Old 01-07-2014, 11:09 AM   #43
Anthony@RWHP
Anthony@RWHP's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Trmx2 View Post
I've got a question about the fuels from Renegade. Are they safe to use in a non-tuned DD car? I wanted to put 98 octane into mine. Would you recommend this or would it cause issues? The only mods I have to the engine are a performance air filter and intake tube. I am interested in the fuels especially if they are safe to use and will give me better performance. I don't want any issues with my cat or injectors or anything like that.
No race fuel will not give you better performance if you're not tuned for it. The whole point of the race fuel is the higher octane. Octane is the fuels resistance to igniting and the rate and control at which it burns. Higher the octane, the harder it is to ignite, and the slower it burns. The higher the octane you put in your car (assuming the pcm isnt tuned to take advantage of it) the less power you will make.
Sounds confusing, why would people use race fuel. Certain engines (high compression, forced induction, etc.) require a higher octane fuel to control combustion, and a tune with proper fueling and spark advance to run it.
Example.
Car A Is Turbocharged, makes 400hp on 93 octane with 11.4 air fuel ratio, and 14 degrees of timing.
That is the most power Car A can make on 93 octane because the fuel isnt stable enough to make more power, it will preignite and damage the motor.
Add 110 Octane to car A, lean the air fuel ratio to 12.2, and take the timing to 19 degrees, now car A safely makes 500hp
In order for Race fuel to make more hp in this application, you would have to add advance and lean the mixture in the tune.
besides the lead in it isnt the greatest thing for your oxygen sensors..
Best option is to run what the manufacturer recomends...
Next argument, "my car runs better on 93 even though they say to use 87". Likely you are running it up against the knock sensor, or other engine control, and the additional stability of the higher octane fuel allows the pcm to add more timing and lean the mixture to make more power.
This is basically the computer making the adjustments for you. The computer however can only make minute adjustments.
Anthony@RWHP is offline   Reply With Quote
The Following User Says Thank You to Anthony@RWHP For This Useful Post:
lbroskee (01-07-2014)
Old 01-07-2014, 11:24 AM   #44
Trmx2
Trmx2's Avatar
Drives: 2014 Raven FR-S 6spd
Example.
That was incredibly detailed and informative! Good to know.
In the case of the FRS, the manual states to use Premium Unleaded 93 Octane, which is what I use. So using the higher mixture would not give me better performance correct? I have heard the argument of "manual states to use 87 but I use 93 and my car runs better" but I've also heard of people damaging their cats after a while too.....a buddy of mine had a 1999.5 Jetta (non-turbo) and used 93 despite the manual stating to use 87 and at about 70k miles his cat eroded and it sounded like glass rattling when he drove. lol
I use what the manual states but there was a section saying for "hard driving conditions" a higher octane can be used. I was curious about that.
Trmx2 is offline   Reply With Quote
Old 01-07-2014, 11:59 AM   #45
USMC
USMC's Avatar
Drives: 2013 Scion FR-s
Am in. I will be on station.
USMC is offline   Reply With Quote
The Following User Says Thank You to USMC For This Useful Post:
Sportsguy83 (01-15-2014)
Old 01-07-2014, 03:38 PM   #46
Anthony@RWHP
Originally Posted by lbroskee View Post
b4 and after the drop
id love some te37sl but i don't have 4k for wheels
Sick! Love the color!
Old 01-08-2014, 02:44 AM   #47
mfbmike
Drives: 2013 FRS, 2008 R32
Don't think I'm gonna be able to make it. I have to work. doh.
mfbmike is offline   Reply With Quote
Old 01-08-2014, 08:07 AM   #48
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Old 01-10-2014, 10:56 AM   #49
Sportsguy83
Drives: Limited BRZ
Save the date!!
Old 01-14-2014, 10:46 AM   #50
Sportsguy83
Drives: Limited BRZ
Hope to see some Orlando and Tampa owners make it!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
TRobb (01-17-2014)
Old 01-14-2014, 10:47 AM   #51
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
hope to see ur new setup
lbroskee is offline   Reply With Quote
The Following User Says Thank You to lbroskee For This Useful Post:
Sportsguy83 (01-14-2014)
Old 01-14-2014, 10:59 AM   #52
Sportsguy83
Drives: Limited BRZ
Me too but that's a given baring something catastrophic happens.
The one I would REALLY want to see is @Frs300's car.
KAB-FRS (01-14-2014)
Old 01-14-2014, 11:04 AM   #53
lbroskee
lbroskee's Avatar
pfft fat chance. other then it not starting i hear the clutch is slipping on his FX400 and his HP isn't even at 500
Old 01-14-2014, 11:05 AM   #54
Sportsguy83
Drives: Limited BRZ
:facepalm:
Old 01-14-2014, 11:06 AM   #55
lbroskee
lbroskee's Avatar
:facepalm:
btw i no it's measured in TQ, but we don't know his TQ and I'm just saying i doubt it's over 500
Old 01-14-2014, 11:07 AM   #56
Sportsguy83
Drives: Limited BRZ
Yea I know what you meant. Facepalm for all of it, I mean ALL the facts of the matter regarding Brando's build.
SOUTH FL: Next Meet Discussion Sportsguy83 Southeast 28 12-31-2013 10:07 PM
Texas (south) meet and Track? Ryosuke86 Southwest 16 11-21-2013 11:11 PM
*******Central/South/North FL 86 meet! VADER Southeast 35 01-04-2013 01:26 PM
South Florida Car Meet List raul Southeast 0 09-24-2012 09:38 AM
South Florida Meet raul Southeast 4 09-10-2012 08:22 AM
