#15 | |
Drives: Toyota 86
From where I'm from, reverse fog lights are ok because half of the year we have heavy rains and a lot of PUVs and old cars don't have proper head/fog lights. I wasn't implying that people were wiring them wrong on purpose to look cool. I was just confused why/if the JDM, USDM and EDM seemed to operate differently out of the box. I've been thinking about getting these for about a week now. I just wanted to see where I should order from. |
| The Following User Says Thank You to trustyler For This Useful Post: | Killerbee (12-30-2013) |
#16 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
About the "wiring" issue of JDM/USDM/EDM, its not so much the lights, but the car that differs. The Taillights for JDM differ from USDM/EDM, so JDM seems to have turning signal/braking lights turned upside down. USDM/EDM however work as intended out of the box (and also the JDM is just changing out 2 cables to get them wired right) If it comes to the rear foglight the question is really if your car was equipped from factory with a rear foglight. If yes, the Valentis will work plug n play. If no, then you will have to buy the Rear Foglight kit (there are some sellers for that around here) to get the wiring/switch for the rear foglight, and then you can mount the Valentis Foglight with no issue. Alot of ppl do however just connect the Valentis Foglight to the normal light of their car which results in the wrong wired lights you see around. As for a good seller to get Valentis from, I can recommend @pansontw as I know at least 5 ppl (including myself) that did order from him, and he always keept us informed and delivered on time as promised.
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
| The Following User Says Thank You to Killerbee For This Useful Post: | trustyler (12-30-2013) |
#17 |
On USDM cars if you have front fogs with a stalk/switch, you can just wire the rear fog to the front fogs. That way you can just shut them off by shutting all fog lights off. That's the way mine is wired.
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
#18 |
Just a dude
Drives: Scion FR-S 2013
Here are how mine look and work, including valenti bumper light.
http://www.ft86club.com/forums/showp...6&postcount=68
| The Following User Says Thank You to OICU812 For This Useful Post: | trustyler (12-30-2013) |
#19 | |
Drives: Toyota 86
By the way, sorry to op for kinda jacking your thread. I like your combination and have the same questions. Thinking of getting them myself. Its either I'm going with the smoked set or just go with Toms or continue to live with my peeling tinted tails. Lol! |
#20 |
I would think you can open it up and disconnect the wiring to the triangle only, it doesn't satisfy your first preference, but it would satisfy the second. You could probably open it up and either tint the inside of the plastic or black it out with electrical tape.
On the topic of brightness, I bought and installed the smoked version on my FR-S this weekend. I have the stock tail lights and as far as I can tell, in the dark, the brightness for the triangle is as near as makes no difference to my tail lights (without braking). The only thing that leaves for me is the blinking portion which I'm guessing is much less of a deal than people are making it out to be. I am a conservative braker (even in traffic) so I don't think constant blinking is going to be that much of an issue. What I would love to see is a DIY guide to adding a normally open (I think that's the right way of saying it) accelerometer that closes when sensing greater than 1G acceleration (or in this case, deceleration). In that case we can run that in the brake light wire and we'd get that as a warning for heavy braking situations. |
#21 |
your pictures are farking huge.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#22 |
Drives: Scion FR-S
I wrote a DIY on the wiring a few months ago. Search for "valenti rear fog alternate wiring" to see if my setup is what you would like. I would link it but I'm on my phone
| The Following User Says Thank You to Gundark For This Useful Post: | PSJohnDoe (01-01-2014) |
#23 | |
1337
Drives: 2013 BRZ WRB S/C
http://www.ft86club.com/forums/showthread.php?t=47409 There you go. Looks like this is what the OP is after. Looks much better this way IMO. |
#24 |
Drives: Scion FR-S
I agree I think it looks much cleaner this way. Thanks for posting the link!
#25 |
Drives: '14 SWP Limited BRZ
I'm very close to purchasing Smoked Tails, but I'm worried about the legality in OR. I've seen it both ways. Have you been pulled over?
#26 | |
Drives: fr-s
Eat your vegetables.. |
#27 | |
I am having a serious internal debate about which to get. I have an SWP BRZ. I love the look of smoked when they are on, but the tail lights just look too black when the car is off. Meanwhile, the Clear/Red ones look to white and I think being able to see the LED tube makes them look really cheap. Should I get the smoked, or do I go clear and get them smoked so they are a little less darker?
| The Following User Says Thank You to 503 BRZ For This Useful Post: | evan (03-03-2014) |
#28 | |
Drives: fr-s
).Eat your vegetables.. Last edited by evan; 03-03-2014 at 01:30 PM. |
| The Following User Says Thank You to evan For This Useful Post: | 503 BRZ (03-03-2014) |
| [GB Closed]Group Buy on Valenti LED Tails | pansontw | Groupbuys | 363 | 12-22-2013 09:51 PM |
| BC tails and Valenti reverse? | kALMIGHTY | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 12-17-2013 04:31 AM |
| "LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" | F-T | Exterior Parts - Lighting | 187 | 05-15-2013 01:07 AM |
| Valenti Tails & Reverse Lamp | JPxM0Dz | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 04-27-2013 10:06 AM |
