Old 12-30-2013, 04:42 AM   #1
JohnAyySays
JohnAyySays's Avatar
Drives: Scion FR-S Whiteout
Perrin 2.5 Exhaust Users
Hello everyone, so if you guys don't know I've been really looking into an exhaust and I've probably narrowed it down to a Perrin 2.5 Resonated catback exhaust. At first I was thinking of a 3" Perrin Resonated but I have then decided that I wanted to get some headers to get that boxer rumble.
For the Perrin 2.5 Resonated in general, how do you guys like them? Drive by sound and also down shift sound?
Also for people who run perrin catback with headers, which do you run and how does it sound. I really don't want a raspy sounding exhaust if I ever choose to go headers with my catback exhaust setup. Thanks again guys!
JohnAyySays is offline   Reply With Quote
The Following User Says Thank You to JohnAyySays For This Useful Post:
Chad86 (06-07-2016)
Old 12-30-2013, 05:20 AM   #2
etherealfall
Drives: Toyota 86 GTS Storm Black
Currently runs the Perrin catback res, sounds deep on start up but dies down pretty quickly. It's a catback that lets people know that it isn't silent but it is definitely not very loud. In fact, it is probably just a hair louder than stock but quite a bit deeper when you do hear it.
Not sure about drive by sound but my friends generally don't notice it. No noticeable down shift sound.
etherealfall is offline   Reply With Quote
The Following User Says Thank You to etherealfall For This Useful Post:
Chad86 (06-07-2016)
Old 12-30-2013, 06:45 AM   #3
FR-S Matt
This exhaust is all over Youtube. It's quiet till you pair it up with a catless header.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Chad86 (06-07-2016)
Old 12-30-2013, 08:20 AM   #4
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
I have the complete Perrin 2.5 system. Overpipe, catted front pipe, resonated mid pipe coupled to a Borla equal length header.
Not overly loud, little to no rasp, no harsh highway drone. I like it a lot.
Will note that I had to order and install the resonated mid pipe after installing the header. Without the resonator it was completely the opposite. Loud, raspy and drone. It was horrible.
FRSFirestorm is offline   Reply With Quote
The Following User Says Thank You to FRSFirestorm For This Useful Post:
Chad86 (06-07-2016)
Old 12-30-2013, 08:39 AM   #5
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
You can see what I have in my sig, I have 2 cats still in the system and it's loud where it should be, out the backend - in cabin it's not so bad.
Here's a few videos for you (Sorry for the boomyness - that's the GoPro mic for you):
Resonated Catback only, stock header/over/mid-pipe: [ame="http://www.youtube.com/watch?v=2JeIAMXDxEk"]BRZ Limited 4000 RPM Rev Limit, 1st/2nd Gear, Visconti tuned, perrin resonated cat back - YouTube[/ame]
Full system as on the car now, in car: [ame="http://www.youtube.com/watch?v=o-gFwloO1ag"]Subaru BRZ: Fall Drive - YouTube[/ame]
mikalem is offline   Reply With Quote
Old 12-30-2013, 11:41 AM   #6
ramiram1984
Drives: 2016 STi DGM
Contact me if you want a Perrin catted front pipe.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 12-30-2013, 02:10 PM   #7
pmccut
Drives: Blue Subarus
@Norcalmav23 had the 2.5" resonated Perrin with 3" OP + 3" FP + UEL headers and switched to the 3" Perrin resonated.
The car went from 'really damn loud' to 'slightly obnoxious'. It sounds really damn good with the headers. You should try and sync up with him since we're all local.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 12-30-2013, 08:30 PM   #8
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
I really want to hear the 2.5 res with catted headers.
Edit: but it's super quiet the engine/ wind noise is definitely louder than the exhaust in the 3-4K rpm range.. Hopefully once I'm past my break in period it's louder in the upper range!
It's probably one the quietest catbacks I've heard for any car. I think there are some stock cars louder!
calmtigers is offline   Reply With Quote
Old 01-06-2014, 11:05 AM   #9
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
If you don't go with new headers, get unres. I have it and love it. Sound is perfect and not obnoxious.
TONYpepperon1 is offline   Reply With Quote
Old 01-06-2014, 11:32 AM   #10
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
I run the resonated version and I also ran the nonres before. If you plan to do more work ie headerback and headers I would do the resonated. If you just plan to do catback, then nonres is great. While the resonated is pretty quiet by itself, when WOT it sounds amazing. You can be stealth at the same time if you want best of both worlds.
The Following 2 Users Say Thank You to Wes For This Useful Post:
Chad86 (06-07-2016), Kimsey47 (01-06-2014)
Old 01-06-2014, 11:41 AM   #11
skyre
Drives: 2013 Ultramarine Scion FRS
Anyone have an issue with their car making vibrating noises around the driver car visor area after installing the exhaust (Im guesing itll happen with any brand exhaust)? Happens around 2k RPM, once it goes past 2k its fine.
Pushing up against the area stops the sound, I may just put some padding in there.
skyre is offline   Reply With Quote
Old 01-06-2014, 11:51 AM   #12
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
Had the same issue, warranty took care of it. Only a few that I know of has this problem
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 01-06-2014, 11:51 AM   #13
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Agreed... I'll add that you will always hear it in the car though. You'll know its there as it is not as quiet as stock, but its not going to make your ears bleed like others I've heard. Absolutely love mine!
Subaru STI :
The Following 2 Users Say Thank You to Kimsey47 For This Useful Post:
Chad86 (06-07-2016), Wes (01-06-2014)
Old 01-06-2014, 12:00 PM   #14
skyre
Any idea what they did?
Perrin exhaust balla_08 Engine, Exhaust, Transmission 43 03-02-2019 10:57 AM
SpeedFactory V1 Exhaust VS perrin exhaust 21_nola_05 Engine, Exhaust, Transmission 18 06-19-2015 02:54 PM
Perrin Exhaust s14sleepyeyez Engine, Exhaust, Transmission 4 11-15-2013 02:01 PM
WTB: TRD or Perrin Exhaust ucsmfu Engine, Exhaust, Bolt-Ons 0 11-03-2013 02:39 PM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
