Old 12-16-2013, 10:03 AM   #393
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Originally Posted by switchlanez View Post
Any rubbing on the inner fender liner at full lock? What's the reason you changed from the Hankooks to these?
It all depends how much camber your running. When I was running -1.5 I did run I the inside fender. Running a -2.4 running I don't have any issues. Hankook ran a bit narrow and wanted something that I could take on the track and would protect my rim from any damage on daily driving it. At 8psi 91 octane making about 270 at the wheels; the 275 are still fun to play with.
DesertFrs is offline   Reply With Quote
Old 12-16-2013, 02:14 PM   #394
quiet-k
quiet-k's Avatar
Drives: 2014 Hot Lava FR-S
Just more 255s...
17x9 +35 RPF1
255/40/17 Dunlop Direzza ZII
KW v3
-3 deg camber in the front / -0.4 deg (no adjustability yet) rear
quiet-k is offline   Reply With Quote
The Following User Says Thank You to quiet-k For This Useful Post:
Mr. (01-01-2014)
Old 12-16-2013, 02:21 PM   #395
ModBargains.com
ModBargains.com's Avatar
Originally Posted by mfbmike View Post
18x9.5 +40 sbc enkei nt03
265/35/18 michelin pss
More pictures of this!
ModBargains.com is offline   Reply With Quote
The Following User Says Thank You to ModBargains.com For This Useful Post:
mfbmike (12-17-2013)
Old 12-17-2013, 04:10 AM   #396
mfbmike
Drives: 2013 FRS, 2008 R32
http://www.ft86club.com/forums/showthread.php?t=46573
Getting a new camera soon hopefully so better pics to come!
mfbmike is offline   Reply With Quote
Old 12-18-2013, 06:09 PM   #397
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
i love my 35offset 17x8 rims with dat MEAT! 245/45/17
NYCsubaruBRZ is offline   Reply With Quote
Old 12-20-2013, 02:31 PM   #398
E46toFT86
Drives: IB '05 E46 M3 ZCP
You're the only person I've found on this forum close to the front tire/wheel size spec I've been looking for (been looking for Hankook V12 255/35 on 18x9.5 +45 and also V12 265/35). Do you think the front fender roll was necessary and what are your front height and camber settings?
So sorry for the delayed reply. Read it when you originally posted & completly forgot to come back and answer. Okay so to be honest with you I didnt take before & after measurements so I couldnt tell you the height measurements/difference between stock & my ride height now. As for fender roll as mentioned before I didnt roll any other part of any of my fenders except the front area near the sidemarker where it flares out a little bit. That being said, with the ride height I currently have it at & wheel/tire specs looking at the clearance it looks as if I can get away with NOT having to had rolled that area at all, but I did it to be on the safe side anyway.
I still have not had the chance to get a proper alignment so I'm not 100% sure on my exact camber settings. Although I can tell you I have STANCE Super Sport Coilovers & the front camber plates are currently set @ 0/ZERO. Looking at the rear w/ my ride height (fenders slightly above tires) not slammed by any means but low I'd say rear camber is under -3 but near that. Although I can tell you I know of a FRS with the same wheel/tire specs as mine & ride height just about the same who got a proper alignment and they dialed in camber @ -2 up front and -3 @ the rear.
'05 Interlagos Blue
E46toFT86 is offline   Reply With Quote
The Following User Says Thank You to E46toFT86 For This Useful Post:
switchlanez (12-20-2013)
Old 12-29-2013, 08:02 PM   #399
nlamon33
nlamon33's Avatar
Drives: 2013 SWP BRZ Limited
Just ordered some 18x9.5 +40 NT03's in flat black! Pumped. Plan on going 265's all around. Also have some coilovers on the way and currently have whiteline camber bolts on the car. Just looking over everybody's setups, it seems like these are pretty easy to fit with a tad bit of trimming and maybe some rolling up front by the marker.
Reading through here I'm curious are LCA's really necessary to make this work or is it really just helpful for getting a good alignment?
Thanks!
Nick
nlamon33 is offline   Reply With Quote
Old 12-30-2013, 02:58 AM   #400
mfbmike
18x9.5 +40
265/35 michelin pss
The Following User Says Thank You to mfbmike For This Useful Post:
armythug (01-25-2014)
Old 12-30-2013, 03:01 AM   #401
mfbmike
Thanks!
Nick
I wanted no drama and equal camber on both sides. Considering the "aggressiveness" of the setup, you want to be able to adjust camber in the rear. Too little camber and all the fender rolling in the world isn't going to stop the meaty tires from hitting fender during hard cornering or full compression.
There is no telling where your camber will be once you lower the car. The rear lca's let you dial it in. Better safe than sorry - everyone loves bacon. Noone loves bacon fenders.
Old 12-30-2013, 04:14 PM   #402
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Like
TouchMyHonda is offline   Reply With Quote
Old 12-31-2013, 03:45 PM   #403
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
18x9 255/40r18 all around +38 offset.
zoth is offline   Reply With Quote
Old 01-01-2014, 02:32 PM   #404
nlamon33
nlamon33's Avatar
Thanks for the info man! Checking into different LCA's now... The SPC rear control arm looks to be the cheapest, but doesn't offer a whole lot of adjustment. Don't know if 2 degrees of adjustment will be enough for me. Megan Racing would be the next option and they offer a lot more adjustment, and have a very similar design to all the high dollar LCA's for a great price. Anybody running those? I think that might be a good place to settle. Except they're pink.
Old 01-01-2014, 04:29 PM   #405
toby714
Drives: whiteout
I got the megan ones but blue. Ask the sponsors if they offer the blue one. Check my post I posted pics of my blue megan lca
toby714 is offline   Reply With Quote
Old 01-01-2014, 04:31 PM   #406
JS + BRZ
Drives: 2010 MS3
Looks awesome man. Is your car lowered?
Sent from my SCH-I605 using Tapatalk
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
