Old 01-05-2014, 04:39 PM   #1
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Exclamation Crystal eye tails turn signal not working.
I've had crystal eye tails for 9 months noticed last night only the rear driver side turn signal is not working. After work I'm going to Tare down that light and inspect the connections.
This happen to anyone else? Any solutions?
Searching didn't net me anything useful.
FRSfan111 is offline   Reply With Quote
Old 01-05-2014, 11:20 PM   #2
FRSfan111
Woooowwwww. I'm a failure. Picked up some stuff for my store from anothe location. The boxes were a tight fit in my trunk and some how pulled the connection from the factory harness to the crystal eye harness loose. Everything works fine and I re arranged the harness with some zip ties so it won't happen again.
Almost had to buy a set of toms lol
Old 01-06-2014, 02:07 AM   #3
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Any issues with condensation in yours? Also see that your in Oregon. For awhile I thought I was the only one in Oregon with crystal eyes. Where are you located?
Chen is offline   Reply With Quote
Old 01-06-2014, 02:11 AM   #4
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
He was one of the 'First 86' owners. If you would come out to the tracks, you would have met him by now.
Old 01-06-2014, 02:28 AM   #5
FRSfan111
Ha, I'm in Gresham, work in Portland and I dive all over lol. No condensation in my crystal eyes at all!
Old 01-06-2014, 02:28 AM   #6
FRSfan111
Truth!
Old 01-06-2014, 03:40 AM   #7
Chen
Regional Moderator
Chen's Avatar
Hey shad up! I try to attend everything I can!
Lucky. 😑 mine have condensation in both, going to do a gasket replacement and see how that works out. Come out sometime. Would like to meet another crystal eye owner and leave these tom/stock owners in the dust!
Old 01-06-2014, 04:04 AM   #8
FRSfan111
Ha, truthfully no one I see in Oregon has crystal eyes either. Always toms, stock or spider tails. I need to get out too more meets.
Old 01-06-2014, 04:17 AM   #9
Chen
Regional Moderator
Chen's Avatar
Lol. Well at least we can say we are unique here in the nw and it would be a privlage for the few who do see them in person.
Old 01-06-2014, 12:10 PM   #10
RFB
RFB's Avatar
Drives: FRS
Crystal Eye condensation
Methinks ALL tail lights will eventually leak.
One of my Crystal Eyes developed condensation. The gasket WAS properly sealed to the light.
It was caused by the continual flow of water from around the trunk and into the gasket, eroding the seal.
There is a natural conduit under the black plastic housing at the top and rear of the lights.
I fixed it by sealing the housing to the car body with snow man snot (stationary store tack adhesive) thus channeling the water away, around and over top instead of under and into the gasket.
Still goin good fer 99 cents.
CERBERUS
RFB is offline   Reply With Quote
Old 01-06-2014, 01:01 PM   #11
Chen
Regional Moderator
Chen's Avatar
CERBERUS
Hmmmm. Ill have to look into that.. Thanks for thebheads up!
Old 01-06-2014, 02:40 PM   #12
RFB
RFB's Avatar
Drives: FRS
y w
Get a garden hose and spray the back window-
Watch the water flow from under the trunk and off the top of the tails.
Open the trunk, watch the water flow -
The location for the snot dam is obvious (make the water flow OVER the top black plastic rear housing rather than under and into the gasket).
Other than all the dust and leaves sticking to the snot, its a permanent fix.
It will even work with the poorly sealed stock tail lights (no water at the gaskets).
Well worth the 99 cents.
CERBERUS
Old 01-06-2014, 03:08 PM   #13
Iddoit2er
Drives: S
Anyway you can provide a pic to illustrate? Thanks.
Iddoit2er is offline   Reply With Quote
Old 01-06-2014, 03:23 PM   #14
FRSfan111
He's talking about the black part of the tails that like sticks out under where the trunk closes. Ill snap a pic.
My front turn signal lights not working after shop installed LED DRL bezel speedy racer Cosmetic Modification (Interior/Exterior/Lighting) 6 10-11-2013 05:08 PM
Crystal Smoked Front Turn Signals IgnitionGundam Cosmetic Modification (Interior/Exterior/Lighting) 16 09-18-2013 10:22 AM
CRYSTAL EYE Tails! JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 0 04-20-2013 11:09 PM
Turn signal problem Kai Uhl Cosmetic Modification (Interior/Exterior/Lighting) 12 03-21-2013 10:23 AM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
