.
I'm curious though how you think this works, the wheel speed sensors make sense:
-wheel speed drops very quickly
-wheel is locked up
-release brake pressure
-wheel unlocks, speed increases
-reapply pressure
-repeat
What happens when a the accelerometer trips?
-max acceleration detected
-accleration drops
-reapply brake pressure when acceleration drops below braking level?
In my experience I would not trust an accelerometer to regulate my brake system, they're finicky even when set up properly and to get the kind of fidelity, consistency, and longevity out of a unit you'd have to spend a considerable amount of money, a far cry from the LED system outlined in the manual I posted.
Every technical paper I've found focuses on wheel speed sensors, this goes back to the 60's, any mention of accelerometers is meant for acquiring road conditions (ice vs. tarmac as mentioned previously) and nothing more.
http://papers.sae.org/2000-05-0236/
http://papers.sae.org/2002-01-2229/
http://papers.sae.org/2008-01-2985/
Thanks for the discussion, I never bothered to look up wheel speed sensors until today, you learn something new! Again, I'd love to see some evidence of an ABS system utilizing accelerometers for anything other than determining road conditions.
ineedyourdiddly
Old 01-08-2014, 08:46 PM   #251
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
I have 4 track days running Khumo V710's (30 UTQG) HP+ fronts HPS rears. I use the 5 sec Track Off (because I can never remember the pedal dance sequence or I'm late as usual for a session). Two heavy braking points 130-70 and 105-45 and I have not felt the slightest bit of ABS modulation. In my AMG the ABS was so pronounced the vibration could be seen in go pro videos. This car however had DTC 70 all around and was braking from 155 into the first turn.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following 3 Users Say Thank You to Deep Six For This Useful Post:
Old 01-08-2014, 08:47 PM   #252
diss7
Few things.
Thats a semi slick not a full slick.
Just driving around town, it will almost certainly not be at optimium temperature. I also note that you appear to live in quite a cold state.
Your ride height suggestes less than ideal alignment, with respect to grip under braking.
If you're driving around the street on those tyres, you almost certainly have them at too high a tyre pressure, which will drastically affect their performance.
Finally, a quick stap on the brakes as you describe could indeed lock a cold, poorly aligned semi slick.
Go do some big braking off the front straight of your local race track, with 30psi warm (so probably 24psi cold depending on local conditions and your driving style) with a known alignment (you may already have this) and see if the results are the same. Try it with the fuse installed, and with it pulled.
-wheel is locked up
-reapply pressure
-repeat
-accleration drops
I can't enter into more technical detail regarding this discussion than I already have. I don't doubt the sources you are providing or your knowledge at all. All I am doing is providing the feedback on what I believe is happening and way.
I'd really like it if someone decided to try to replicate my findings, independantly from myself.
enwave (01-09-2014), strat61caster (01-08-2014)
abs for noobs, aids suck, back to the 80's, brakes, driftin'alldayeveryday, i have aids, lots of aids, make believe abs systems, nanny aids, nanny boo-boos, no abs, old school, rock hard abs, waste of time read
Subaru BRZ tS Driving Impressions (Japanese) Gaiakai BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-13-2013 01:44 PM
Electronic Driving Aids trackmagic Scion FR-S / Toyota 86 GT86 General Forum 20 03-07-2013 07:45 PM
Initial Driving Impressions - BRZ Limited 6MT ShoNUFF BRZ First-Gen (2012+) — General Topics 17 12-21-2012 02:09 AM
FR-S Driving impressions Guaruja Scion FR-S / Toyota 86 GT86 General Forum 30 02-29-2012 05:20 PM
Kota Sasaki Subaru BRZ Driving Impressions illmatic BRZ Photos, Videos, Wallpapers, Gallery Forum 31 01-14-2012 12:24 PM
