Old 12-20-2013, 01:24 PM   #15
OrbitalEllipses
Drives: Attitude
Originally Posted by switchlanez View Post
Bump for same question. What other brands offer front/rear calipers designed for stock rotors? Goal is more for show purpose than performance but arguably still way more functional than the alternative: $25 imitation-Brembo caliper covers.
2006-2007 WRX 4 pot FHI front caliper is bolt-on and fits stock rotor. 2006-2007 WRX 2 pot FHI rear caliper is NOT bolt-on and fits stock rotor, KNS Brakes makes a bracket that fits that caliper to our style rear setup: http://knsbrakes.com/c/kns-bracket
It appears that @Mach V Dan also has the rear bracket/kit: http://www.fastwrx.com/sufobrup2wr.html
switchlanez (12-20-2013)
Old 12-20-2013, 02:26 PM   #16
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Originally Posted by TouchMyHonda View Post
I daily my car. I will track it maybe 1-3 times next summer. I have Carbotech xp8's all around and completely stock everything else.... the stopping power and modulation is insane. I am also on oem tires.
Thanks bro. I'll keep the carbotechs in mind.
Tye300 is offline   Reply With Quote
Old 12-20-2013, 11:42 PM   #17
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Originally Posted by Tye300 View Post
Thanks bro. What pads did you use? I'm just weary of buying different pads then decide to get a bbk after. After you went FI, did the pads cut it? I'm willingnto try a set of pads first, then decide after that. I just want to choose the right pad right away.
I'm on TOM's sports pads
could still be better but good value.
andrewFT86 is offline   Reply With Quote
Old 12-21-2013, 03:43 AM   #18
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
I think the goal is to have the look of BBK calipers instead of spending 5k+ on a full on BBK while still maintaining - but not necessarily improving - performance. The OP's question is very straighforward (he never asked about performance) yet it's getting questioned back w/ nobody giving a straight up answer to the original question.
Bingo, thank you.
The stock brakes work fine under light/medium track use with upgraded pads and fluid.
Just want something that looks better without breaking the bank on that part of the car,
and if pads are then easier to swap out without having to unbolt the caliper, even better.
Don't want STI Brembo's because of the heavy front rotors and the Subaru 4/2 pots leave me wanting a little more.
Therefore... just looking for lightweight aftermarket calipers.
Anorexic 86 is offline   Reply With Quote
Old 12-26-2013, 07:51 AM   #19
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
To everyone upgrading brakes.... Have you upgraded tires yet? Upgrading tires should be number one as its the only thing touching the ground from the car. Upgraded brakes with stock tires are a waste of money as you out brake the stock tires with stock brakes as it is now.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 12-26-2013, 07:55 AM   #20
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Can I ask the reverse question? Which affordable slotted/drilled rotors are best for the fronts with everything else stock? For look/function.
Old 12-26-2013, 08:21 AM   #21
s2d4
s2d4's Avatar
Perhaps you guys can try the cosmetic section.
Old 12-26-2013, 09:31 AM   #22
makinen
makinen's Avatar
Drives: Toyota 86
I've used EBC yellow-stuff pads and EBC slotted rotors (USR series) successfully on track days.
Mine are lower spec brakes so USR729 rotors are used. But for 294mm rotors, USR972 should be used.
makinen is offline   Reply With Quote
Old 12-26-2013, 10:21 AM   #23
BRZ68
Drives: BRZ m/t
I highly recommend Project Mu HC+800 street/track pads. They're carbon metallic so initial bite is pretty good. It also has tad higher friction coefficient than carbotechs. The only downside is you get little noise when not bedded properly.
BRZ68 is offline   Reply With Quote
Old 12-26-2013, 10:31 AM   #24
BlueDubbinTDI
Whichever the US spec FR-S is equipped with. Not interested in pads atm as all my extra money is still going into cosmetics, track use later. You liked the EBC rotors though?
Old 12-26-2013, 10:53 AM   #25
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Nope.
Old 12-27-2013, 01:08 AM   #26
makinen
makinen's Avatar
Drives: Toyota 86
I like them except size.
FS - (NoVA) OEM Front Brake Calipers, Rotors, Pads, Lines (~4k miles) swift996 Brakes, Suspension, Chassis 23 05-05-2014 08:15 AM
Stock Calipers Now Painted/Coated? Bristecom Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 06-25-2013 04:31 PM
OEM Calipers, brakes and rotors. 800 miles driven RUNAMUK Brakes, Suspension, Chassis 3 05-24-2013 04:04 AM
Stock Calipers Rusting Fast? ProTekk Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 04-19-2013 06:06 PM
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! NickFRS Brakes, Suspension, Chassis 6 03-14-2013 01:38 AM
