Old 01-08-2014, 01:09 PM   #29
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I actually purchased one of those eBay lips and it arrived last week, can't wait to install it come spring.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 01-08-2014, 04:26 PM   #30
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Which one did you buy (from what vendor), is it of good quality? Have you tried placing it under your fender to see how it matches up fit wise yet?
Deathalo is offline   Reply With Quote
Old 01-08-2014, 04:38 PM   #31
BRZZZZZZZZZZ
Car Nut
I actually purchased this one http://www.ebay.ca/itm/12-14-BRZ-tS-...vxp=mtr&_uhb=1
Have not even had a chance to move it from my living room to my garage yet so who knows how it will fit. My car is sitting in my garage with 23km on the odometer and wont be driven until spring so I may not bother mounting it for a while.
Old 01-08-2014, 04:43 PM   #32
Deathalo
Ahh, that's an ABS version, similar to what Bayson R makes, problem is that ABS is a much more fragile material than Polyurethane, and for something that low on the front I'd be afraid it'd crack.
Old 01-08-2014, 06:05 PM   #33
djdnz
1337
Drives: 2013 BRZ WRB S/C
Are these ones are ACTUALLY polyurethane or just mislabeled ABS?
djdnz is offline   Reply With Quote
Old 01-08-2014, 07:18 PM   #34
Deathalo
Idk, I think you'd be able to tell really easily once you got it whether or not it was ABS (rigid) or PU (somewhat flexible)
Old 01-08-2014, 07:43 PM   #35
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I know from first hand, the one from jonmotoring is PU.
I have no idea about the eBay ones. That first link shows 2 different lips (one has mounting points, the other doesn't) so I probably wouldn't order from them.
Old 01-08-2014, 08:05 PM   #36
Deathalo
What did you think of his lip, I've heard mixed feelings on it.
Old 01-08-2014, 08:08 PM   #37
Andrew025
Andrew025's Avatar
I had no issues with it. Fitment was spot on. Definitely needs some sort of painting/plastidip though.
Old 01-08-2014, 08:52 PM   #38
Deathalo
Really? I thought most people just ran them as the black it comes in.
Old 01-08-2014, 10:23 PM   #39
Andrew025
Andrew025's Avatar
I think most people do.
It just has an unfinished look to it.
Old 01-08-2014, 11:45 PM   #40
Deathalo
I wonder if a coat of clear coat would do it, or like you said plasti dip, trying to think of easy DIY ways of improving the look.
Old 01-09-2014, 12:48 AM   #41
ShoGun
ShoGun's Avatar
Drives: 2013 Subaru BRZ SWP 6MT
a few look like replicas of my Seibon TA CF lip
2013 Subaru BRZ - SWP - 6MT
ShoGun is offline   Reply With Quote
Old 01-09-2014, 11:51 AM   #42
Deathalo
I noticed most have the same part number, so it probably doesn't matter where I buy from if I chose that version.
BRZ front lips lookchris Cosmetic Modification (Interior/Exterior/Lighting) 17 05-23-2014 02:14 PM
Trunk Spoilers/Lips, Front Lips. SalM NY / NJ / CT / PA 2 08-12-2013 01:44 AM
Do front lips look okay without side skirts Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 7 08-07-2013 02:26 AM
Any round/smooth front fenders/lips out there? Tromatic Cosmetic Modification (Interior/Exterior/Lighting) 0 06-26-2013 08:55 PM
Cheap Polyurethane Front Lips? 636 Cosmetic Modification (Interior/Exterior/Lighting) 8 04-12-2013 06:54 PM
