#603 | |
They help on all cars, but even more so when you are firming up the chassis with coilovers. Soft squishy OEM bushings become weak points. I usually say yes on swaybars too, you get a little more roll resistance and the ability to make quick/easy changes to the balance of the car. Better to tune steady state balance with swaybars than dampers. They aren't 100% necessary for every case though and it may be worth trying the car without them (easy to add later). - Andy |
#604 | |
No clue on how low any of them go. Sorry! - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | FRS Johnny (01-06-2014) |
#605 | |
![]() - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | ultra (01-06-2014) |
#606 | |
- Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | CSG Mike (01-06-2014) |
#607 | |
- Andy |
#608 | |
- Andy |
#609 | |
![]() - Andy |
#610 |
Vtec Jesus
Are kw clubsports / rce t2 twin tube or mono tube?
#611 |
#612 | |
Drives: Raven FRS
As for spring rates, no , wanted to see before what all modification on suspension had changed compare to oem setup, and try regain oem setup. |
#613 | |
That Guy
Drives: 2013 asphalt FRS MT
http://www.whiteline.com.au/product_..._number=W63225 |
| The Following 2 Users Say Thank You to Calum For This Useful Post: | normancw (01-06-2014), Racecomp Engineering (01-07-2014) |
#614 | ||||
I need to have that added to our site. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | normancw (01-07-2014) |
#615 |
Drives: 2015 WRX
I recently had an alignment done since I had my coilovers installed (amazing RCE T2's
) and I knew going in that I couldn't get perfect rear alignment because I didn't install any means of rear camber adjustment. I was surprised at how different the left and rear specs were so I went ahead and purchased the upper adjustable bushings at Myles suggestion. Got a call back from the alignment shop this morning in reference to their concerns to how difficult it would be align them. I sent over the install PDF from whitelines site and their concerns were eased some but noted that it would take longer than normal to adjust with these instead of a lower control arm. Regardless of their concerns, I do agree with Myles that these are the superior option because of the replacement of the soft rubber bushings with a poly bushing and the fact that adjusting the camber will not affect the toe like the lower control arms will.Anyway, my question is since the car is going to be on stands again while I get these installed I might as well replace other things at the same time since I'm going to need another alignment. I've been looking at the offset bushings from perrin for the front control arm to add caster. I've got the raceseng caster/camber top hats and I noted that on my alignment the caster was different on the left and right. I guess my goal is to get more caster with these bushing and then using the top hats to make them equal left and right. Is there a need to have them equal or is a couple of tenths off from one another ok? So, is there such a thing as to much caster on the front? Also, is there any other bushings that I should replace while I have the suspension apart again that will require an alignment if replaced that will be beneficial for a mostly street driven BRZ that will see a couple HPDE events a year? |
| The Following User Says Thank You to Malt For This Useful Post: | RJasonKlein (09-07-2015) |
#616 | |
Too much caster? No, but make sure your wheels clear your fenders! |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
