Old 01-07-2014, 08:51 AM   #1
wparsons
wparsons's Avatar
Perrin CAI's...
Just noticed that they've added the "Big MAF" version, based on their dynos the bigger maf housing gives very similar gains to the smaller maf housing.
Any input on if the bigger tube is worth getting? My car is going to be staying N/A for a while (possibly forever), so I'm doubting the bigger MAF housing will be of much benefit?
I'm also just leaning towards a good panel filter over the CAI portion, but this could all be good info for others as well.
flickr
Old 01-07-2014, 09:36 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The bigger MAF is of benefit to people who have a FI kit AND can use the Perrin CAI (e. g. AVO, Innovate) AND plan on making big power, (north of 400 WHP).
At high PSI, a bigger MAF housing is required to be able to keep using the MAF for tuning and not need Speed Density.
Edit: Per @PERRIN_Chris post, the bigger MAF housing CAI does make more power and should be selected as long as you have means to tune the MAF, like @jamesm stated. My apologies for adding some info that was not completely accurate.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
jonbonazza (01-07-2014), PERRIN_Chris (01-07-2014)
Old 01-07-2014, 01:47 PM   #3
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
If you are planning on tuning the car before or at the same time as adding the intake, I'd go for the big MAF intake. There really isn't anything to loose going with the bigger intake, as long as it's tuned correctly, you won't lose anything at lower RPMS or cruising. We have the MAF scaling available on our website for free that can be copied and pasted into your map!
We have proven that it makes more power than the normal PERRIN intake here.
If you don't plan on ever getting a tune though, you're going to want to do the normal size intake.
If you have any questions, let me know!
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
Sportsguy83 (01-07-2014)
Old 01-07-2014, 02:01 PM   #4
jamesm
i'll add that you don't necessarily have to pay someone for a tune to run a big maf. if you have a tactrix cable (i happen to have one for sale lol) you could do it with brzedit or romraider much, much cheaper than a vendor tune. oft would allow you to do it and use ots maps as well, or dyno tune in the future. ecutek is probably not a good choice if that is your only goal, but if you're wanting to do more tuning later it's where all the fun is these days.
if you're changing to any intake it will serve you well to check and likely scale the maf afterwards, whether it's 'big' or not. really even if it's still stock you would benefit from it. this is incredibly simple to do for anyone who can copy and paste things around excel, and will improve your drivability a bunch, specifically around very low throttle and parking lot speeds.
in the case of the perrin big maf they give you the calibration to start from, but you'll still want to confirm and fine tune it if necessary.
The Following User Says Thank You to jamesm For This Useful Post:
Old 01-07-2014, 03:15 PM   #5
wparsons
wparsons's Avatar
I'll definitely be tuning it at the same time, so that's not a concern. My question was more if it was worth the extra cost over the regular CAI which it seems it might be.
flickr
Old 01-08-2014, 12:15 PM   #6
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
With the "Stage 3" setup that we offer, the big MAF intake made roughly 4-5WHP more over the original intake we introduced.
Now, I know that isn't a direct answer for you, but your question is not really for me to answer. The gain to me personally, would be worth the extra money. I want the most amount of power that I can squeeze out of an engine. If you are the same way, then it's totally worth it
Keep in mind, when we have sales running, the price of the big MAF, is very good! You can also shoot me a PM if you have any further questions.
PERRIN_Mladen is offline   Reply With Quote
Old 01-08-2014, 01:44 PM   #7
Blood
Drives: 2018 STI
@PERRIN_Chris @PERRIN_Mladen
How often does the filter on your cold air intake need to be cleaned? Because taking off the front bumper every time the filter needs to be cleaned can be pretty tedious..
Blood is offline   Reply With Quote
Old 01-08-2014, 01:54 PM   #8
PERRIN_Mladen
Drives: '11 535i
We recommend cleaning it every 5-10K miles. I do agree about the bumper being a bit tedious, but stay tuned as we are working on something to see if we can help ease the pain of that step!
Old 01-08-2014, 02:55 PM   #9
wparsons
wparsons's Avatar
That would go a long way in convincing me to pick up the CAI portion. I've got 45k km's in 19 months (about 2500km's per month) so having to pull the bumper every 3-4 months could get tedious.
Sounds like I should be patient and wait until spring before pulling the trigger on anything!
flickr
PERRIN_Mladen (01-08-2014)
Old 01-08-2014, 03:08 PM   #10
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Yes, that would be very helpful. The black portion that clips onto the bumper wears out after several on-and-off removals, same with the bumper causing it to sag.
Did you guys take my advice and start making those quick-release button bonnet clips yet?
stevo_12v is offline   Reply With Quote
The Following User Says Thank You to stevo_12v For This Useful Post:
Old 01-12-2014, 06:22 PM   #11
wparsons
wparsons's Avatar
Can you access the filter from the bottom if you remove the under tray?
flickr
Old 01-12-2014, 07:32 PM   #12
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
If you're Stretch Armstrong maybe
Old 01-12-2014, 09:31 PM   #13
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
This was the ONLY thing that kept me from buying it!
The CAI looks really nice tho..
Carlitoz3 is offline   Reply With Quote
Old 01-12-2014, 09:37 PM   #14
Andrew025
Andrew025's Avatar
It's really not too bad after your first time and you learn where everything is.
I can probably take the bumper off in ~10-15 mins
The Following User Says Thank You to Andrew025 For This Useful Post:
PERRIN_Mladen (01-13-2014)
FS: Perrin headerback, Injen Intake and Perrin Pulley Boxer-86 Engine, Exhaust, Bolt-Ons 39 10-29-2013 10:32 PM
Anyone keen to swap their Perrin Unresonated mid pipe for a Perrin resonated one? Jigga Australia Classifieds 0 07-07-2013 12:35 AM
perrin pulley perrin intake tube Area51 Engine, Exhaust, Bolt-Ons 4 04-05-2013 06:11 PM
