Old 12-27-2013, 11:09 PM   #21253
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Should I make an FI thread?
Nevermore is offline
Old 12-27-2013, 11:12 PM   #21254
sklimo
I'll let you know when I want to get banned lol
sklimo is offline
The Following 2 Users Say Thank You to sklimo For This Useful Post:
Nevermore (12-27-2013), OrbitalEllipses (12-29-2013)
Old 12-27-2013, 11:14 PM   #21255
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
No no, you need to tell me which vendor you want banned. You're safe because you're not one.
The Following User Says Thank You to Nevermore For This Useful Post:
sklimo (12-27-2013)
Old 12-27-2013, 11:25 PM   #21256
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Am I the only one that wish there was a section where I could post: "I want part A, B, and C" and vendors would fight over giving me the best price? It'd be so fun.
Maybe I'm a little off, idk. Anyway, finally got my windows tinted today!
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline
The Following User Says Thank You to 6-Shift For This Useful Post:
KslayFRZ (12-28-2013)
Old 12-27-2013, 11:44 PM   #21257
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
I wasnt actually thinking of the same thing. Or if we were able to post what we want and the forum members could link us sites that may have the cheapest price for it.
Kelbyat07 is offline
Old 12-28-2013, 12:14 AM   #21258
kanundrum
Drives: 2013 Whiteout FR-S
New Comedian In Cars Getting Coffee
[ame="http://www.youtube.com/watch?v=BYf8Ra3eWi8"]Jerry Seinfeld & Louis C.K. | Comedians In Cars Getting Coffee | Season 3 Premiere - YouTube[/ame]
kanundrum is offline
The Following User Says Thank You to kanundrum For This Useful Post:
6-Shift (12-28-2013)
Old 12-28-2013, 06:13 AM   #21259
Calum
That Guy
Drives: 2013 asphalt FRS MT
A little off quote but just watched 2 episodes of how it's made and one was turbo car one SC. They put thermal cam to both and turbo gets madddddd hot sc not anywhere near. I know how both work but why such big temp diff?? Never owned FI so this one will be first
Edit they both had intercoolers
They both increase in temperature due the act of compressing the gas, but the turbo also has the exhaust gases running through it to increase it's temperature.
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
sklimo (12-28-2013)
Old 12-28-2013, 10:55 AM   #21260
sklimo
Forgot exhaust facepalm
sklimo is offline
Old 12-28-2013, 11:55 AM   #21261
serialk11r
Drives: '06 AM V8V Coupe
I remember a long time ago, in the age of this forum, some guys were talking about a newer style twin screw that was much more efficient and offered a compressor size that would match well to this engine. Was that the Lysholm you speak of?
Nah, that's Eaton TVS like Dimman said. Innovate I think uses a Lysholm (which, by the way, is HORRIBLE for street driving because it saps so much power).
Without going into details, I think you can think of TVS's efficiency as kind of like how high revving naturally aspirated engines make a ton of torque at the top end. The port is designed so that in some speed range the uneven flow of air and waves are "in tune" with the spinning vanes, and allow the compressor to operate much more efficiently than you'd initially think.
That said, there's a reason why the maps don't show you what happens below 9000rpm, the compressor sucks.
serialk11r is offline
The Following User Says Thank You to serialk11r For This Useful Post:
Calum (12-28-2013)
Old 12-28-2013, 01:38 PM   #21262
Calum
That Guy
Saps power compared to...Non-positive displacement? ...the roots style? (Above or below that 9000 rpm you mentioned.)
I wonder if that's why they had such a hard time getting the sprintex kit to idle well?
Calum is offline
Old 12-28-2013, 02:35 PM   #21263
Taro
You call him Dr. Jones!
Taro's Avatar
Drives: 2013 Twin Mish-Mash
[IMG][/IMG]
Taro is offline
The Following 3 Users Say Thank You to Taro For This Useful Post:
6-Shift (12-28-2013), Dimman (12-28-2013), kanundrum (12-28-2013)
Old 12-28-2013, 08:48 PM   #21264
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Put my 1,000th mile on the FR-S today.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline
Old 12-28-2013, 10:56 PM   #21265
serialk11r
Yup. Roots style doesn't use that much power idling, it just has to turn the gears and pump air through a tube not against any significant pressure. The twin screw is always compressing air, so twin screw supercharged cars have crappy idle because the engine needs to produce significantly more torque at idle to turn the charger.
Also, I thought of a neat way to have a manual transmission hybrid. Hyundai uses 2 clutches, but if you think about it, neutral is kind of like declutching the transmission input shaft, so why not have an electric motor on the input shaft (after the clutch)? The electric motor throttle is actuated at the same time as the gas engine throttle, and if you want to get fancy you could have the electric motor speed follow the gas engine speed. To start the engine you'd put it in neutral, release clutch, step on gas pedal. Downshifts/upshifts would be automatically synchronized.
Old 12-28-2013, 11:06 PM   #21266
Dimman
Kuruma Otaku
Dimman's Avatar
On my way up North. Holidays almost over...
Because titanium.
Dimman is offline
