Old 12-29-2013, 01:17 AM   #15
OrbitalEllipses
Drives: Attitude
I believe we'll have issues with the turbo where it's mounted and the IC...after having to re-do those, your choice of FI kit may be cheaper. We'll see once the 2015 WRX hits the ground and n00bs start wrecking them.
Originally Posted by WiebTech Performance View Post
I'm very curious what Subaru is going to do to combat the carbon build up on the back of the valves that comes from only having direct injectors. BMW and GM are already having lots of issues with this.
Air/oil separator.
The Racers Line (12-29-2013)
Old 12-29-2013, 06:56 AM   #16
Calum
That Guy
Drives: 2013 asphalt FRS MT
As an aftermarket solution maybe, but a catch can would never come stock.
While an air/oil separator isn't common they do exist in factory cars. Hell, the 95 neon came with one.
As for the fa20dit, this has been discussed ad nauseum. IIRC, the rods and crank are the same. The pistons are hypereutectic, not forged, and don't have the proper crown shape for our spray pattern. The block has the starter on the wrong side and the turbo manifold won't fit as it will interfer with the body on our cars.
What I haven't seen covered yet is the differences in head flow, the valve train, and how the newer combustion chamber will do with knock resistance.
Old 12-29-2013, 10:07 AM   #17
xjohnx
Grip>Slip
xjohnx's Avatar
Exactly. Anyone who thinks Subaru hasn't considered this may not be paying enough attention.
Source: http://appft1.uspto.gov/netacgi/nph-...DN/20120080015
Calum (12-29-2013)
Old 12-29-2013, 12:10 PM   #18
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Awesome stuff. I wasn't doubting they would find a solution, just curious what it would be. Kinda cool to have a group of internet Sherlock Holmes's at your disposal.
The Racers Line is offline   Reply With Quote
Old 12-29-2013, 03:12 PM   #19
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
I would like to get a close up look of the size of the DI injectors on the wrx engine. it would be nice if they fit the fa20 for FI applications as they most likely are larger. Audi/VW 2.0t FSI guys upgrade their stock injectors to S3 or RS4 direct injectors when going larger turbo. Maybe coupled with the WRX HPFP as well we can see some interesting results when tuned properly with the already available port injectors.
PrimeMotoring is offline   Reply With Quote
Old 12-29-2013, 03:21 PM   #20
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Well if this is true:
...Then likely the direct injectors from the wrx would not work with our piston bowls becuase of the difference in spray pattern. But who really knows untill someone gets their hands on one to play with.
WHITE is offline   Reply With Quote
Old 12-29-2013, 03:24 PM   #21
D K
Stig's dark passenger
Does anyone know the rod length and compression height of the new engine?
D K is offline   Reply With Quote
Old 12-29-2013, 08:08 PM   #22
Calum
That Guy
http://www.ft86club.com/forums/showthread.php?t=47004
Old 12-29-2013, 11:04 PM   #23
xwd
Originally Posted by hmong337 View Post
Another reason why I think it wasn't Subaru ditching the d4s but rather Toyota wanting to keep that technology firmly in their grasp. Toyota's a business and one of the most successful in history. I can't see them handing over all their d4s tech that they took years to develop to a partner/competitor that never had any DI tech prior who can potentially use it for their own interests.
Subaru started developing DI tech a long time ago, but it was never meant to be used in a NA application. They first used DI in a turbo diesel engine in 2011. The FA20DIT was being developed before the 86 FA20. It was used in the JDM Legacy in like May 2012.
Old 12-29-2013, 11:26 PM   #24
WHITE
Thats pretty neat
WHITE's Avatar
Correct me if im wrong but wasnt the ee20 turbo diesel unveiled in like 2007-2008?
Old 12-30-2013, 01:52 AM   #25
OrbitalEllipses
Drives: Attitude
NASIOC does most of my sleuthing for me. That patent for the AOS design has been known for ~2 years or so.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
The Racers Line (12-30-2013), xjohnx (12-30-2013)
Old 12-30-2013, 06:29 AM   #26
Calum
That Guy
Has there ever been a diesel engine that didn't use direct injection?
Sent from my GT-S7560M using Tapatalk
Old 12-30-2013, 09:04 AM   #27
WHITE
Thats pretty neat
WHITE's Avatar
Actually, let me introduce you to the IDI. Indirect injection diesel. Found most comonly in the old ford 7.3l non powerstroke.
The Following User Says Thank You to WHITE For This Useful Post:
Calum (12-30-2013)
Old 07-26-2020, 01:20 AM   #28
Jameson86
Jameson86's Avatar
Drives: Black Toyota 86
It seems like it has come standard on the fa20dit...
Jameson86 is offline   Reply With Quote
Dynosty Turbo FR-S FA20 Highest Horsepower Record 324WHP Hal@Dynosty Forced Induction 363 11-19-2014 10:03 AM
FA20 Turbo? slidethis Forced Induction 23 09-27-2013 11:55 AM
FA20 or 4U-GSE ??? WesFRS Engine, Exhaust, Transmission 2 04-25-2013 04:17 AM
new jdm legacy B4 uses FA20 turbo cyde01 Forced Induction 3 07-26-2012 02:00 AM
HKS s/c FA20?? Rome Scion FR-S / Toyota 86 GT86 General Forum 6 04-04-2012 12:13 PM
