Old 12-06-2013, 11:05 PM   #1
frstn
frstn's Avatar
Drives: 2013 FRS
Arrow need help with rear defroster
does anybody know where the rear defroster plugs in? it won't work and I believe it's not connected because when I bought the vehicle the 3rd brake light was also disconnected but that was visible. I cant seem to find the rear defrost plug. anybody?
frstn is offline   Reply With Quote
Old 12-07-2013, 12:33 AM   #2
Have you checked the fuse .... ??
(#8 in the fuse box under the hood - 30 Amp)
humfrz is online now   Reply With Quote
Old 12-31-2013, 10:30 AM   #3
frstn
frstn's Avatar
Drives: 2013 FRS
fuse is good. anybody know where it connects? anybody??
Old 12-31-2013, 11:52 AM   #4
infinite012
Drives: 13 DGM BRZ Ltd
More than likely it connects somewhere behind the C pillars, but obviously you already checked there because you've exhausted all other options.
Right?
infinite012 is offline   Reply With Quote
Old 12-31-2013, 12:16 PM   #5
Well, here is a picture ..... which isn't much help ....
Old 12-31-2013, 04:28 PM   #6
andrew20195
Drives: 2013 Subaru BRZ
Looks like the connectors are on the top left and top right corner, either behind the C-pillar or headliner, according to my service info. According to the image @humfrz posted above, it looks like there is a connector behind the right C-pillar. So I'd start with the pillars.
andrew20195 is offline   Reply With Quote
Old 01-12-2014, 10:40 AM   #7
frstn
frstn's Avatar
Drives: 2013 FRS
I'll check that and let you know what I find. Thanks guys
Old 01-12-2014, 02:22 PM   #8
jdubious
Drives: 13 Scion FR-S
are your windows tinted? Those guys have a bad habit of slicing through the element(what ever those lines are called). might get a flashlight and look to see if any are damaged
jdubious is offline   Reply With Quote
Old 04-04-2014, 10:48 PM   #9
frstn
frstn's Avatar
Drives: 2013 FRS
Yea they are. He might have damaged the lines, I have to check but I haven't got to take the pillars off yet it's been too cold. I'm installing speakers soon so I will do it at the same time.
Old 04-15-2014, 03:16 AM   #10
frstn
frstn's Avatar
Drives: 2013 FRS
It was disconnected. Behind the driver side rear c piller is where the defrost connection is. Thanks for the help
USDM - Rear foglight indicator in cluster? Trying to do a quality rear fog light inst nalc Cosmetic Modification (Interior/Exterior/Lighting) 8 12-10-2015 04:48 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
Decal/sticker over defroster lines? samers66 Scion FR-S / Toyota 86 GT86 General Forum 5 09-23-2013 12:18 PM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
ecutek map switching defroster ft86me Software Tuning 8 08-04-2013 02:09 PM
