Old 01-03-2014, 08:20 AM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Exclamation Best battery for daily driver
Hey just wonder what the best battery out there would be with more than the stock 390 CCA. I'm having issues with the car going completely dead on start up so I have to reset the battery for it to work so I'm going to get a new alarm in and also a new higher powered battery since I have a bunch of led aftermarket work done to the car ....he dealership disconnected the security box when they put in my alarm and auto start so that could also be the issue ... Best battery with proper fitment and works well in cold weather
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 01-03-2014, 11:58 AM   #2
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Subaru and scion fit a 500 CCA battery to automatic equipped cars. Drop in fit in any BRZ/FRS.
Suberman is offline   Reply With Quote
Old 01-03-2014, 12:57 PM   #3
ScionFR-S
ScionFR-S's Avatar
The stock Panasonic battery is 390CCA so I can go up to 500? And also what size do I need or other specs before getting one
Old 01-03-2014, 01:12 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
I went with Optima Batteries YellowTop Dual-Purpose Battery, Group 75/25, 620 CCA
Model # D35 is the exact fit/polarity for our cars. It's normally around $230 but I bought it when I had a coupon for around $180.
Old 01-03-2014, 03:00 PM   #5
One of these would work good.
http://www.interstatebatteries.com/c...501-2147384906
However, I'd suggest you first find out what is draining your old battery .... ??
subwaynm (01-04-2014)
Old 01-03-2014, 03:23 PM   #6
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
This is the same battery I just got. It's so much better than stock.
post_break is offline   Reply With Quote
Old 01-03-2014, 04:00 PM   #7
raptor87
Drives: 2013 DGM BRZ Ltd
my Panasonic does not crank strong when its cold out it seems like a junk battery. I have a dash cam wired up with a power magic but I have disconnected it for the winter as I do not trust it.
raptor87 is offline   Reply With Quote
The Following User Says Thank You to raptor87 For This Useful Post:
Busybee (10-12-2019)
Old 01-03-2014, 04:55 PM   #8
ScionFR-S
ScionFR-S's Avatar
I found this on amazon this is it correct? What do I use to mount it ? [ame="http://www.amazon.com/Optima-8040-218-FFP-YellowTop-Group-Battery/dp/B006QH56GE"]Optima 8040-218-FFP YellowTop Group 35 Deep Cycle Battery : Amazon.com : Automotive[/ame]
Old 01-03-2014, 05:06 PM   #9
post_break
post_break's Avatar
Originally Posted by ScionFR-S View Post
I found this on amazon this is it correct? What do I use to mount it ? Optima 8040-218-FFP YellowTop Group 35 Deep Cycle Battery : Amazon.com : Automotive
Be careful. Optima has stated Amazon is not an authorized seller and will not warranty them. You'll pay more at Autozone but they will honor the 3 year warranty and replace it on the spot.
That's the correct battery. Mount it how you'd mount the battery you have in the car.
Old 01-03-2014, 05:36 PM   #10
ScionFR-S
ScionFR-S's Avatar
Yes I looked and found that , thank you for the heads up .... How do these mount ?
Old 01-03-2014, 07:02 PM   #11
Foobar
SLO NO MO
Foobar's Avatar
Precisely the reason I switched mine out. I also have a cam with a power magic and the repeated discharging to 12V eventually killed the Panasonic to the point where it was needing to be jumped.
Loosen the negative battery terminal connector, loosen the positive battery terminal connector, loosen the battery tie down, lift out the battery.
Take the new battery's top cover piece and attach it to the bottom (snaps right on to give it more height to match the stock size), put the battery in place, tighten the battery tie down, attach the positive battery terminal connector and tighten it, attach the negative battery terminal connector and tighten it.
Start the car.
With exception to the Optima cover piece attached to the bottom, these instructions apply to any battery you get. Also keep in mind that any Group 35 battery will physically fit, so long as the negative is on the left and the positive is on the right. If you get the polarity reversed, the existing cables won't reach without some serious hacking.
The Following 4 Users Say Thank You to Foobar For This Useful Post:
Busybee (10-12-2019), ScionFR-S (01-03-2014), slizoth (01-19-2014), subwaynm (01-04-2014)
Old 01-04-2014, 01:52 AM   #12
Poodles
Drives: 2015 Series.Blue
Keep in mind Optimas aren't what they used to be. They used to be made in the USA, now they're made in Mexico and their quality has gone way down.
LED stuff on the car isn't going to do much. LED's consume a fraction of a normal bulb, if anything you've lessened the load on the electrical system.
Old 01-04-2014, 02:56 AM   #13
subwaynm
subwaynm's Avatar
Drives: Scion FR-S Coupe
A new Battery is fine but as humfrs said check and see what is draining the battery down or the same thing will happen to the new Battery
subwaynm is offline   Reply With Quote
Old 01-04-2014, 07:24 AM   #14
Foobar
SLO NO MO
Foobar's Avatar
Still better than the stock Panasonic and most other crap on the market. There's a lot to be said for a 36 month replacement warranty.
Another battery to consider would be the Odyssey or DieHard Platinum (re-branded Odyssey).
New to me daily driver.. 95 M3. Dave-ROR Other Vehicles & General Automotive Discussions 58 07-17-2014 02:05 AM
Is your FR-S your daily driver? Drive Scion FR-S / Toyota 86 GT86 General Forum 136 02-10-2014 09:10 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 09:50 AM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
