Old 01-02-2014, 11:34 PM   #2479
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by Ryan86 View Post
Greetings Compliments Happy New Year may you have a awesome year full of zweeeee boost.
Some points to share, which I've encountered.
I hit cel PO351 coil pack cylinder 1. So I sent car into Toyota to change the coil pack and while doing so opted to change plugs while at it. Got the car back, according to my tuner I should be good for a further 10whp gain.
So happened we had a end of year dyno evening so I went down to check what the car would be pushing out.
I lost 10wkw to my previous run a week ago in cool evening temps.
When I got home I popped the hood and noticed the coolant bottle empty, I filled up and for the last 3 days after 20km drives I get back coolant bottle empty. I have pin pointed the coolant is coming out the coolant bottle cap.
We suspect the seals in the core have gone causing boost to force coolant out the bottle.
This may have been caused by the engine being lifted to change the plugs pulling on the coolant pipes.
Keep you posted on our findings.
Man you have had some luck with this kit. Bless your patience.
Did you have any symptoms prior to the coil pack going? from what I saw Bill at @DeliciousTuning has said, it seems theres a constant flat spot in power in the same RPM that throws no code, then after a while a code will come. I'm experiencing this "flat spot" right now, at first I thought it was the tune or maybe the car breaking loose just enough to where it wouldn't kick on the traction control light, but now i'm thinking its this. How much did the coil pack cost? I might just buy one to have in case.
Originally Posted by whataboutbob View Post
man, you couldn't post up all these damn fitting posts/info prior to me buying local brass fittings??
Thanks for sharing, unfortunately i've already replaced them but this is good for everyone else on the forum.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
whataboutbob (01-02-2014)
Old 01-02-2014, 11:38 PM   #2480
whataboutbob
AutoX-10/10ths every run
My motivation to find the fittings increased with the amount of down time on the car. I'm at 2+ weeks and going through SERIOUS withdrawls...
Build thread:Here
Old 01-02-2014, 11:41 PM   #2481
xxscaxx
cause of downtime?
right now for me, its the damn snow we are getting at the moment. suppose to get 8-10 inches tonight...
I know I used NPT fittings, but I made sure to spray the fittings to check for leaks and had none so I won't complain. But definitely would have used BNPT if I realized that prior.
Its funny, the NPT fittings I used to replace the plastic ones screwed in so much easier than the stock brass fitting in there that comes with the kit. Thing was TIGHT. I thought it wasn't correct at first lol.
Old 01-02-2014, 11:49 PM   #2482
whataboutbob
IC install. Here's photos of my pain.
Build thread:Here
Old 01-02-2014, 11:49 PM   #2483
DriftEm
DriftEm's Avatar
I guess you have checked this already but is the water pump working? I blew the fuse and same thing was happening to me, the coolant would over heat and come out of the bottle cap.
DriftEm is offline   Reply With Quote
Old 01-02-2014, 11:51 PM   #2484
DriftEm
DriftEm's Avatar
bob, better get that thing put back together before the autox
The Following User Says Thank You to DriftEm For This Useful Post:
whataboutbob (01-03-2014)
Old 01-02-2014, 11:53 PM   #2485
xxscaxx
anything holding you up or just limited time to work on it?
I am hoping I can just drop the plastic tray on bottom and not remove my bumper. Haven't taken it off yet and don't plan on it. Hate how it sags after removing it so much, I had this issue with my sti. I used quik latches on it after a while because the sag drove me crazy
Old 01-02-2014, 11:53 PM   #2486
xxscaxx
did you ever find out why the fuse blew?
Old 01-02-2014, 11:58 PM   #2487
whataboutbob
My plastic fittings were loose on the back of the blower. I tried to remove the plate on the bottom to get them off to tape/RTV them, but the bolts seemed like they were going to strip. I made a decision (somewhat hasty in hindsight) to use a dremmel to cut the old ones off thinking I could just go grab some new ones before I knew they were BSPT. I've been trying to get in contact with a company in the UK to order them, but with the holidays I wasn't having much luck.
I've just ordered the straight ones I linked to on McMaster-Carr and will use a 90 deg elbow to get it all connected together. The straight ones will let me put everything back together without having to take more parts off the blower.
Build thread:Here
Old 01-03-2014, 12:01 AM   #2488
DriftEm
DriftEm's Avatar
Innovate told me to check the ground, I took off the ground, cleaned the area and reinstalled it. So far so good, but I'm going to do what Bob did and install a relay box so I get power straight from battery.
Old 01-03-2014, 12:02 AM   #2489
xxscaxx
Damn dude, that blows! Hope you get everything back together quickly.
Old 01-03-2014, 12:04 AM   #2490
whataboutbob
Me too. I've got RCE T2s, Raceseng CASCAMS/Shock Tops, Whiteline bumpsteer kit, Mishimoto Oil cooler, SS brake lines, and a bunch of other misc stuff to finish after the IC is working.
Build thread:Here
Old 01-03-2014, 12:04 AM   #2491
xxscaxx
hmm..wonder how the ground would do that other than being loose or maybe a bad connection or something. I haven't looked at the installation guide in a while to see where that ground goes, but seems odd it would pop it.
Old 01-03-2014, 12:05 AM   #2492
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I have seen the coolant running through the bottle with ignition on, maybe I should take a pipe off and verify it's pumping.
Thanks for heads up.
Ryan86 is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
