Old 12-24-2013, 06:37 AM   #729
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
it is ok now i managed to update.
ST-A is offline   Reply With Quote
Old 12-26-2013, 10:51 AM   #730
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Who else here has had their LTFT go up after switching back to gasoline from E85 maps or after trimming the intake snorkel?
I was looking through my old logs from before testing out the E85 map, and my LTFT were lower than they are currently with the OFT stage 1 map. I looked for exhaust and vacuum leaks and was only able to find a very small leak in the mid pipe to front pipe connection. Only things that were different pre and post- E85 were the trimmed intake scoop and the MAP version. (v1.3 vs. v1.42b)
Is it possible that the MAF scaling need to be modified to account for the trimmed intake scoop? LTFT has increased across the entire range to around +10% plus minus a few percent.
Old 12-26-2013, 11:08 AM   #731
Malt
Drives: 2015 WRX
Is it possible that there still is some E85 in the tank? That might explain the lean LTFT
Sent from my SCH-R970C using Tapatalk
Malt is offline   Reply With Quote
Old 12-26-2013, 01:19 PM   #732
Hachiroku
Administrator
Hachiroku's Avatar
Drives: Boxster 986
Read my warnings: http://www.ft86club.com/forums/showt...54#post1411654
This applies to the entire subforum. For those who want to keep trolling and posting off-topic, you will face infractions.
Keep your discussions on-topic and technical.
Hachiroku is offline   Reply With Quote
Old 12-26-2013, 01:33 PM   #733
s2d4
s2d4's Avatar
@shiv@vishnu
will OFT get fbkc, flkc, iat, iam working on non-us cars on the next update?
Technical enough? @Hachiroku
Old 12-26-2013, 01:38 PM   #734
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by s2d4 View Post
@shiv@vishnu
Last I heard they are working on it.
Btw slo did you ever fix your rattle?
Installed Mods:
Old 12-26-2013, 02:08 PM   #735
s2d4
s2d4's Avatar
Yeah, I know they are for usdm.
Didn't know if it applies to non-usdm.
Old 12-26-2013, 04:34 PM   #736
solidONE
solidONE's Avatar
Likely not much if any of the last tank of E85 is left. I'm on my 3rd consecutive tank of 91 octane after switching from E85.
Old 12-26-2013, 06:18 PM   #737
DEK186
DEK186's Avatar
Drives: 86 GT MT Velocity Orange
@shiv@vishnu
Don't we need to check these things during logs to make sure the tune is right for our Oz conditions?
Are there any other alternative logging options available? All good to keep an eye on the fuel trims, but I want to see if my car will be knocking!
DEK186 is offline   Reply With Quote
Old 12-26-2013, 06:37 PM   #738
s2d4
s2d4's Avatar
You can check the ignition timing against the base timing map + timing advance and see if it matches or higher then there is no knock.
Last edited by s2d4; 12-29-2013 at 11:06 AM. Reason: Didn't get it right 1st time around, still learning
Old 12-27-2013, 01:53 PM   #739
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
I know this may have been ask before but I can't find it,,, If I have Ecutek how do I remove it and use Openflash?
kombatlion is offline   Reply With Quote
Old 12-27-2013, 01:54 PM   #740
jamesm
You could flash the stock map back on with ecutek then install the openflash. Not sure why you'd do that now that ecutek offers oft-equivalent tuning for free.
Old 12-27-2013, 07:09 PM   #741
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Lol, just asking!!! Thanks!!!
Old 12-27-2013, 10:46 PM   #742
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
To be fair, for many customers, there is more to the OFT than just the tune-ability. Handheld convenience and not needing a laptop for diagnostics, data logging and data graph viewing plays a big role. Resale value is also a pro since it is divorce-able hardware that can be resold with very little to no depreciation.
At the end of the day, there are multiple good options for people. Which is good because different people will way pros and cons differently.
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
