Old 01-06-2014, 06:54 AM   #337
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
So many different different aftermarket coilovers to choose from. I'm looking to get into autocross this summer. For a begginer like me, which coilovers would work best for me in autocross?
Carlitoz3 is offline   Reply With Quote
Old 01-06-2014, 09:37 AM   #338
CSG Mike
CSG Mike's Avatar
So you would recommend just getting another set of primacy hps?
It doesn'tneed to be another set of the OEM tires, but I'd recommend you stick to a relatively high performance tire, and with the brand names.
Falken FK453, Hankook V12, etc.
finch1750 (01-06-2014)
Old 01-06-2014, 09:38 AM   #339
CSG Mike
CSG Mike's Avatar
Originally Posted by leicaboss View Post
Hey thanks for the reply - I think 17's might do the trick - they certainly look better than stock
I don't want to change the dynamics of the car too much by pushing the wheels out though, any advice?
Don't worry about scrub radius or aerodynamic consequences of lower wheel offset. You'll know if you need to worry about it.
Old 01-06-2014, 09:39 AM   #340
CSG Mike
CSG Mike's Avatar
Stick to stock, until you know what exactly you want to change.
If anything, get yourself a front sway bar, and ONLY the front sway bar, for now.
Also, AutoX modding is typically mutually exclusive with track modding, when it comes to times.
Old 01-06-2014, 09:43 AM   #341
CSG Mike
CSG Mike's Avatar
Originally Posted by bukit View Post
Running stock tires with race pads on the track can be problematic. I did it this past weekend with Carbotech XP10s. The increased braking overwhelmed the tires so modulation was key.
Stock tires, race pads
[ame="http://www.youtube.com/watch?v=-r7EgQGxA4g"]Jackson Racing Supercharged BRZ Track Shakedown - YouTube[/ame]
Anthonytpt (01-06-2014), SuperDave (06-18-2016)
Old 01-14-2014, 12:29 AM   #342
t0mmyd
t0mmyd's Avatar
Mike,
I am planning to take my BRZ to the track for the first time. I want to keep the car stock for a while and get familiar with it before serious mods come in.
The only thing I'm planning to change for the track is:
Hankook RS3
Brake pads
Brake Fluid
Will this be efficient?
Would the stock rotors be fine? or would you suggest changing them too?
Also can you (or anyone here) suggest what pads and fluid would be good for a first time track session.
Thanks a lot!
t0mmyd is offline   Reply With Quote
Old 01-14-2014, 11:34 AM   #343
CSG Mike
CSG Mike's Avatar
Originally Posted by t0mmyd View Post
Mike,
Hankook RS3
Brake pads
Brake Fluid
Thanks a lot!
I'd recommend you get camber bolts too; they're REALLY inexpensive.
YGPM.
Old 01-14-2014, 01:24 PM   #344
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
I actually loved running the Hankook V12s this past season. Got a lot of compliments in the handling department for such an inexpensive tire setup.
PoorMansRacing is offline   Reply With Quote
Old 01-14-2014, 01:25 PM   #345
PoorMansRacing
Anorexic
Hey Mike, when would you recommend adding a rear sway bar?
Old 01-14-2014, 01:26 PM   #346
CSG Mike
CSG Mike's Avatar
If the car is understeering too much, and the owner doesn't want to change spring rates (or can't).
Old 01-14-2014, 02:52 PM   #347
mike the snake
I plan to AX and track my car occasionally.
So far I've added ST coilovers, lowered 1.5'', Michelin PSS 245/265 on Enkei Raijins 18x8.5 and 18x9.5.
Car should hopefully have around 300whp this week after turbo and tune.
I know going staggered with big rubber will cause more understeer, so I added a thicker rear swaybar (Perrin 19mm) to help (hopefully) neutralize the car.
Is my thinking correct? I haven't pushed the car to the edge yet, but I'm expecting understeer with my particular setup.
Old 01-22-2014, 10:52 PM   #348
T-dub
Drives: '13 BRZ
Got a track related question? I'll try to answer.
I just found out that I made standby at TWS this weekend, which I didn't really expect...I have ~1200 miles on the car, factory engine oil/brake fluid and a set of 17x9 +38 255/40 rs3 sitting in my garage that are begging to go.
I hate the Prius tires, but the other set seems like serious overkill for 160 hp car at a fast track. WWYD?
I thought I read in the manual that I shouldn't change the factory oil until 5k miles, but I don't feel right about leaving it in. WWYD?
T-dub is offline   Reply With Quote
Old 01-22-2014, 11:58 PM   #349
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I would put the tires on and leave the oil alone. The oil in the car is most likly a break in oil. High hp motors use these for about 20 min while they are broke in on a stand but due to a longer calmer break in they are probably putting in a lighter version of that in the twins. The tires will help even on a fast track and you will have a much lower chance of going off course. I waited until my car had some miles and the first oil change to track it but that was more me being over cautious as I have zero luck with subaru engines.
Sent from my Q10
Old 01-22-2014, 11:58 PM   #350
CSG Mike
CSG Mike's Avatar
Your thinking is correct, but I suspect you will also suffer from a LOT of understeer, and when you do get oversteer, it'll be a pretty hard snap from power-over.
I'd recommend you go to a square setup, and run a FRONT sway bar for faster transitions. It'll understeer through sweepers, but you'll make up the time in slaloms and then some.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
