Old 12-26-2013, 03:01 PM   #141
Dezoris
Dezoris's Avatar
Originally Posted by Brick View Post
That's what I figured but wanted to make sure, do you need a check valve to keep the catch can from getting pressurized?
Check valve not needed for the catch can's sake, at least on the Radium as it is a sealed unit. But most SC/Turbo kits utilize a check valve on PCV line. Just put it after the catch can right before Intake manifold.
No check valve needed on breather line to intake though.
The Following User Says Thank You to Dezoris For This Useful Post:
whataboutbob (12-26-2013)
Old 12-26-2013, 03:30 PM   #142
Brick
Drives: White 2013 FRS
Thanks, your posts on the PCV system have been real helpful for those of us trying to do the FI thing right. Now I just need the rest of the turbo kit.
Brick is offline   Reply With Quote
Old 12-26-2013, 03:43 PM   #143
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Great DIY. Ill be doing this before I start tracking this season!
FRSfan111 is offline   Reply With Quote
Old 12-27-2013, 02:46 PM   #144
Dezoris
Dezoris's Avatar
Radium updated me. Car is in shop and catch can is almost finished and will use factory mounting location for FI and NA.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
kster1 (12-27-2013), R2 (12-27-2013)
Old 12-28-2013, 11:25 AM   #145
Craig
Craig's Avatar
Drives: Asphalt FRS
Why does my engine look different from yours.... I don't have the clamped hose in my bay, just the one on the left in this photo. The one on the right just has some kind of cap on it. When I noticed this I stopped my instal thinking I was retarded....
Current: Nameless Headerback- Crawford BPB - Zeta Intake Duct - Mishimoto Intake
Craig is offline   Reply With Quote
Old 12-28-2013, 02:08 PM   #146
Dezoris
Dezoris's Avatar
The one on the left is the PCV line it is unclamped from factory. I clamped mine because of forced induction. The one on right is brake booster.
Old 01-01-2014, 03:31 PM   #147
Brick
What check valve did you use? @Dezoris
Old 01-01-2014, 05:45 PM   #148
Dezoris
Dezoris's Avatar
The one that came with the Vortech kit.
Old 01-01-2014, 06:07 PM   #149
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
The right hose goes to the brake booster on the manual cars. You have an automatic and that is taken care of in a different way. It has no impact on the pcv line. You will also have more stuff in the way of your install as there is a lot more stuff everywhere for the auto trans, but nothing is different about where you connect a catch can. Pcv in same spot etc. I only know because I installed two catch cans over Christmas. One on my manual. One on my uncle's auto.
I also looked at his cross eyed for a second thinking wtf, but it all worked just fine. Just more stuff in the way is all. Made me wish I had smaller hands.
FrsDuke is offline   Reply With Quote
The Following User Says Thank You to FrsDuke For This Useful Post:
Craig (01-02-2014)
Old 01-02-2014, 08:30 PM   #150
JB86'd
JB86'd's Avatar
Drives: JAWS
Just ordered one of these bad boys. 2500 miles..N/A.
For (top) inlet fitting I got the -6AN (comparable to 0.425") 90degree 2pc adapter for 3/8" pushlok hose.
For outlet (side) fitting I got the 0.550" green barb, which says it'll be a tight fit with 1/2" diameter hose.
I see you guys are using 11/32" hose for the inlet..is that going to work with the inlet I ordered or should I use 3/8" hose? I'm planning on clamping all connections, if that helps.
I'm excited to get this and install it, and I'll definitely share my experiences.
JB86'd is offline   Reply With Quote
Old 01-02-2014, 09:11 PM   #151
xxscaxx
Drives: 2013 SWP BRZ
I was going to pick up a universal can but after seeing their facebook updates, i'll be holding off until there specific kit for the twins. They are saying january so hopefully soon.
xxscaxx is offline   Reply With Quote
Old 01-02-2014, 09:44 PM   #152
FRSfan111
Can't wait for the kit to come out. I'm tempted to just DIY my own bracket though if it doesn't come out soon.
Old 01-02-2014, 11:51 PM   #153
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Made a small change to the bracket of mine:
Before:
After:
I tell you what, the weatherproof cold shrink tape I use as a rubber isolater inbetween the strut bar and the aluminum angle pieces really bonds the 2 together...with the hose clamp off and trying to get the top bracket off the strut bar to size it down it would not budge....took everything I had to work it free. The bottom one was impossible to get out by hand...had to wack it with a hammer and block of wood to get it off... That's some good stuff!
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 01-03-2014, 12:18 AM   #154
Dezoris
Dezoris's Avatar
Before:
After:
Thats some excellent work, the tape is a good idea as well. Really like it.
2013 FR-S Product Technical Info and Specs (from Las Vegas press event) ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 53 07-19-2021 05:59 PM
Fifth Gear reviews the GT86 (Full Video) lazyluka Scion FR-S / Toyota 86 GT86 General Forum 20 10-10-2012 06:09 AM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-02-2012 11:11 PM
