Old 12-31-2013, 06:32 PM   #1
Trac Toy
Trac Toy's Avatar
Front bumper material?
What is our front bumper made of? I picked up a front bumper that is cracked but relatively easy to repair.
Polyurethane?
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 12-31-2013, 06:55 PM   #2
jonbonazza
Haven't had mine off, but just about every car on the market in the past 10 yeasr has had polyurethane bumpers. i can't imagine ours is any different.
jonbonazza is offline   Reply With Quote
Old 12-31-2013, 07:17 PM   #3
FirestormFRS
If it's poly it's the most brittle poly in the history of poly. They break really easy.
FirestormFRS is offline   Reply With Quote
Old 12-31-2013, 07:20 PM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
You aren't supposed to repair a cracked bumper.
Old 12-31-2013, 07:30 PM   #5
Trac Toy
Trac Toy's Avatar
Not talking the steel crash bar. The plastic cover. Figured it was polyurethane but wanted to be sure.
Thanks guys!
.o0+Eric+0o.
2013 FRS 6MT
Old 03-12-2024, 02:09 PM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Old thread but was trawling the forums looking for this information because I'm in the process of making some repairs myself. I though it was worth making a correction:
The bumpers are made out of polypropylene (PP). It's clearly stamped on the part (this type of material information can be found stamped on almost every plastic part on the car.)
Knowing the bumper is made of PP is critically important because it's a Low Surface Energy (LSE) material: most adhesives/epoxies/glues don't work on it, especially if you need the repair to be strong and hold load.
There are specialized structural adhesives out there that are made to work with PP, but you need to know what to look for AND they tend to be expensive (3M DP8005 / DP8010 and Infinity Bond MMA 500). Your budget option is to use a primer (like Loctite 770) and cyanoacrylate glue (i.e. super glue) BUT usually a repair like this won't be strong unless you have a really close fit and get it put back together with precision.
EndlessAzure is offline   Reply With Quote
The Following 4 Users Say Thank You to EndlessAzure For This Useful Post:
HKz (03-12-2024), Ohio Enthusiast (03-12-2024), sugoi (10-24-2024), Wally86 (03-13-2024)
Old 03-12-2024, 02:40 PM   #7
Ohio Enthusiast
Drives: 2018 BRZ
On the other hand, PP lends itself very well to plastic welding. I've repaired several household items with a cheap soldering iron and some doner PP (from plastic jar lids). Using a purpose made plastic welder should work much better.
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
EndlessAzure (03-25-2024), Wally86 (03-13-2024)
Old 03-25-2024, 09:41 PM   #8
EndlessAzure
Wheels for Brains
Decided to try using plastic welder for one of the repair tasks (rebuilding a completely lost tab). Worked pretty well with an Amazon soldering-iron-style kit. My first time doing a plastic weld. Intimidating at first and a slight learning curve but the end result was satisfactory and strong. Soldering and welding principles are key (as well as good ventilation) - maintaining material wetting/flow to get a proper fuse is a must. It pretty much needs to be formed continuously which can be challenging as you add more and more material. If you just add more material on top gradually - like dolloping play dough - the layers don't bond and just snap when you bend it.
Splurged on 3M DP8010 for other tasks. Amazing stuff: a strong bond even across a thin edge glue line. Used it to glue back the fender liner bolted tab that got snapped-off completely (red damage circle). I went back afterward and reinforced it with a single sheet of fiberglass soaked in the same adhesive to provide some additional strength against flex/peel mode.
Finally it's worth nothing that DP8010 (and other similar adhesive) isn't good for repairs that have very close clearance and where you can't bring the parts together to trap the adhesive in between (e.g. a slip formed by a thin crack, green damage circles). The adhesive is pretty thick and you end up just squishing the adhesive out of the gap, leaving barely any to make a bond. For these cracks, I ended up using Loctite 770 Primer with Prism 401 superglue which wicks extremely well and forms a strong bond. Hoping the tightness of the fit will help the joint hold up to flexing over time, but we'll see. If it doesn't hold, I'll go back and plastic weld them with steel mesh.
The Following User Says Thank You to EndlessAzure For This Useful Post:
bcj (03-26-2024)
Swap my BRZ front bumper for your FR-S bumper (GBS/ultramarine) wulfgang Exterior Parts (Aero, Lighting, Etc.) 8 11-26-2013 07:48 PM
WTB: BRZ PS headlight, hood, front wide fenders, front bumper/ body kit Guildjs Want-To-Buy Requests 5 10-31-2013 09:35 PM
Wtb brz headlights and a white front frs front bumper post to Australia. jet86 Want-To-Buy Requests 0 08-20-2013 09:27 AM
WTB: Front BRZ WRB Bumper scraejtp Exterior Parts (Aero, Lighting, Etc.) 2 12-23-2012 09:56 PM
Other than SR front bumper this is the only other one I like Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-09-2012 04:30 PM
