View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 01-01-2014, 07:49 AM   #3529
ZZT86
ZZT86's Avatar
Drives: BR86
I would have thought no diff . . . . mechanical pump would be identical on all cars.
ZZT86 is offline   Reply With Quote
Old 01-01-2014, 09:35 AM   #3530
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
Originally Posted by 86chaser View Post
is automatic transmission affected by the cricket bug as well guys?
would appreciate a response man..
Have patience, man - just because nobody responded in 6 hrs since your first post doesn't mean that no one will. It's one of the biggest global holidays after all. Happy new year.
I have an AT and yes, it had chirping from about 2,500 miles. I got the latest pump revision installed a few weeks ago and they haven't returned yet.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
The Following 3 Users Say Thank You to wdninja For This Useful Post:
Marrk (01-01-2014), mit_peid (01-01-2014), Mr.EvoMR (01-01-2014)
Old 01-01-2014, 10:28 AM   #3531
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
is automatic affected by chirping too?
The High Pressure Fuel Pump (HPFP) on the engine has nothing to do with the transmission.
Why would you even ask this silly question. Might have as well asked, does this affect cars with white paint?
mwjcyber is offline   Reply With Quote
The Following User Says Thank You to mwjcyber For This Useful Post:
Old 01-01-2014, 10:34 AM   #3532
mwjcyber
mwjcyber's Avatar
To all the people saying my car build was in September, August, July, or whatever and now has the chirp, how can this be???
I say, unless you car has a build date around or after the revised TSB date (10/28/13), your HPFP will chirp. Please quit acting surprised your affected too.
Even the new TSB pump will likely chirp, but its insulation will greatly muffle it. And then there's talk of a new design in the works.
Have patience like everyone else who has this car, and if you like...request a new pump or file a complaint with your manufacturer requesting they resolve this.
Old 01-01-2014, 02:28 PM   #3533
Mr.EvoMR
Mr.EvoMR's Avatar
Drives: 2013 Scion Fr-s
YES.
Mr.EvoMR is offline   Reply With Quote
Old 01-01-2014, 05:41 PM   #3534
makesdrivingfunagain
that's funny, I have been using shell, and have had the chirp issue. Replaced the fuel system two times, it now does it louder than before. I should try a new gas station maybe
makesdrivingfunagain is offline   Reply With Quote
Old 01-02-2014, 05:06 PM   #3535
Neyzo
Drives: Firestorm Red FR-S
Took my car in on November 6th - was informed the parts would be on back-order due to a high demand (about the time the new TSB was released) and just finally had mine replaced today. So far a noticeable difference in overall sound and no chirps yet. Will continue driving and inspecting over the coming days to ensure it is totally chirp-less.
Neyzo is offline   Reply With Quote
Old 01-02-2014, 07:40 PM   #3536
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by Sigh-on-Rice View Post
44 days and 1520 miles after the pump was replaced.
I heard the crickets this morning.
It's hardly noticeable now, but it probably is because it's only the first day of chirping.
The original HPFP was replaced by the green dot HPFP on 5/22/2013.
Above quoted message was posted on 7/5/2013.
No chirp for the next 5 1/2 month.
Then around the Christmas time, it started to chirp very lightly.
It's been chirping very lightly for about 10 days now.
Posting this just for the record.
Old 01-02-2014, 08:24 PM   #3537
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
When I took my car to get it's first service, I brought up the chirping. The rep told me that Toyota was no longer replacing the fuel pump because the new pumps still have the same issue and Toyota was still investigating.
TruRace is offline   Reply With Quote
Old 01-02-2014, 10:29 PM   #3538
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
11XXX miles, no chirps still.
Proof
[ame]http://youtu.be/_fS9mPoS-XI[/ame]
Only used non ethanol 91 octane gas other than the one trip to Michigan where I had to fill up with 10% Ethanol gas.
Others swear by the gas not being the issue. Did I somehow get the Unicorn of the lot then that is sprinkled with Pixie dust? Doubt it.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
The Following User Says Thank You to Khazzy For This Useful Post:
Mr.EvoMR (01-02-2014)
Old 01-02-2014, 11:58 PM   #3539
TruRace
TruRace's Avatar
When I run E85 I get no chips. I am going to try to find some non ethanol gas to see if that does the trick.
Old 01-03-2014, 01:40 AM   #3540
Khazzy
Khazzy's Avatar
E85 seems to work well too.
Old 01-03-2014, 03:23 AM   #3541
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Gas hasn't changed much in the last 10 years, the issue isn't the fuel (which is a known design parameter) it's the design.
Think of a blender, one of those high powered ones that 'cuts through anything'.
The blender turns bananas into mush without hesitation, but it struggles with regular size ice cubes. Is the problem with the ice or the blender? Are you going to substitute cold bananas for ice forever? You could return the blender, modify the blender or realize that while it struggles it still blends the ice without any signs of damage.
18k miles, all E10 and zero chirps for the last 8k miles. Original pump, 12/12 build date.
ineedyourdiddly
Old 01-03-2014, 04:24 AM   #3542
Khazzy
Khazzy's Avatar
Then we have been blessed with remarkable pumps that do not cricket. I guess we will see how long I do not have crickets until I have to fill up with gas I usually do not. 93 is hard to come by in Nebraska.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
