| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
| View Poll Results: What are you opinions on negative camber, from a looks perspective? | |||
| Looks great |
23 | 52.27% |
| Looks ugly |
21 | 47.73% |
| Voters: 44. You may not vote on this poll | |||
Troll Hunter
Drives: fr-s, tundra
What are your opinions on negative camber, from a looks perspective?
I'm curious to see what everyone's thoughts are on excessive negative camber. I know it has functional benefits, but aesthetically, do you like the look?
Personally, I find it disgusting. I would never lower my car so low that I need negative camber to prevent fender rub. I also think it looks pretty trashy and am not a fan of seeing these cars with high negative camber. For purposes of the poll, significantly more cambered than stock
#2 |
What do you consider high?
#3 |
Troll Hunter
Good point. I updated the OP. Anything more than stock.
#4 |
Drives: 2013 FRS Asphalt
Stock wheels with lots of neg camber ugly. Nice fat wheels with lots of camber sexy.
2013 Scion FR-S AT Picked up 5/30/2012
#5 |
#6 |
Drives: na
I prefer function over hard parking, especially on a car like the FR-S
#7 |
It was fun
Drives: Dirty FR-S
Functional negative camber looks aggressive. I like a good stance too, but I hate hellaflush camber.
#8 |
Drives: 2013 FRS, 2008 R32
#9 |
Drives: '13 SWP BRZ
I hate high-cambered cars that are driven on the street for the purpose of trying to fit an improper fitting wheel. If its for a car that is tracked then yes, I like it because the car is actually putting the camber use.
#10 |
is better than you
Drives: 2013 raven FRS
you should have just named this thread, hella flush is hella retarded Y/N
#11 |
Glorious BRZ Master Race
Drives: Subaru Libird
"For purposes of the poll, anything more negative than stock" is a little vague. Allowable factory camber spec is -1.3 front and -2.4 rear (per http://www.ft86club.com/forums/showthread.php?t=7918). Being at the limits of factory camber is visually noticeable compared to typical factory camber (0 front and -0.5 rear) but still factory spec. So are you referring to anything more negative than -1.3 front and -2.4 rear or anything more negative than typical (0 front and -0.5 rear)?
The following TRD 86es have their camber plates maxed out likely beyond factory spec but are still visually tasteful. ![]() ![]() ![]()
#12 |
Troll Hunter
Do we really have to get into the technicals? The question I'm asking is pretty obvious
#13 |
Drives: '24 GR86
^Not really
There's more to camber than just running it so wheels don't rub.
#14 |
Just a dude
Drives: Scion FR-S 2013
Too high=what? As others have said
Stance no I don't care for that, but that is one persons desire so that is fine? Too many variables really. Stock ft camber sucks in comparison to having even -1.5 for example you don't need to be a track star to notice the improvement in simple spirited driving. -1 to -2 degrees ft or rear IMO looks perfectly fine "looks wise" past that well then I need to evaluate if it for function, if so that's good on them. All I can say is that with this platform having a good alignment and having "some" negative camber up front is heaps better then stock function wise so that will over run what I think a tad of negative looks like. For my own personal needs I will not exceed -2 ft or rear and that is a very functional range for "me". Guys who are tracking regularly will and do use -3 to -4 range up front and that is perfectly understandable. IMO (0) up front is not right for a sports car to begin with. Conclusion, straight up and down on this car looks "not good" mostly cause I know the benefits of having camber on "this car"
| Question About Negative Camber: More Negative Camber == More Grip at Corner? | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 03-10-2019 03:08 PM |
| Advice on negative rear camber | Thongpocket | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 09-27-2013 11:38 PM |
| 86 vs. 2013 STI - a DD perspective. | Jar | FR-S / BRZ vs.... | 22 | 07-10-2013 03:04 PM |
| Excessive negative camber? | MTeator | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-22-2012 11:30 AM |
| A different perspective on price. | Hanzo | BRZ First-Gen (2012+) — General Topics | 19 | 06-11-2012 10:07 PM |
