Old 12-27-2013, 06:30 PM   #15
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Wow, wonder when those came out. Seems solid for people that don't need a hardcore alignment with +/- 1.5 degrees adjustment (and even then you still may be good with these combined with the camber gained from a natural drop). I meant he SPC lcas only give 2 degrees and these are under $100.
But would these alter toe just like lcas do?
But pressing in and out the bushings could be harder and more expensive than just buying and installing the $200 SPC LCAs. I was thinking of the H&R camber bolts, or just dremeling the stock LCA and using a washer (making a SPC clone), but in the end LCAs aren't that tough to install. I'm like many, I just want to bring my rear camber in a tiny bit after lowering.
mike_ekim1024 is offline   Reply With Quote
Old 12-27-2013, 06:40 PM   #16
Calum
That Guy
Drives: 2013 asphalt FRS MT
This got me wondering so I looked into it. They don't need to be pressed in and out to adjust.
Old 12-27-2013, 07:49 PM   #17
mike_ekim1024
True.. but I don't know much about pressing, and it's actually more work than just replacing the LCA since you need to take the LCA out to press it right? I think the SPC LCAs would be easier to adjust also.
Old 12-27-2013, 07:58 PM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Pressing is mearly renting the tool from autozone/oreilys/etc and putting them in, then its just a basic camber bolt to adjust so that is the easy. I'm gonna have to read up on adjustment.
edit: looks like adjustment is basically like any eccentric bolt so it is pretty straight forward
Old 12-27-2013, 08:03 PM   #19
Calum
That Guy
Check the install instructions for yourself. It looks pretty straight forward to me, you do have to 'press' the splined bolt into the bushing, but you just use the provided nut and two wrenches.
http://www.whiteline.com.au/docs/ins...ides/Z5274.pdf
I feel like I'm defending these, but I'm just trying to offer what info I've found. Which isn't much. I haven't used these and don't know how well they'll work. They just seem like an ideal solution, for the price, to me.
ecutek ability to adjust to different % of E85 Mars2 Software Tuning 2 12-15-2013 01:04 PM
Passenger Seat adjust ? rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 6 06-09-2013 10:37 PM
Anyone know how to adjust bass/treble on the Brz? ysr50guy Electronics | Audio | NAV | Infotainment 2 02-25-2013 05:45 PM
Does the ECU adjust quickly to octane change? Evil86 Engine, Exhaust, Transmission 2 07-02-2012 07:30 PM
