Sam Strano
Old 12-25-2013, 12:39 AM   #463
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by Kido1986 View Post
The newest Fastrack changed the wording from 1/4" (6.35mm) inch offset to 7mm offset. Look for the January FastTrack for this information
Ah, ok, thanks. All hail the metric system
UPD: looked at FasTrack, and it's only a proposal for 2015.
UPD2: holy phuk, any combination of 16-18" inch wheels on all corners is legal. It sure gonna look funny.
Old 12-25-2013, 01:06 AM   #464
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Oh, I understood from reading RRAX Forum that clarifications, which this was marked as, are immediate.
I'll have to re-read it later to figure it out for sure then.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 12-25-2013, 12:37 PM   #465
Rexpelagi
Drives: 2013 Subaru BRZ
I believe it is for 2015 and beyond as proposed, although I think there should be some off-the-books penalty for anyone that protests someone using +41 this year knowing the change for next year (assuming it goes through).
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
Old 12-25-2013, 01:16 PM   #466
Kido1986
Dodging cones
Kido1986's Avatar
For real. If you lose to someone and you truly believe it's due to their effective 2mm extra track, you should re-evaluate your SCCA membership lol
Old 12-25-2013, 02:31 PM   #467
dsgerbc
That probably won't matter for *wheel choices* in 2014. I don't think there are any light wheels with +41 offset. Maybe next year TR will start selling RPF1s in +41 and all the hardcore peeps will sell their +42 versions cheap
Old 12-25-2013, 09:53 PM   #468
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I think the last thing this car needs another 2mm width penalty.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 12-27-2013, 04:48 PM   #469
mrazny
Drives: BMW 135i, soon to BRZ
Originally Posted by SeanRTR View Post
We're still going to be waxed by D-Street in even a halfway well driven late model Audi TT, or 2.5L Subaru WRX, likely even on raw time....let alone the PAX.
I have serious doubts you'll see many 8 participant D-Street tours with all of those being great drivers.
I truly believe that a C-Street Winner being left out of the Pro-Shootout will be the exception not the rule.
mrazny is offline   Reply With Quote
Old 12-29-2013, 12:25 PM   #470
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
I need some clarification. I've always been under the impression that in Stock/Street if a car comes with slotted rotors you can only replace it with slotted to be legal. Not cross drilled and slotted just slotted. For our cars they come with plain vented rotors so we can only replace them with plain vented rotors not slotted or cross drilled/slotted. Is this still the case? A couple folks were trying to tell me that I could upgrade to slotted.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 12-29-2013, 09:42 PM   #471
Kido1986
Dodging cones
Kido1986's Avatar
You need to retain stock rotors from what Ive read. I moved to slotted when planning to go to STX then changed my mind and had to switch back to OEM.
"upgraded" rotors will not help with autocross so if you were doing so for it, but if you were looking at them for track days, I'd suggest changing rotors back and forth when doing a track day. Just use nice pads and fluid and call it a fun day
Old 12-29-2013, 10:39 PM   #472
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Thought so. I'm planning on just picking up some cryo treated centric plain rotors
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 12-30-2013, 03:23 AM   #473
Rexpelagi
Yep, stock rotors or stock replacements - if it doesn't say you can, then you can't.
Originally Posted by SCCA Rules
13.6 BRAKES
A. The make and material of brake linings may be changed.
B. Substitution of clutch and brake hydraulic lines with solid metal or
braided metal is allowed on all cars manufactured before model year
1992.
C. Alternate brake bleeder
fi
ttings (e.g., Speedbleeders®) are permit-
ted. They may serve no other purpose.
Personally, I don't think you will see any benefit from going to stock-sized slotted and/or crossdrilled rotors on a track. Outgassing isn't really a problem these days and extra stress risers on the rotor surface combined with less heat-sink mass aren't positive performance factors.
As kido mentioned, if you are looking to improve braking performance upgraded pads with a good DOT 4 or 5 fluid will do far more than brake rotors, and they are Street-class legal. However, they don't have the bling factor.
-John L.
2011 BMW M3 - 57 FS
Old 12-30-2013, 09:28 AM   #474
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Haha well I'm not worried about bling. I swapped to ATE blue last year so I'm good on brake fluid.
After two full autox seasons my rotors are squealing. I need to swap them out. If I'm not mistaken Subaru warranties 1 set of pads and rotors.
Old 12-30-2013, 10:51 AM   #475
Kido1986
Dodging cones
Kido1986's Avatar
Rotors are squealing? I'm a crap mechanic but I thought pads were what generally did this?
Are you on OEM pads still? They are likely shot. Give some DS2500s a shot if you end up buying new pads yourself.
Rotors should be fine this early, unless you overheat them too often or get down to metal on pads.
Old 12-30-2013, 10:53 AM   #476
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Pads are squealing because the rotors are warped. * I'm on Porterfield R4S pads right now.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
