Old 01-01-2014, 04:08 AM   #15
Luis_GT
Originally Posted by missbrz View Post
well what kind of front pipe would you recommend since perrin discountinued ?
sorry for all the question i dont want to mess this up
Invidia, motiv, or hks... those seem to be the most popular.
The Following User Says Thank You to Luis_GT For This Useful Post:
missbrz (01-01-2014)
Old 01-01-2014, 04:10 AM   #16
missbrz
missbrz's Avatar
Drives: brz limited
Originally Posted by SoCal909 View Post
I've got the FT86 V1 non-resonated (from @FT-86 SpeedFactory), I like it a lot. but I want it a LITTLE louder I'll probably throw on a catted front pipe eventually.
it sounds good a little bit louder would be good , how much was that one ??
missbrz is offline   Reply With Quote
Old 01-01-2014, 04:11 AM   #17
missbrz
missbrz's Avatar
Drives: brz limited
sounds good well thank you so much from the advice
whats you next move on the car ??
Old 01-01-2014, 04:15 AM   #18
Luis_GT
No problem
my next mod might be lowering springs... still undecided on that though.
Old 01-01-2014, 04:17 AM   #19
missbrz
missbrz's Avatar
Drives: brz limited
No problem
yeah i would like to do that also , i have a question what are coilovers ?
Old 01-01-2014, 04:31 AM   #20
Luis_GT
They are height adjustable struts basically, lowering springs you are limited to a set height designed by the springs, coilovers have a threaded body with nuts that allow you to raise or lower the springs.
Old 01-01-2014, 04:33 AM   #21
missbrz
missbrz's Avatar
Drives: brz limited
so coilovers are better than the springs ?
Old 01-01-2014, 05:20 AM   #22
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
Check out ft86speedfactory.com they've got almost every thing for our car
SoCal909 is offline   Reply With Quote
The Following User Says Thank You to SoCal909 For This Useful Post:
Old 01-01-2014, 05:28 PM   #23
Yikes, missbrz, hold up a minute ......
Now, you don't have to follow ol @Luis_GT down every pig path he takes......
Before you go throwing money into a perfectly good car, for average driving, I would suggest you ask yourself this question "What do I want my car to do, that it doesn't already do?"
Your answer will lead you to the "appropriate" modifications.
So, what do you want your car to do ..... better, if anything?
(Hesh up, Luis_GT ...... your a bad infulence .... .....)
Luis_GT (01-01-2014), PoorMansRacing (01-02-2014)
Old 01-01-2014, 05:33 PM   #24
Luis_GT
depends on what you want to do with your car. Coilovers have a wider range of adjustment, but at the same time it requires more patience and know-how to set them up correctly.
Old 01-01-2014, 05:37 PM   #25
Touge_ninja
Sending rods to their doo
Touge_ninja's Avatar
Drives: 700HP STi
So far the following:
BC Racing Coils
Perrin Shorty Antenna
Perring LWP
AVO Over pipe
J2 Catted front pipe
Invidia N1 catback
OEM GT86 style touch screen deck
AVO Stage 1.5 Turbo
SPC Lower Control Arms
Touge_ninja is offline   Reply With Quote
Old 01-01-2014, 06:35 PM   #26
missbrz
missbrz's Avatar
Drives: brz limited
your right !
im not ganna go the same path , just would like to know my options
Old 01-01-2014, 06:35 PM   #27
missbrz
missbrz's Avatar
Drives: brz limited
BC Racing Coils
Perring LWP
AVO Over pipe
Invidia N1 catback
AVO Stage 1.5 Turbo
does the perrin short antenna get good reception ??
Old 01-01-2014, 06:41 PM   #28
Touge_ninja
Drives: 700HP STi
i'll be honest. i never use my radio so its only there for looks. mostly have my iphone connected.
