Old 12-27-2013, 05:12 PM   #29
zenki_levin
Road Warrior
zenki_levin's Avatar
Drives: AE86 Levin
I think i a saw a truck somewhere that can run on any old oil, petrol, diesel, kerosine etc. So that would probably be a safe choice.
zenki_levin is offline   Reply With Quote
Old 12-27-2013, 05:32 PM   #30
Shagaliscious
Drives: Firestorm FR-S (MT)
Originally Posted by BlueDubbinTDI View Post
a boat
Don't forget the hoes!
Old 12-27-2013, 07:35 PM   #31
Joakim3
Joakim3's Avatar
Drives: 04' Saab 9-5 Aero
Go military then, I know the Abrams can run off of damn near anything burnable, I think they put cooking oil in one just to prove a point lol
Joakim3 is offline   Reply With Quote
The Following User Says Thank You to Joakim3 For This Useful Post:
zenki_levin (12-28-2013)
Old 12-28-2013, 07:06 AM   #32
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Originally Posted by n2oinferno View Post
Can I come? We can bring t-pain.
Don't forget your flippy floppies!
Old 12-28-2013, 11:23 AM   #33
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
There were a few zombie apocalypse mobiles at SEMA this year, like this one:
Perihelion is offline   Reply With Quote
Old 12-28-2013, 12:09 PM   #34
serialk11r
Drives: '06 AM V8V Coupe
Turbine might be a problem when maintenance time comes, it guzzles a huge amount of fuel at idle/low load, plus walking outside to get fuel for that thing would be pretty dangerous.
The Following User Says Thank You to serialk11r For This Useful Post:
LSxJunkie (12-29-2013)
Old 12-28-2013, 02:29 PM   #35
Joakim3
Joakim3's Avatar
Yeah that would be the main issue.... but the walking outside part could be covered via the your buddy on the 50 cal. Disregarding my inner urge to be Rambo blasting horde of zombis with a 121mm tank round during an apacolypse if this where to happen I (and anyone else for that matter) want to either be A) as mobile as humanely possible or B) be someplace where nothing can get to you in the first place.
If it's A)
I'd go anything diesel. WAY more range and because diesel itself can function after years of being stagnant which regular petrol can't do. I'd think a F-150 with a extended range option and a secondary fuel tank, massive mud tires, front grill, mega light kit, and an armada of weapons in the back lol. That or a military diesel vehicle would suffice (Challenger 2 tank )
If it's B)
Find you a couple of buddies, go to the nearest marina and take the biggest boat you can find, and park that bitch in the middle of the harbor. Learn to fish = profit
Old 12-28-2013, 02:51 PM   #36
EJ20
EJ20's Avatar
Drives: NA8C, GDB, and R50
My current uzj200 with tough dog lift, 33's and snorkel kit (will go for it soon )
EJ20 is offline   Reply With Quote
Old 12-28-2013, 04:43 PM   #37
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
It's weird, I see everyone's choices and clearly no one read Max Brook's "Zombie Survival Guide" book.
I'd get a minivan with a sun roof.
Reasons:
- Relatively fuel efficient compared to trucks
- Has large holding capacity and can tow slightly in a pinch
- Is large enough (possibly for ramming through a crowd)
- Sunroof allows for sniping from the top (kiting them zombies)
- In a pinch, windows can be opened and made into a mini fortress
- Relatively common therefore parts can be salvaged
- Usually reliable or can be easy to fix
Whoever posted the Abrams isn't thinking long term - it runs on jet fuel no? Where are you gonna get jet fuel in an apocalypse? I can siphon fuel off other cars.
Come to think of it, is there a hybrid minivan?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 12-28-2013, 04:53 PM   #38
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Reasons:
JP8 the most common jet fuel is really similar to a low grade diesel fuel. I was a jet mechanic for 5 years. But besides that I vote astro van.
Sent from my Q10
Old 12-28-2013, 04:59 PM   #39
Frost
Frost's Avatar
Sent from my Q10
Yeah but still far less common than straight up regular gasoline
Also, cannons are useless against zombie! Kill-to-expense ratio is ridiculously poor.
If you know guns, what would you recommend for something that can penetrate the skull but NOT go through one (you want it to ricochet inside to guarantee dead zombie brain)?
Old 12-28-2013, 07:49 PM   #40
serialk11r
Pretty sure you can put gasoline through a turbine engine. Vegetable oil, heating oil, pretty much anything works. The problem is that the Abrams would suck it up so fast you'd be refueling all the time and you'd need to siphon a LOT of trucks and cars to fill the tank.
I think minivan is a good choice except they don't have diesel engines. I'd get a diesel BMW X5, it's got a sunroof, pretty high off the ground, a vat of leftover veggie oil can power it for thousands of miles.
Old 12-29-2013, 09:36 AM   #41
Accurate Race Shop
Drives: Scion FR-S
As far as the gun goes I would have to say a .22 as it is the most common round in the world.
Sent from my Q10
Old 12-29-2013, 10:56 AM   #42
Frost
Frost's Avatar
Originally Posted by LSxJunkie View Post
.22LR is also a rimfire. I've had tons of misfires with .22LR. That said, it is no worse an option than .223/5.56 in terms of brain destroying power at the kind of ranges that you'll be seeing in zombie defense scenarios. A decent older reliable 10/22 would be a good weapon to have around. I'd still have a 9mm pistol as a backup, again, because of ammo availability, and a 12ga shotgun. I'd probably try to find a 6.8 or .308 gun too.
Up here in Canadia, gun laws make me far less experienced with firing different sorts of ammunition compared to our US counterparts.
BUT I've fired .22 rounds when I used to be part of the rifle club and I encountered a misfire at least once every weekly visit where I would fire off roughly 40-50 rounds. That sounds like a high rate of failure no?
impending zombie apocalypse BRZerk Off-Topic Lounge [WARNING: NO POLITICS] 32 04-07-2013 07:00 PM
TV Station's Emergency Alert System Hacked, Warns of Montana Zombie Apocalypse JPxM0Dz Off-Topic Lounge [WARNING: NO POLITICS] 8 02-17-2013 11:12 AM
Man eat's roommate's brain and heart. [zombie] Giccin Off-Topic Lounge [WARNING: NO POLITICS] 12 06-01-2012 03:59 PM
Miami's First Zombie Victim WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 22 05-30-2012 03:03 PM
Zombie car...? MF_DEUCE Off-Topic Lounge [WARNING: NO POLITICS] 26 08-31-2011 09:20 AM
