Old 01-03-2014, 09:45 PM   #1
Dvulo7
Dvulo7's Avatar
Drives: Whiteout Scion FR-S
CLOSE THREAD
Hello all. Just got a muffler delete done. It is dual exit. Everything is stock on car including stock tips. Had a Y pipe done and just had the tips extended out a few inches from stock.
Cold start-sounds deep and rumbly a little rasp, but it settles down in less than a min.
Low rpm (up to 3k)-sounds deep and rumbly considering its a 4 cylinder.
High rpm(3k+)/gunning it- where should i begin....sounds like bees in a tin can + a tracktor + a kid blowing one of those party straws + a high pitched dirtbike...it can go on....
So my question is...how do i reduce this unbearable raspiness. Im beginning to regret ever touching the exhaust. I dont even gun it to past cars anymore since it sounds like a rice rocket. I even shift early to avoid hitting 3k rpm lollll.
Thanks in advance! Ill try to post pics and a vid sometime soon.
Dvulo7 is offline   Reply With Quote
Old 01-03-2014, 09:47 PM   #2
u/Josh
Drives: GBS Limited 6MT
Sounds like you have dual exits? I have a single exit muffler delete and think it sounds great.
u/Josh is offline   Reply With Quote
Old 01-03-2014, 10:01 PM   #3
sirsol66
Drives: 2013 FRS- Hot Lava
Very odd, as I've never heard a muffler delete that rasps. I have the berk and there's no rasp...
sirsol66 is offline   Reply With Quote
Old 01-03-2014, 10:16 PM   #4
Clalondeberg
Drives: 2013 frs
What I think you may have done and correct me if im wrong is delete both the muffler and the rear resonator. I too did the same thing to see how it would sound and it lasted a few days before I put a resonator back into the system.
Clalondeberg is offline   Reply With Quote
Old 01-03-2014, 10:19 PM   #5
Dvulo7
Dvulo7's Avatar
Yea it is a dual exit
Old 01-03-2014, 10:20 PM   #6
Dvulo7
Dvulo7's Avatar
I specifically asked for the resonators not to be removed, but ill take a look to see if they removed it or not. I know that removing them would increase the raspiness.
Old 01-03-2014, 10:36 PM   #7
hellyvin
Drives: WRB Brz
I have a Berk Dual exit delete, no rasp with no resonator. Not sure how much different my setup is to yours. I've heard adding the resonator will help. Also my exit delete, along with the drone I got toned down quite a bit after 500 or so miles.
hellyvin is offline   Reply With Quote
Old 01-03-2014, 11:09 PM   #8
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
It might sound raspy from in the cabin more so then from behind the car.
How are you guys finding the volume? Louder then most cat-backs? Or reasonable daily driver volume?
headlikeahole is offline   Reply With Quote
Old 01-03-2014, 11:18 PM   #9
Dvulo7
Dvulo7's Avatar
You guys dont get it. At pedal to the metal speeds it sounds like a really loud and obnoxious electric rc car. Im embarassed to drive it!
Old 01-04-2014, 12:32 AM   #10
"Sounds" like you may have to spring for an exhaust that has a muffler(s) in it ....
The Following 4 Users Say Thank You to humfrz For This Useful Post:
chrisl (01-04-2014), Marchy (01-07-2014), Wes (01-04-2014), wparsons (01-04-2014)
Old 01-04-2014, 12:41 AM   #11
Dvulo7
Dvulo7's Avatar
I have a feeling it might be the exit size. I left the stock tips. What if i change it to dual 4" exits like the berk one?
Old 01-04-2014, 12:53 AM   #12
tunami
tunami's Avatar
Drives: 2013 FR-S 6spd Whiteout
http://www.ft86club.com/forums/showthread.php?t=53447
tunami is offline   Reply With Quote
Old 01-04-2014, 01:01 AM   #13
koevasi
koevasi's Avatar
Drives: 1
put up a video and see if we agree with your assessment.
i've had my local welder experiment with all sorts of different types and sizes and it seems singles are always a lot quieter than duals. It's the resonance coming off of the empty well left where the muffler used to be - try to keep it single if you can.
not knowing what sort of y pipe is used in your case sort of difficult to comment..
my single exit muffler delete utilizes the stock 58mm (i think it was?) piping and uses a JDM tip and we have made it come out about an inch more out the diffuser - this has removed a lot of the in-cabin booming. note there should not really be any drone unless you remove the resonator.
fyi i am pretty sure i am not making any more power than stock - just louder.
koevasi is offline   Reply With Quote
The Following User Says Thank You to koevasi For This Useful Post:
Dvulo7 (01-04-2014)
Old 01-04-2014, 01:15 AM   #14
headlikeahole
Maybe try quickly removing everything from the mid pipe back and testing the sound quality with no tips. It could give you an idea of where the unwanted noise is coming from. If it still sounds like crap to you, then you probably need a muffler to be happy.
** obviously dont go driving around like this.
The Following User Says Thank You to headlikeahole For This Useful Post:
Dvulo7 (01-04-2014)
delete, loud, muffler, muffler delete, raspy
Muffler Delete SkitterSkotter Engine, Exhaust, Transmission 37 07-04-2017 12:44 AM
Muffler Delete project d CANADA 1 10-14-2013 01:43 PM
WTB: Berks dual tip muffler delete and cat delete pipe Black86 Want-To-Buy Requests 0 09-27-2013 09:31 PM
WTB Berk Dual Exit Muffler Delete or Works AB Delete Admired Want-To-Buy Requests 2 09-10-2013 04:20 PM
Muffler Delete sound without deleting muffler sw20kosh Engine, Exhaust, Transmission 10 01-30-2013 05:09 PM
